Question about WSM 1993-1999 Tiger Shark All Models 640 Cc Jet Ski Motor Mount
Spark Plug Gap Settings
What is the plug gap
What is the spark plug gap
When replacing your spark plugs you need to set them at the spec set by your auto manufacturer. Gap means the distance between the electrode and the little metal hook looking pieve at the end of the plug. This is on the threaded side of the plug. There is a $2.99 gap tool that has most gap settings engraved, your vehicle will have the gap required on a label under the hood
Feb 25, 2015 | Cars & Trucks
Spark plug gap settings chart
The spark plug gap depends from the engine make/model, not from the spark plug type.
Usually all engines will run with a gap between 0.7 and 1.00mm
Jul 30, 2014 | Champion Spark Plugs Marine Spark Plugs...
Spark plugs gap
no engine stated? wow. 3.5L? says no gap settings.
its in the FSM. many cars dont put it in the op guide as the plugs
are rated to 80k miles or more, and is not consider, operator deal.
sadly.
and many folks think the new plugs are set in the factory , WRONG. (comment is for J plugs not surface fire tech)
i see you are there.!
many stores, list it wrongly too.... vast....
but you never said country car was sold.
in the USA we open the hood, look up and behold, its right there.
the vacuum and turn up sticker,
now alldata.com
quotes to follow.........all.
the original equipment spark plugs installed in the Odyssey 3.5L V-6 engine are platinum tip spark plugs, and the plug gap must not be adjusted.
and other warnings, and the no file them warn.g
On CR-V and 4-cylinder Odyssey models, adjust the spark plug gap to 0.039-0.043 inches (1.0-1.1mm). On Odysseys with the V6 engine, check, but do not adjust the spark plug gap. The spark plug gap should be 0.039-0.043 inches (1.0-1.1mm). If the spark plug gap exceeds 0.051inches (1.3mm), replace the spark plug.
so 1mm , if not v6
Sep 07, 2013 | 2000 Honda Odyssey
Spark plug settings honda jazz 1.4 2006
Inspect the electrodes and ceramic insulator.
  • Burned or worn electrodes may be caused by:
    • Advanced ignition timing
    • Loose spark plug
    • Plug heat range too hot
    • Insufficient cooling
  • Fouled plug may be caused by:
    • Retarded ignition timing
    • Oil in combustion chamber
    • Incorrect spark plug gap
    • Plug heat range too cold
    • Excessive idling/low speed running
    • Clogged air cleaner element
    • Deteriorated ignition coils
2.
Check the electrode gap (A). If the gap is over the standard, adjust the gap with suitable gapping tool.
Electrode Gap
Standard (New):
1.0-1.1 mm (0.039-0.043 in.)
3.
Replace the plug at the specified interval, or if the center electrode is rounded (A). Use only the spark plugs as listed.
Spark Plugs
NGK:
ZFR6K-11
DENSO:
KJ20DR-M11
Apr 09, 2012 | Honda Jazz Cars & Trucks
Need do know the spark plugs gap
If you're replacing the spark plugs in your car engine, you'll need to set the gap before reseating the spark plug. The gap is the distance electricity arcs between the ground electrode and center electrode. The gap must be set correctly to ensure maximum performance. Here's how to set the gap of a spark plug.
  1. Remove the spark plug wires. Use a socket wrench to remove the spark plugs from their chambers.
  2. Clean the spark plug if you are not replacing it with a new one. Remove all dirt and debris from the spark plug.
  3. Check the owner's manual for your car (or any appliance with spark plugs) to find out the recommended gap setting.
  4. Use a gap tool to check the gap of the spark plug. Slip the tool between the ground electrode and center electrode. The gap tool should fit snugly at the recommended gap width indicated on the tool.
  5. Push the tool between the electrodes a few times to ensure proper gap. If the gap is too wide, push the ground electrode firmly against a flat surface to narrow the gap and then check again with the gap tool.
  6. Repeat Step 5 as necessary until you reach the correct gap. Reseat the spark plug and reattach the spark plug wires
Good Luck
Dec 10, 2010 | 1997 Pontiac Grand Am
Need the spark plug gap settings for Buick
sparkplug gap for 2003 buick century 6 cyl.
Feb 13, 2010 | 2003 Buick LeSabre
Ignition point gap and spark plug gap inboard outboard omc
.019 for the points and .035 for the plugs
Jul 05, 2009 | Boating
Spark Plug Gap settings
ACDELCO Part # 41103
SPARK PLUG .043 GAP
Feb 23, 2009 | 2006 Chevrolet Trailblazer
Spark Plug gap settings.
Look on you're emissions tag under the hood they should be on there.
Jan 16, 2009 | 2004 Buick LeSabre
WSM 1993-1999 Tiger Shark All Models 640 Cc Jet Ski Motor Mount Logo
Top WSM Boating Experts
Fabrice Wolters
Stan Ford
spy1309
Are you a WSM Boating Expert? Answer questions, earn points and help others
