Computer crash. cannot pass welcome screen
Computer stalls everytime. why?
    Brigadier General:
  • 3,400 Answers
Mrteacher601. try to run a checkdisk.or start repair. if you have cd put it in cd writer/player let windows start load files choose to repair windows try start repair.can take same time can also fail in that case run chekdisk from command prompt.write.C:\ CHKDSK /F/R if no cd you have to tap you into safe mode.tap once a second on F8,F10 OR DEL .depends on manufacturer can a other.start tap then windows start boot.run checkdisk from safe mode write in the command prompt as early.write cmd in searchbox.
Posted on Apr 25, 2013
  • 27,725 Answers
There could be a number of possible reasons why your computer is crashing.
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Testing & replacing the PC's power supply
http://www.youtube.com/watch?v=hbNxhvm0czs
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty although very rare for sata lead to fail
Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
I've tried backing up my computer ...but I get a message everytime Error: back up failed. What can I do before my computer crashes?
Don't use the pre installed backup software, just grab an external HDD or a second internal HDD and do it manually.
Jan 29, 2012 | E-Machines eMachines Desktop PC
My dell 1501 is crashing constantly with usually a striped screen. I updated the bios and the problem is not OS related because I did the PSA test which the computer passed and while doing the extended...
i would center your fault finding around the gpu as that is a classic symptom of a graphics malfunction, if it was the lead or screen the computer would still respond , the fact its not suggests, to me , that your gpu is overheating or has a short
Mar 27, 2011 | Dell Inspiron 1501 Notebook
Firefox crashes everytime I try to start it, last time it worked without an issue was Friday, October 23. When I turned on my computer the next morning, Firefox will not start. It crashes everytime.
hi this is john,
i always face this problem my dear so i follow these instruction which i m sending u that particular link which will help u alot..
http://support.mozilla.com/en-US/kb/Firefox+crashes
follow this link and get ur problem solved
regards
john
Oct 25, 2009 | Mozilla Firefox
My hp 2000 will not go past the welcome screen
Try pressing F8 on bootup and starting in Safe Mode. If it will go into safe mode, run Chkdsk /r /v at a command prompt. You might be able to recover from this.
Aug 05, 2009 | Dell Latitude D600 Notebook
Computer comes on, shows a blue screen, and restarts on it's own.
Try to boot into Safe Mode.
If you're able to, let me know and we'll go from there.
Jun 17, 2009 | HP Compaq Presario 2223US Notebook
Creative zen
dpwnload the disc onto your computer then it might work.
Sep 11, 2008 | Creative Labs Zen Digital Media Player
Computer Crashed!!!
Format it and start again,
hope you saved your important stuff ,
if not take your drive out and plug into another machine ,
now using the other machine to sort out your stuff for saving,
Save and then format the drive thru device manager .
Select the Drive from your computer while your in Device Manager.
Right click on your Drive (drop down appears)
A Quick format seems to take a short period off time.approx 10min(depends on hard drives size)and its ready for use straight away.
Plug it back into your original computer and it should be happy as again.lol
Hope this helps, let me know out come thanks
Jul 15, 2008 | Sony VAIO VGN-N130G/W Notebook
By-pass windows' screensaver password
i try to understand what you want to do ? resetting windows user account password or just screensaver password which one ?
Mar 21, 2008 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
