Question about Garden
AA HPW 110 Pressure Washer,fix on off switch in gun handle
How does the on off switch sit in the housing of the handle
5 Suggested Answers
dnewcombe1
  • 1564 Answers
SOURCE: pressure washer water leaking from gun
Depending on the manufacturer, you may purchase a rebuild kit for these very inexpensively. It's just a small pack of o-rings and maybe a spring or two. It would be a good weekend job, pretty simple to figure out, I've got faith in you. Thanks Dana
Posted on Aug 22, 2009
SOURCE: washer stops when handle released
unloader valve not functioning properly causes pressure overload and stalls engine
Posted on Sep 02, 2009
  • 174 Answers
SOURCE: Troy Bilt pressure washer model 020209 will not
A leaking gun will kill all the pressure. You may need to repair or replace the gun
Posted on Sep 17, 2009
  • 34 Answers
SOURCE: I have a Karcher 110
Which part of the handle is water leaking from? It could be that the hose connection into the gun is not fitted properly. Otherwise it could be that you just need to replace the handle.
Posted on Mar 02, 2011
Dc17 won't turn on
there is a reset button under the cover that houses the on/off switches. remove the handle/wand and look on the back (where the top of the hose sits) for 2 screws (its a torx/star head screw size t10 i believe). remove them and locate 4 small locking tabs that hold the switch cover to the frame of the vacuum. Depress them and pop the cover off (2 towards the top and 2 towards the bottom). Youll see 3 switches (2 square red buttons and one small cylindrical shaped one). Push the small red one (the one to the left if my memory serves me right). you should hear a click. if you do than the switch is reset. if not check all connections to all 3 switches. if you see nothing loose or not connected, you may need a new brushbar motor.
Nov 18, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Porter cable 352vs manual
My Porter Cable 352vs Belt Sander was clogged from sanding epoxy, wet wood, something like that. No dust collection at all.
I had to remove 4 screws on the housing, one screw under the front handle and another below the rear handle. The housing came out very easily (with a little wiggle). Pay very close attention to where the position of your plastic fan housing sits. It will only be installed in one spot.
http://www.ereplacementparts.com/images/porter_cable/352_TYPE_1.pdf
The pdf diagram was not exactly correct on the housing placement.
Once opened, The wood and epoxy were caked in everyplace. I brushed them out and replaced the screws.
Good as new.
Good luck.
Feb 24, 2012 | Tools & Hardware - Others
Glacier Bay bathroom faucet - 2 handle leaks
see if the housing itself will unscrew
Jun 06, 2010 | Garden
The starter pull cord has pulled off.
EASY,REMOVE TOP COVER OF ENGINE THAT HOUSES ROPE ASSY. LOOK UNDERNEATH PLASTIC PIECE,CUT THE KNOT OFF THAT COMES THROUGH HOLE AND PULL AND EXISTANT ROPE OUT. OK, GET NEW ROPE AND HANDLE TOGETHER,THE END THAT IS OPPOSITE FROM NEW PULL STRING HANDLE YOU ARE GOING TO USE. CAREFULLY WIND UP ROPE HOUSING NICE AND FIRM JUST BY WINDING IT UP WITH HAND IN AS IT SITS IN TOP COVER. WHEN YOU THINK IT HAS ENOUGH TO PULL ROPE IN FEED END OF ROPE IN HOLE AND IN CHANNEL OF ROPE HOUSING,THERE IS A SMALL HOLE TO LINE IT UP WITH,WHEN SEE THE ROPE END FEED IT THROUGH THAT HOLE NOW. MAKE TAKE ANOTHER SET OF HANDS OR A WEDGE TO STOP RETRACTING OF SPRING. PULL ROPE THROUGH AND TIE A DOUBLE KNOT AT END SO IT WONT PULL THROUGH. SLOWLY LET IT PULL ROPE IN,THEN PULL ROPE BY HANDLE FULL LENGTH TO ENSURE ALL KINKS ARE OUT AND IT PULLS BACK IN LIKE IT SHOULD.
Jul 12, 2009 | Toro Lawn Mower With Toro Power Tools
How do i get the door panel of f-150 off to replace handle 1994 pick-up
  1. Remove the armrest pad retaining screw.
  2. Remove the retaining screw and washer from the trim panel upper corner.
  3. Remove the door handle screw and pull off the handle.
  4. If equipped with manual windows, remove the window regulator handle screw and pull off the handle and washer. On vehicles with power windows, remove the power window switch housing.
  5. If equipped with manual door locks, remove the door lock control. On vehicles with power door locks, remove the power door lock switch housing.
  6. On models with electric outside rear view mirrors, remove the power mirror switch housing.
  7. Remove the retaining screw and washer from the trim panel lower corner.
  8. Using a special door trim panel removal tool or a flat wood spatula, insert it carefully behind the panel and slide it along to find the push-pins. When you encounter a pin, pry the pin outward. Do this until all the pins are out. NEVER PULL ON THE PANEL TO REMOVE THE PINS!
  9. Installation is the reverse of removal.
Please don't forget to rate.
I'll get the pics here in a sec....takes a little bit to load.
May 13, 2009 | 1994 Ford F150 Styleside Supercab
Ignition wire came lose inside my stihl 210c chainsaw .
28866.png This is the only diagram that is offered for this model but on the multifuntion switch (#33) The wire is layed through the upper part of it with the metal connector sticking out of the left side and once there you will pull the wire to the right until the metal connector is seated in the switch. After this reinstall the switch into the handle houseing and make sure that the contact spring (#24) is sitting on top of the switch and when in the off possition making contact with the metal conector of the wire on the switch.
Mar 15, 2009 | Oregon Scientific Oregon Chainsaw chain...
Roller motor on a DC17 dyson wont turn on
there is a reset button under the cover that houses the on/off switches. remove the handle/wand and look on the back (where the top of the hose sits) for 2 screws (its a torx/star head screw size t10 i believe). remove them and locate 4 small locking tabs that hold the switch cover to the frame of the vacuum. Depress them and pop the cover off (2 towards the top and 2 towards the bottom). Youll see 3 switches (2 square red buttons and one small cylindrical shaped one). Push the small red one (the one to the left if my memory serves me right). you should hear a click. if you do than the switch is reset. if not check all connections to all 3 switches. if you see nothing loose or not connected, you may need a new brushbar motor. try it
Feb 02, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beam Soft Touch handle electric harness replacement
Set the bottom part of the handle down(not the part that the screws go in)the contact board will fit into slots on the left side of thehandle half, the switch will go where the cutout is for it on the top, the plug is notched to fit at the lower front part of the handle. Then put the the tube into the hose and set it into the handle. There is a ribe near where the tube sticks out of the handle, it fits into a slot just before it sticks out. There also is a stop for the hose to up against so the contact rings can't slip off. Then put the other half on and screw it down.
Jan 08, 2009 | Beam Industries Wet/Dry Auto Central...
Bissell Pro Heat Turbo 2X
Here are things to check when there is no spray from hose or nozzles.
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
May 29, 2008 | Vacuums
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
