Question about Kenmore Elite 45986 Front Load Washer
44921300 elite kenmore owner manuals
Nothing on on panel wont beep or do anything checked power got 110 going in and out dont no where to check from there
    President:
  • Kenmore Master
  • 662 Answers
Http://downloadfreemanuals.com/kenmore-washer-manual/
Posted on Apr 26, 2013
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite HE3t
Here's a link that explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
Read through these steps and let me know if you require further assistance. HINT: I'm assuming you have water entering the wash tub since you mentioned the washer will begin a wash cycle. Check for a siphoning issue or Drain Pump problem first. These are the simplest items to check. I hope this helps you.
PS There should be a tech sheet located inside you washer behind the lower panel under the door, or along the interior cabinet wall that explains all the error codes and how to troubleshoot. This may also assist you further.
Posted on Jul 25, 2008
  • 1028 Answers
SOURCE: Kenmore HE2 Elite is making groaning noises and then error messages 5D and/or F
did you clean pump out by removing acess port on front end of pump? also you can ckd pump impeller by removing screws around pump body impeller will free wheel but should have some resistance to turning by hand if no water in tub reinstall pump put in drain spin to see if drum will spin if it does forget main motor ..motor is most reliable par on those washers
Posted on Aug 07, 2008
SearsTechToo
  • 261 Answers
SOURCE: Kenmore Oasis Elite---110-27086601
This error only shows in diagnostic mode, with power off choose any buttons except stop and power, press in intervals 5 seconds on and 5 seconds off until 88 appears and all light light up. If the user panel is faulted F 2 will flash in the display, press the same button you used to start diagnostics to jump to the next error code and once through 88 will flash and diagnostics will start. Sometimes once F2 flashes and the machine has not been repaired it will stick at that mode.
Posted on Sep 12, 2008
docjohn174
  • 943 Answers
SOURCE: kenmore top load washer 110
hi thanks for the question i would check the lid switch very common for that make thanks the appliance doc
Posted on Sep 27, 2008
  • 10 Answers
SOURCE: Kenmore Elite HE3T model 110 44932 200
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Posted on Jul 23, 2010
Kenmore elite he14. What is the f14 error?
EEPROM Error
The Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU.
If there is an error reading this data, it will cuse this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 18, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite model 16582200 built in
Item #959376(fuse) will need to be replaced.
Unplug the dishwasher.
Remove the 6 screws holding the control panel on.
The fuse is on the top right side of the control panel. It has 2 wires going to it,usually black and white.
Remove the wires and check the fuse with a meter set for continuity. No continuity is a bad fuse.
If the fuse checks OK use the meter on the micro door switch found under the door latch.
Remove the wires to the switch,touch the meter leads to the 2 terminals and manually push the switch button in. If no reading on the meter the door switch is bad..
Jan 01, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
KENMORE MODEL 110 WASHER WONT DO ANYTHING, JUST DEAD
you need to make sure you have power comeing out of your wall socket first. then let me know. also is any of your lights on your display lite up?????? control lock?????
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 7.0 HE4 lights flash, won't start
Hi! debby1114 and sydver
I can imagine why several people are have similar problem, lets start with the basics and check the voltage at the wall recepticle. If this is the HE4 units made by Whirlpool for Kenmore, the first three digits of the model number could be 110. Let me know if you have had the power at the wall checked, and the breaker. This looks like a power problem to me.
Aug 09, 2008 | Kenmore Elite HE4 Electric Dryer
Need manuals
What problem are you having, the problems i have seen with kenmore elites are below.
1. when you press start and release dryer shuts off
for this problem, change the board in the console
2. not producing heat
for this problem, check to see if 220 is getting to element, check to see if you are getting 220 from outlet, check your thermal cutoff on heating housing, check your heater relay which is located in top console.
Apr 02, 2008 | Kenmore 63942 Dryer
KENMORE ELITE MODLE 110 20082 992
We have the 11020092991, same washer. Ours has had all kinds of problems. We kept renewing our extended warranty and finally in August 2007, Sears concurred and called it a lemon and gave us credit for a new washer.
Mar 31, 2007 | Kenmore 20092
Kenmore Elite 45986 Front Load Washer Logo
177 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
