Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge handle jvm240wl002 microwave oven spacemaker
Handle is broken need a new handle
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
  • 95 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: how do you replace a broken handle for a GE Spacemaker II microwave?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
On some models, the handle may rotate into and unlocked position then lift out.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 10, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE spacemake microwave handle door
Apparently the part number for the black handle is WB15X10020 and the white one is WB15X335.
You can order either and find find helpful exploded view diagrams here.
Enter the part number to order the part, and enter your model number to find the exploded views.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Aug 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Broken handle on GE Spacemaker XL1800 microwave
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 07, 2008
I have a 1994 GE JVM240wl002 microwave. After running it about 8 mins it stopped working. The lights, vent, control panel all work but it won't start up. Any ideas on what might be the problem?
One of the door switches bad, magnetron overheated or bad, capacitor for magnetron weak or bad or problems with the controls. Less often and more involved a bad triac, less involved the internal fuse blew but would be caused by one of the other problems.
May 10, 2014 | GE Spacemaker Over-the-Range Microwave
My counter top GE Spacemaker microwave oven's door handle is broken. Is there a replaceable door handle part?
Hi!!
Yes, there is. The part # for the HANDLE,DOOR -L is WB15X10119 and costs $15.25. You can order it from this site https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=ACCESSORY use your oven's model # to make sure you have the proper handle.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Feb 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do I repair the broken handle on my Spacemaker microwave from GE?
you have to remove the trim inside the door. you have to carefully pry the inner trim and kind of twist it as you remove it so you don't break it.
if there is enough of the handle left where the screw goes in(I'm assuming that's where it broke) sometimes you can drill into it a little and put a longer screw on. otherwise you need to buy a new handle.
May 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Broken door handle
The in side door panel ( at total pain) must come off
If the damage to the bottom is not too bad.
On mine I took the cover for the handle loose from the bottom ( it pops off, but be careful).
and put screws at the bottom
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
New handles for microwaves can be bought on amazon. Take a look here Amazon com microwave handle and choose one (which fits). P.S. watch out on reviews and handle sizes. I hope this was helpful. cheers
Sep 07, 2008 | GE JVM1851BD 1100 Watts Microwave Oven
Broken handle on GE Spacemaker Microwave Model J VM132X 004
Yes you can get parts. Sears or GE can sell you a new handle but depending on the cost it may be worth getting a new microwave. If you do it yourself, it should be fairly easy to replace otherwise Sears can probably fix it for you or they can tell you easily what to do if you get stuck or you can just ask me here. Let me know if you have any more questions and good luck to you.
Jun 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Broken door handle on GE microwave oven
hi stormy
door handles are usually model specific, but I think your serial # may be JVM140K02. look that up at a partstore web site and see if it matches
Mar 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
52 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
