Electrolux EIDW6105GW 24 in. Built-in Dishwasher Logo
A
Anonymous Posted on Apr 25, 2013
ALL CONTROL PANEL LIGHTS ARE FLASHING
I have a Fisher&Paykal DD6031 drawer dishwasher. Stopped running mid cycle. Lights flashing on drawer front green,red,yellow,red green,red,yellow . I don't know what that code means. On the inside Heavy...
follow this steps and fix it. GOD BLESS YOU
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
1helpful
I have a electrolux eidw6105 all lights are flashing and the led panel has the wash pump light on what does this mean
very important! the machine must be perfectly level or slightly tilted higher in the front . If not the leak detector function will engage and the machine will not operate. Try raising the adjustable feet behind the kick plate.The machie may reset without removing it.
1helpful
The touch control pannel on my eletrolux dishwasher will not respond and seems stuck, will not start, will not beep
Have you got any indication of error codes in the display if not check the child safety lock is not set or the disable of display is not set.I guess you have a manual it gives all the error codes in this.
Hope this helps.
2helpful
Our 4300 series frigidaire dishwasher has all the lights flashing on the front panel tried resetting power but did not hel[
sounds like its the p c control . it will need to be replaced . less expensive than most. ( inside the contrl panel is a tec sheet and it will tell you what the flashing is caused from ..ck the beeping for a code like dot dot --pause or 3 dots and a pause . this control has codes .. mm
9helpful
2answers
Maytag Dishwasher
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Dishwasher lights are all flashing
If you do have the Touch Control Electronic Pad, then you do have a problem, moisture related. You need to open the panel, use a Hairdryer to dry the panel properly and replace. This sorts many of these Touch Control Electronic Pad.
5helpful
3answers
Flashing LEDs
When doing some floor work, I had taken off the front bottom panel of the dishwasher and there was a pamphlet which had electronic information. Dummy me threw it away, but I remember it had code information on it. I am now having this flashing light problem. So check behind the front bottom panel (remove the 4 screws to get behind it) and the piece of paper should be in there. Please let me know if you find it!
Top Electrolux Dishwashers Experts
Mike Cairns
Mike Cairns
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
