Question about Canon Pixma MX410 All-In-One Printer
Error message "fax info doesn't match"
When I try to send a fax I get the error message "fax info doesn't match".
aknz
SOURCE: fax error message = TX cancelled:RX fax info
Two Issues:
1. The Transmission Speed of the MX860 may be too fast.
Solution: on FAX Menu go to Settings>Device Settings>FAX Settings>Transmission Settings >"TX start speed" and change to 14400 or lower (14400 worked for me).
2. The recipient FAX machine may be receiving by a different number than the one you dial. This may occur if you dial a free-calling no.
Solution: Go to Transmission Settings as above>"Check RX fax info" and turn it to OFF. This disables the mismatch issue.
Hope this helps. aknz
Posted on Sep 25, 2009
colliewob
  • 778 Answers
SOURCE: can't send or receive faxes on my Canon MF 6550
have you just changed over to dsl from standard modem when i had this problem it was because to fax out/in i needed a standard 56kb modem to do so as dsl does not go through the normal phone lines and cannot connect to standard phones which is what fax machines are on
Posted on Jul 28, 2008
  • 4090 Answers
SOURCE: when I send a fax to a 1800 number I get the
I wasnt aware that anyone could list a 1800 number as a fax These are supposed to be voice only.
usually the freecall lists 1800 to call and fax numbers as the usual 02,03 xxxxxx etc
Posted on May 08, 2010
  • 628 Answers
SOURCE: When I try to send
Does it work with local phones or is the problem only with certain places yo try to fax to? If it does, then there may be an incompatibility problem with some remote fax machines.
Posted on Jan 07, 2011
  • 31 Answers
SOURCE: Cannot send fax on Pixma MX328 error message redo operation
If it does it when sending to all no's then it could be a country code setting.make sur it is set to the south africa country code.
Posted on Oct 29, 2012
Oct 29, 2012 | Canon PIXMA Office Equipment & Supplies
My printer states "Check printer"
The "Check Printer" error can usually be cleared by unpluging the fax from the wall outlet, waiting a few minutes, and then plugging it back in. If the fax is connected to a UPS, or multioutlet strip, it is highly recommened to plug it directly into the AC wall outlet.
If the message stays in the display, try opening and closing all the access doors to the fax. If that still doesn't return the machine to operating properly, then you will probably need to take it to your service provider.
Aug 08, 2011 | Canon LaserClass 9000 Fax
I've been trying to send a fax to an office in Sri Lanka for several days now, but it won't go. We are getting a Comm Error 388 in the fax error report. The unusual thing is we are able to send fax...
inernational fax calls quite often do not work on digitized phone lines or via satellite. You cannot fix that. maybe your fax has a "fallback 4800 bps" setting that might be helpful.
May 11, 2011 | Office Equipment & Supplies
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
Im trying to fax.. and i keep getting an error...RX FAX INFO MISMATCH what do i do?
change fax settings from color to b&w and try again. this can happen if the fax machine at the receiving end doesn't support color fax
Apr 14, 2011 | Canon PIXMA MX340 Wireless Office...
When I send a fax to a 1800 number I get the
May 08, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Canon Pixma MX410 All-In-One Printer Logo
100 people viewed this question
old marine
old marine
