Zebra ql320 plus firmware load - Office Equipment & Supplies
  • 88 Answers
SOURCE: I have a QL320 zebra mobile printer that locks up
if your computer is stil recognizing the printer,it's has the software so iyl be the printer itself
Posted on Jan 22, 2010
  • 185 Answers
SOURCE: zebra QL320 plus no bluetooth discovery
Turn the printer up side down and remove the battery. Undo the philips screw and remove the module from the top. re-seat it back on the main PCB and replace the screw and battery. if the module still doesn't work then it is more than likely it has failed.
Posted on Apr 13, 2010
SOURCE: How can we change from black bar sensor printing
First you need to send below file to the printer via Vista Label
Printer >> 1 Send File
Save this file as gapsen.txt:
! DF CONFIG.SYS
! UTILITIES
GAP-SENSE
PRINT
To save this as default setting, send below script (save as setting.txt)
^XA ^JUS ^XZ
Posted on Dec 23, 2010
  • 135 Answers
SOURCE: How ot change the font
Contact Zebra Technical Support Phone: +1 877 275 9327
Fax: +1 847 913 2578
Kiosk Only: +1 866 322 5202
**Best Option will be to call them since it is a mobile printer**
Posted on Mar 10, 2011
SOURCE: How to calibrate the label in QL320 plus zebra
create a text file called Calibrate.txt and in the text file type this:
~JC
^XA
^JUS
^XZ
then send the file to the printer using label vista.
this will then print 3 - 4 labels and stop.
once u press the feed button it will only feed one label.
Posted on Apr 05, 2011
Testimonial: "Thanks"
How ot change the font size, printed on QL320 plus Zebra printer
Mar 10, 2011 | Zebra QL 320 Thermal Printer
How to calibrate the label in QL320 plus zebra printer?How to make it only feed 1 label per print?
~JC
^XA
^JUS
^XZ
Dec 10, 2010 | Zebra QL 320 Thermal Printer
How can we change from black bar sensor printing to using the gap between labels on a Zebra QL320 plus?
! DF CONFIG.SYS
! UTILITIES
GAP-SENSE
PRINT
^XA ^JUS ^XZ
Nov 03, 2010 | Zebra QL 320 Thermal Printer
Brady 600x Plus II Date Code Is Off
mmm...Maybe try updating the firmware. That printer is a Zebra Z96XiIII Plus printer. Zebra made a change in their code for the onboard clock in version 60.13.0.5 See if you have that version and if not, you can to to www.zebra.com and download firmware for the printer.
Hope that helps !
Apr 26, 2010 | Brady BP-THT-600X+ Thermal Label Printer
Zebra QL320 plus no bluetooth discovery
Feb 12, 2010 | Zebra QL 320 Plus Thermal Printer
Z4MPLUS P3/P5 ERROR I found some problem in Zebra Z4m plus printer like error p3/p5.please give me solution for that
The display shows P3/P5 ERROR? You can try to load firmware, download the file from www.zebra.com press the keys - and +, turn the printer and you see FIRMWARE DOWNLOAD in screen, download the file through the parallel port.
Roberto Martinez
Jun 01, 2009 | Zebra Z4Mplus Label Printer
XiIII Latest Firmware
I know when I was going through the zebra website I seen a bunch of firmware downloads. Once you are on their home page just click on downloads, then you should be able to find them.
May 07, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Powers down after every print
There is a setting in the all CPCL based Zebra mobile printers called "DTR Power Off". You will need to turn disable this. It sounds like you are printing through the serial connection based on your brief issue description.
Connect to the printer with serial cable and run the Label Vista application, free from Zebra.com. If your printer is a Q3C or Q3D configuration, you can connect with a mini USB cable, but you will have to install the driver. If you have a Q3A or Q3B configuration, you must to use the serial cable (PN: BL11757-001) to connect to your PC.
Once in Lavel Vista, click on the Printer drop down and choose the COMM Port Settings option. Select the correct value for your connection type. Next, select Printer Settings from the Printer drop down. Go over to the Port tab and click the disable button under the DTR Power Off section. Click apply. If this does not work, also check your inactivity timeout setting as well as your battery level setting in the batery tab od the same screen. I set mine to "0" because I dont want my printer turing itself off for any reason.
Apr 04, 2009 | Zebra QL320-Plus Mobile Printers QL320...
26 people viewed this question
jasbo
jasbo
