Question about Boating
Replace Impeller How - Boating
  • 56 Answers
First we need to know what motor you have. The replacement should be fairly easy. You can find replacement impellers on iboats.com.
Posted on Apr 26, 2013
How to replace plastic impeller with brass(metal) impeller
I called Lowes then Utilitech and they sent me a new impeller. There were no instructions about how far to thread the impeller onto the post. I am going back in to thread it all the way to the top. I wish I had requested a brass impeller.
May 21, 2014 | Utilitech 1-1/2 HP Irrigation Pump UTP15P1
I am looking for a kinki waterpump on yanmar diesel engine
Which kind of kinki impeller you need?We have the KINKI BK-0132 and BK-0134
Flexible Rubber Impellers replace KINKI impeller BK 0132 BK0132 Neoprene Flexible Rubber Impellers replace Kinki Impeller BK 0134 Neoprene
I hope which can help you:-)
Best regards from Vera
Flexible Rubber Impellers Mfg Co.,LTD
No.285 Yunshan Rd,National Hi-Tech zone
Ningbo 315040,China
Tel:+86-574-66850926
Fax:+86-574-66850926
Email:sales@flexible-impeller.com
http://www.flexible-impeller.com
Aug 27, 2011 | Computers & Internet
I have a proline 1.5hp pump need to replace the shaft seal. I can't seem to get the plastic impeller off. We use a screwdriver to hold the shaft screw and try to turn the impeller counter clockwise...
Keep trying - It is stuck and will likely break but you have to remove it to change the seal. It is not uncommon to need to replace the impeller when the seal fails since the water gets behind the impeller shaft and rusts the metal causing the impeller to bind. If you still cannot get it free pull the motor thru-bolts and lock the rotor once removed from the motor in a vice. Use a large pair of channel locks to break the impeller free...replace it if necessary.
John
May 15, 2011 | Waterway 1.5hp Hi Flo Above Ground Pool...
How to replace impeller on evinrude 115
disconnect the lower unit from the power head . makeing sure where the shift rod position is . then you will be getting near the water pump impeller .if you get it wrong the shifting won't work
Apr 24, 2010 | Boating
My Hayward just hums when I turn it on and after a few seconds the breaker pops.
You will need to disassemble the pump and check the impeller. remove any debris and try turning the impeller by hand. If it does not move or is dragging, you will need to overhaul the pump. Possibly a shaft seal leak has damaged the motor bearing(s). Replace the shaft seal and motor bearings. If the motor is badly deteriorated, you might need to replace the motor. Note... the impeller turns counterclockwise to loosen. you may need special tools to grip and hold the motor shaft and the impeller to prevent damage to the impeller. If the impeller is seized on the shaft from rust, you may have to break it to get it off. reassemble with teflon lubricant on the shaft threads when reinstalling the impeller. This will prevent seizure later.
Apr 10, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
I need to replace the motor, but I can't figure out how to remove the blower fan.
This is usually a job for an appliance service company. However, the exhaust blower impeller is typically screwed on to the motor shaft. You will need to wear gloves and get a tight hand grip on the impeller, while using a wrench to unscrew the impeller at the motor. The impeller can be screwed on so tight at the manufacturer that, occassionally, it is necessary to chisel or break the impeller into pieces, and then replace it with a new one!
Feb 22, 2010 | Kenmore Dryers
I want to replace an impeller for a Little Giant submersible pump
This is a plastic impeller on a brass hub. If the impeller is loose it is probally cracked or overheated and melted, ether way you will have to break the impeller off of the hub then you will need to break hub loose from shaft. You can do this by putting pump in a vise and putting a pair of vice grips on hub and giveing them a sharp hit in a counter clockwise direction. you will need to replace the seal and impeller and should check to be sure than you can get these parts before you start.
Aug 24, 2009 | Little Giant Submersible Fountain Pump
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
