Question about Toys
On a 1949 ford 8n, do you set the gap on the bottom of the lobe or the highpoint of the lobe?
    Sergeant:
  • 311 Answers
The MOST gap at the high point of the "BUMP" of the lobe should be the most that the points will open.
.016 " Be sure the points CLOSE,also.
Posted on May 11, 2013
What year is an 8n Ford tractor serial # 202715?
complete list
http://ford8n.com/ford-tractor-serial-numbers.html
Ford 8N Tractors series Serial Numbers
Apr 06, 2015 | Ford Toys
What is the point gap for a 1948 8n ford tractor
The ignition point gap is 0.015" and the spark plug gap is 0.025". More specs here:
http://www.tractordata.com/farm-tractors/000/2/2/223-ford-8n-engine.html
Jun 08, 2014 | Ford 8N Tractor
What is the point gap for ford 8n
The point gap on the 8N is 0.015".
May 14, 2014 | Ford 8N Tractor
What is the point gap ford 8n
.015 for 2N, 8N & 9N
The 8N also had problems with ignition switch causing several troubles, cheap and easy to replace....Below link is an excellent site.
http://www.yesterdaystractors.com/atrp/specs/ford.htm
What is the point gap on a 1949 8n tractor
015 to 019 - start at 017 and see how it runs.
Apr 25, 2013 | Garden
Points gap for 1953 8 n ford tractor
Here's how to do it:
http://www.ehow.com/how_7368031_set-points-ford-8n.html
set the point gap a .025
Jan 13, 2013 | Ford 8N Tractor
NOT GETTING ANY FIRE TO PLUGS. TRIED TO CHECK THE
I just had to do the same. I removed grill and hood. Disconnect upper radiator hose. Remove radiator mounting bolt under left side (as you're looking at the front) and loosen the right mounting bolt. Radiator swings to the right to allow access to the distributor and coil. Lower radiator hose can stay connected as long as it will fold on itself without damaging. Remove the coil and distributor cap. Check to see that the rotor turns when cranking the engine over, to eliminate that potential firing problem. Then remove the whole distributor to replace points and condensor. It's a lot easier. Be sure to check gapping on all four lobes.
Jun 03, 2010 | Ford 8N Tractor
My 1949 8N Ford tractor, the starter just spins
My thought is you need a new "bendix" for lack of a better word. The device I speak of spins out and connects with the flywheel. There is the possibility you have electric problems but based on what you say, I think it is mechanical.
Thanks for posting your question at FixYa.com
Pleae vote
thank you
a
Nov 09, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Have new plugs, wires, cap, coil, rotor points, condensor. Still no spark
Check for power getting to the center top connection at the coil.
Are the points opening?
Are they fully closing?
Check for a grounded connection/wire in the dist?
Be very careful how you set the coil onto the dist.
Jul 12, 2009 | Ford 8N Tractor
Toys Logo
109 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
