Question about ASUS VivoBook X202E-CT033H Touch Laptop, 1 Yr Int. Warranty Black
How to turn on
All light like signal,battery,are lighten but the screen in not responding? please kindly help me for this?
  • ASUS Master
  • 5,660 Answers
What?............Oh, okay.............I was going to watch this Disney movie though..........
JUST KIDDING!
http://www.asus.com/ph/Notebooks_Ultrabooks/ASUS_VivoBook_X202E/
1) Laptop OFF, monitor OFF, attach a VGA monitor to the VGA port, on the laptop.
(Right side, all the way to the back)
Or you can use the HDMI port, and use an HDTV.
The HDMI port is on the Left side.
Turn the monitor/TV on.
Turn the laptop on.
Does a display show on the external monitor/TV?
No?
Hold the Fn key down, and tap once on the F8 key.
The F8 key is the Display Toggle-Over key.
Go to what you are using as an external monitor. VGA monitor, or HDTV. Hold the Fn key down, and tap the F8 key until you get what you want.
Have a display on the external Monitor/TV?
Problem is NOT the graphics chipset.
Problem is the Video Cable, or LCD/Touch screen.
Post back in a Comment, as to the results of the external monitor test.
Regards,
joecoolvette
F8 key is display toggle over
Posted on Apr 25, 2013
The screen on my TI-89 Titanium turned blue after replacing batteries? How do I fix this? It turns on and off but does not respond to any other buttons.
If you cannot see anything on the screen, you may need to adjust the graphing TI 89 Titanium calculator contrast :
1.To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark.
2. To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light.
Sep 01, 2012 | Texas Instruments TI-89 Calculator
Hazard lights and turn signals not working. Fuses are fine.
First check on the drivers awareness of operation knobs from the interior of vehicle. The drivers is required to familiarise with vehicle lightening knobs, buttons or switches dependign on the brand of volks wagen or type of vehicle. Also, the type of brand may allow for lightening to fucntion only when the vehicle is turned on completely and not on ingnition battery test alert. Insert the key in the ingnition to turn on the vehicle. Usuing the available switches either on the dashboard area at drivers side to ascertain which powers the signal lights. The same switshe smay be situated on the steering where as stick levers. Second, the vehicles power supply from bateries including electrical wirings, light blubs and finally when in fucntioning order is indication of drivers unfamiliarity ith operations functionality from within vehicle.
Jan 22, 2011 | 1999 Volkswagen Passat
Lights don't turn.
Did you mean the turn light or all the lights.?
If so check the battery , the switch or the relay/ timer ( if turn signal)
Please be specific and respond so that we can try and help
Sep 27, 2010 | 2007 Suzuki Boulevard
My ti - 83 hasn't been used in a while, placed new batteries in it and all i get is dark screen.....it won't even turn off......there is just a dark screen......any ideas what causing this and how to fix...
The most probable cause (at least I hope so) is that the screen got too dark after you changed the batteries. It is a common occurrence: Screen becomes too dark or too light.
To adjust the screen contrast:
  1. Press ^2nd key and release it.
  2. Press and HOLD the DownArrow key until screen lightens to your taste.
Mar 09, 2010 | Texas Instruments TI-83 Plus Calculator
The screen is black when I turn it on. I've replaced the batteries and no change. I try to change the contrast and nothing happens. It is a couple years old, but I should still work.
Check that the terminals in the battery compartment are clean and shiny. Remove any powder left after battery leakage. Insert fresh batteries in calculator. Make sure you respect the polarity diagram. +-+- (Many malfunctions come from incorrectly placed batteries).
To adjust the screen: Darken or lighten display
To darken screen
Press [2nd] key and release it.
Press and hold [UpArrow] until screen is dark enough.
To lighten screen
Press and hold [DownArrow] until screen is light enough.
Hope it helps.
Dec 03, 2009 | Texas Instruments TI-86 Calculator
Won't power on even though i've installed new batteries. There is no corrosion on the battery terminals.
After replacing batteries, calculator is restored to defaults and screen display may be too loght or too dark
To darken screen
To lighten screen
Hope it helps.
Nov 14, 2009 | Texas Instruments TI-86 Calculator
RAM cleared
My first guess is that the main batteries and the backup battery are depleted. Change the main batteries first and adjust the screen :
  1. Press [2nd] key and release it.
  2. Press and hold UpArrow to darken screen, or DownArrow to lighten it.
Then replace the backup battery.
Hope it helps.
Do rate the solution
Nov 13, 2009 | Texas Instruments TI-84 Plus Silver...
Philips gogear SA 1828 player hanged while playing music
possible problem is the files or the song that you are trying to listen is currupted.delete it and replace it with other.
Sep 27, 2009 | Philips GoGear HDD1830 MP3 Player
Please help!
check your settings.(the middle button on the screen part. make sure it is set to manual or if you need to change it to the kind of light you are using.
Dec 31, 2007 | Optimus DV-3040 Flash Media Camcorder
ASUS VivoBook X202E-CT033H Touch Laptop, 1 Yr Int. Warranty Black Logo
106 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
