Question about Braun Tassimo Coffee Maker
Add water light
Had no luck with the magnet on my tassimo for water light....has anyone taken apart the machine and if so, how do you do it.....I have a couple of ma hines I want to fix...
Fix water level censor tassimo
Check to e if the magnet in the reservoir is moving up & down if not then try to place a magent on the back of the machine
Aug 26, 2014 | Bosch Tassimo TAS4511UC Coffee Maker
Tassimo low water light will not reset
The problem is because Tassimo water tanks have a floating magnet in them which operates the water level switch inside the body. The magnet gets weak over time. Replacement tanks cost too much to be worth the cost. The simple answer is to stick a fridge magnet on the back of the unit (just above the power switch) using blue tack or similar (you can experiment to find the right position). Our unit has been working fine like this for a few years now. :-)
May 24, 2014 | Bosch Tassimo TAS4511UC Coffee Maker
All light flashing in my tassimo coffee machine noise as it will start but do not start'
Check the owner's manual and see if there is a reset button. If not then make sure that the cup that holds the grounds is fitting secu rely, If it's not in just right it will not allow the machine to start. These are simple ideas that you've probably tried but I hope they help.
Keith1562
Feb 28, 2013 | Coffee Makers & Espresso Machines
Our tassimo will not stop blinking, all the lights. We have tried cleaning it but that does not work. Where do we send it for repair?
Hey I was having this same problem with blinking and I was shaking the tank trying to get it to engage when my husband, who can fix literally anything, discovered that the magnet in the tank has to engage with the read sensor inside the machine. This magnet is what tells the machine that the water is getting too low. Our magnet gets stuck out of place sometimes. He said it is getting weak and we need to replace it. He used another magnet and held it at the back of the machine beside the tank near the magnet to trick it to engage. It really works! Now, I wonder if Tassimo can send me the perfect size little magnet to replace it. HMMM!
Aug 31, 2010 | Braun Tassimo TA1400
All the lights on my machine are flashing. What
I had flashing lights in my braun tassimo and tried all previous solutions
Cleaned the barcode reader
Seated the water container properly
The problem was down to the flosting magnet in the water container (which was floating when filled)
The magnet had lost its strength somehow, so i held a strong magnet from from a fish tank cleaner at the back whilst the water container was in and it worked perfect
Inside the machine is a sensor which detects the magnet that floats in the water container
I am looking for a new magnet and will keep you informed if it worked when i get one
Good luck from Ash
Feb 05, 2010 | Braun Tassimo Coffee Maker
Empty water tank light stays on
The only thing thats comes to mind is the reed switch and the float on the water tank. Check the float make sure the magnet is working, if yes then the reed switch on the inside of the machine is not in the correct position.
Dec 30, 2009 | Solis Palazzo Espresso Machine
The sensor on the water tank will not hold in position making all the lights flash, not making coffee!!
My Tassimo was doing the same thing. Defective tank sensor, I taped a small magnet on the back just above the power switch next to the water tank to trick the machine into thinking there is water in the tank. Just make sure there is water in the tank, as the sensor is now fooled on.
Oct 26, 2009 | Braun Tassimo Espresso Machine/Coffee...
Light keeps flashing and water will not heat
there is a float at the side of the machine by the water level, if the float gets stuck the red light will continue to flash even though water is present. Use a magnet on the outside of the machine by the water and float level and raise the float when connected to the magnet and the light will stop flashing red rapidly
Oct 05, 2009 | Philips Senseo HD7832 Coffee Maker
All the lights are flashing on my Braun Tassimo TA1200 and will not make coffee
Several possibilities: (1) No water in tank.
(2) Tank not inserted properly. Try removing tank and then replacing it, making sure that the hook-tab at the back of the tassimo body engages the matching slot at the front of the tank.
(3) Tank not seated properly. Try pressing down on the tank and twisting left or right. If this stops the blinking and allows your drink to brew, at least you know where the problem is. If you have to do this all the time, consider exchanging the unit.
(4) The lights will all also blink if there is residue (coffee, milk, etc) on the bar code reader window. The residue is usually plainly visible. The bar code reader window is a horizontal rectangel directly under where the bar code of the T-Disc sits in the Tassimo. To fix this, just wipe the window clean (no need to scrub), close the lid again and check for blinking.
Aug 07, 2009 | Braun Tassimo TA1200 Espresso Machine
Braun Tassimo Coffee Maker Logo
Top Braun Coffee Makers & Espresso Machines Experts
ellipse0904
Level 1 Expert
Jim Thurston
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
