Question about Vizio L32 32 in. LCD HDTV
Vizio 32 inch television is giving me problems please help
I recently purchased my vizio 32 inch television and when i first connected it it was working fine but now after a day or so the screen started changing to different components on its own but now all together it is showing no display. when ever there is a signal to be displayed the screen just shows black. i can hear the audio from the television but i cant see anything. when i change the input to something thats not connected like component when it trys to show the no signal message it starts flickering black and returns to that screen again because im guessing its having trouble displaying the image but when the no signal message leaves it just stays blue and it doesnt change black at all im guessing cause it is not trying to display anything. if anyone knows how to resolve this please let me know as soon as possible and thank you
3 Suggested Answers
SOURCE: i cant see anything on my vizio 32 inch television
Put off the TV Using the remote .Then unplug the TV 's power line from power source.Allow this for Just Over one minute .Then plug back the powerline and your TV should be okay.
Posted on Apr 15, 2008
budmrtn
  • 11361 Answers
SOURCE: My Vizio 32 model vw32L
Here are the boards for your TV:
http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VW32L
The damages can b extensive when lighting strikes, it can take out the power supply module and the main board.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jul 11, 2011
Distorted Image smart vizio tv 32 inch
It sounds that the T'Con board has failed. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 30, 2013 | Vizio E322ar
Cant hook up externl speaker to 32 inch vizio t.v.
those connections are designed to hook up to a reciever for surround, and are not amplified
Mar 05, 2013 | Vizio VO32LF 32 inch TV
Vizio 32 inch hdtv, Motorola DVR box...Whenever I turn the tv off, the cable connection is lost and I have to unplug/replug the DVR box when I want to watch the cable again. It's not the box, because I...
Here a way,u could test,if it the cable signal,tv Main tuner board have problem or the DVR box again.U have analog antena?Or go and a buy a digital antena.Reset ur tv to free air signal and use it for few hours,turn it off/on and see if u losing signal,require unplug,replug to get signal back.Two problems solved ur tv board or cable signal good or not?Than U know it the DVR box and have connecting problems.
Mar 19, 2010 | Vizio VW32L 32 in. LCD HDTV
I have recently purchased a Vizio M/N Vw 32L 4oA LCD HDTV. Would like to know the secret to plugging in the Optical cable in the rear of the TV to connect my Audio amplifier. Please!! What is the trick??
Have you removed the cover? The optical is generally not left uncovered when not in use. Have to remove the little plastic cover to plug in the cable.
Oct 02, 2009 | Vizio L32 32 in. LCD HDTV
Hello. I have a Vizio 32 inch LCD flatscreen TV. About 5-6 years old. Once on, it works fine for a minute or two but then the screen goes blank and the orange Vizio blinks on and off. Every time. Does...
this is a main board problem. Replacing this will resolve the problem for you. if you want a tech to come to your home and fix it for you, you can call ITI at 888-248-2708
Jun 18, 2009 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Register a 32 inch Vizio Tv
go to www.vizio.com. select the support and go down to the register your vizio. Fill out the require field and press submit. this will get your TV register.
Jun 16, 2009 | Vizio VW32L 32 in. LCD HDTV
Vizio 32 inch now shows mostly only green and red colors
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD
Nov 30, 2008 | Vizio L32 32 in. LCD HDTV
I cant see anything on my vizio 32 inch television
I just spent an hour trying to fix the VIZIO with the same problem. The screen had no picture at all, but could hear the sound perfectly!! But we i figured out the solution! UNPLUG THE CABLE BOX AND LET IT RE-BOOT! and it WORKED!!!!!
Aug 05, 2007 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
119 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
