Question about Canon Pixma Mp250 Printer
I am getting a 2.140.4 error message
It tells me the printer is in use or an error has occured. Check status. Scanner Driver will be closed. I have checked and the printer is not in use. What should I do?
  • 97 Answers
SOURCE: Scanner won't communicate with my Mac
Uninstall the software with scanner unplug from your MAC. Install the software with the scanner disconnected, then connect it b4 the first use of the software.
Posted on Mar 31, 2007
jackboy
  • 2985 Answers
SOURCE: CANON 3000F
If you are runnnig XP or Vista this will happen
Go to Start/Programs/Accessoris/System Tools/Compatability Wizard
Reset the machine for Win 98
Posted on Mar 20, 2008
edisonfrelan
  • 113 Answers
SOURCE: Computer says Scanner not connected
try plugging the USB connection at the back of you computer. If still didn't work out, delete the old driver install the new one, be sure cables are connected and intact. If still didn't work out bring your scanner to the service center near you
Posted on Dec 14, 2008
  • 461 Answers
SOURCE: CanoScan Scanner can not complete a scan
Double-check all connections and try another port if possible. There may also be damage to cables or pins. Do you have another cable to try? Do other devices work in the same port?
Posted on Jan 10, 2009
  • 169 Answers
SOURCE: cannot communicate with scanner (Canoscan Lide60 on Mac OSX 10.5)
hi
click on to start then go to run and in run type in devmgmt.msc ,it will open up device manager try to check under universal serial bus control that their is no red x or exclamation mark .as this universal serial bus acts as a communicating port between computer and scanner,if their any marks try to uinstall and reinstalling the serial bus controll
and after that it will definetly work
if it doesnot work write me an email with your phone number and i will help you out in fixing it
ullekhtandon@gmail.com
Posted on Jul 09, 2009
Cannon error codes
Printer is in use or an error has occurred. check status. Scanner driver will be closed.
code 2,140,2
if scanner is not in use there is a problem using it with the USB unplugged.
May 15, 2013 | Canon PIXMA MX892 multifunction printer
Printer is in use or an error has occured check status scanner driver will be closed closed
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Use a test print to CALIBRATE the scanner. if this wont help there is fault in the motherboard.
Nov 12, 2011 | Office Equipment & Supplies
you should uninstall and re-install printer driver. that could be a driver conflict or driver corruption. check your pc for malware infection too
May 04, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Wen i try to scan my photoes an error message pops up...... SnanGear error code 2,140,2. It says printer is in use or an error has occured. Check status. Scanner driver will be closed
Stop your printer running while you are scanning photos.
It defines error because your printer and scanner running simultaneously.
Eject your printer while scanning.
Jan 07, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Printer is in use or an error has occurred. Check status. Scanner driver will be closed. Code: 2,140, 0.
I had the same problem and fixed it by unplugging the cable that connects the power to the printer while it was running. I then plugged the cable to the printer in and it worked. I previously reinstalled the driver, but it didn't fixed the problem.
Oct 26, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Printer is in use or an error has occurred. Check the status. Scanner controller will be closed. Code: 21402"
Printer is in use or an error has occurred. Check the status. Scanner driver will be closed. Code: 2,140,2"
cannon PIXMA MP258
Jul 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
Canon Pixma Mp250 Printer Logo
232 people viewed this question
old marine
old marine
