Question about Ovens
I have a Rosieres 2040 DB and the left convection oven element won't turn on
This is a double oven. The left side convection oven has a fan and one heating element at the top. The fan turns on and the heating element comes on when I turn the dial to broil. Do you think it could be the switch that the dial turns?
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: GE oven will bake but not broil
I trhink more than likely you have a faulty element, you need to test wether you have power to the element with a voltage tester or meter
Posted on Nov 22, 2008
scottowa
  • 87 Answers
SOURCE: Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Posted on Mar 04, 2009
EllaWatson25
  • 725 Answers
SOURCE: Maytag electric range, cre9530. bottom bake element
This is probably your bake element that is out and this is a very simple repair to make.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct element out to you asap as well as part removal/installation instructions.
We hope to get you cooking aain real soon. Ella
Posted on Nov 13, 2009
ginko
  • 19396 Answers
SOURCE: The grill element of my
Hi.
When the element comes on all the time, that often means that the element is 'plugged', and that there is a contact keeping the element circuit hot even when it should not be hot. In some case the problem may be the control, but first you must check if there is a contact.
The test is done using a multimeter set on impedance. The multimeter reads impedance at element contacts on control board after disconnecting the contacts from board. If there is continuity between element wiring and ground, then the element is plugged. In that case check for points of contact, if you do not find any, then replace element wiring harness. Doing the repair job yourself is reccomended only if you are a trained tech or an experienced DIYer. Disconnect power before performing any test.
If there is no contact , then the problem is the control. Most new ranges use electronic control that is rather difficult to test with power off (for safety reasons I never suggest reading voltages to the owner).
To get the parts and diagrams try the websites below (mainly US models) or call the manufacturer at the number listed on the owmers manual.
try websites here to get parts and diagrams
Posted on Oct 18, 2010
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
May 23, 2010 | AEG U3100-4 Electric Double Oven
Neff u1421 bottom oven: Either fan works but no
You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
Please rate my solution.
Thanks.
Oct 24, 2009 | Neff U1421 Double circotherm Electric Oven
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
I'm looking for the reference of the fan oven element for Rosieres F142FA 4039343280 oven. Thanks
Dec 02, 2008 | Ovens
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Dec 10, 2006 | Bosch HBL 455 Stainless Steel Electric...
Ovens Logo
75 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
