Question about Blenders
Blade of an Oster 2609 hand blender has gone loose. Is there any way to fix it?
The motor is fine. The whole unit works for a few seconds, but then the blade falls about half an inch and it stops spinning since it's no longer attached to the motor. When I took it apart, I found a loose little rusted washer in the lower half of the device, where the blade is. I can provide pictures if necessary. Is there any hope for this thing?
SOURCE: Blade not turning
I am looking at the same problem, the aluminum bottom part (on blade assembly) that contacts the black rubber on the motor part is no longer "attached" to shaft that drives the blade on top side. So like said the top and bottom "turn freely" but independent of each other.... not good, they should be one piece. Ebay does not have a replacement for this original part in my case and would have to buy a complete jar assembly. I will attempt to fix the original one by cutting a slot through aluminum and center shaft and dropping in a pin to make them turn together, with a spot of weld to hold pin to shaft... not sure how long this will last.... unless somene has a better idea to fix it?
Posted on Oct 29, 2008
  • 10865 Answers
SOURCE: Need replacement blade for Russell Hobbs hand mixer
go to this page http://www.russell-hobbs.com/parts.shtml and order what you need directly from Russel Hobbs.
Please mark this answer as a fixya! thanks
Posted on Mar 18, 2009
falter
  • 245 Answers
SOURCE: Krups blender blade stops
well it looks to me there is some thing not tight enough connection to ur blade.....as u say it works when empty but when u put soemting in its stops....this means ur blade is not tight on the shaft to the motor......or u may have done something wrong when u had the blender open........recheck ur work and make sure its tight,,,,,
if so u will have ur ice cold drink....cheers i hope so for ur shake
Posted on Jul 03, 2009
  • 145 Answers
SOURCE: unit seems to work fine, but when the pitcher is
Depending on the age of your blender, a new blade assembly may be available. I would recommend calling Kitchenaid Customer Service for pricing. Their toll-free telephone number is:
1.800.541.6390
Posted on Jul 28, 2009
SOURCE: A blade on my immersion blender was bent slightly.
If you have a model with the detachable blades. Otherwise, you'd need to purchase the blending rod from www.wpcookware.com.
Posted on Mar 17, 2010
How to fix the blender,the motor works ok but the blades don't move
check to make sure the drive stud is spinning with the motor. If it is, make sure the blade assembly is lining up correctly as well as fitting tight on the drive stud. How to Repair Blender How to Repair Small Appliances Tips and Guidelines
Dec 09, 2014 | Oster Blenders
Oster makes a high-itch whining sound
Sounds like the bearing for the blade on the bottom of the pitcher may be in need of replacement.
Aug 13, 2017 | Oster 4094 Designer Classic Beehive Work...
I have an oster My Blend with the blade stuck in the base. Any ideas on how to get it out? Model BLSTPB-WBL
None of these people understand your question. The blade assembly is stuck in the blender base and will not untwist out of the base. The sport bottle untwists off the blade assembly leaving it in the blender base. I've tried using pliers on mine after taking it apart. Something is binding it from untwisting. What is the trick to untwist the blade assembly off the blender base?
Jul 23, 2012 | Oster Blenders
Blender does not blend, only buzzes. So I took the blender jar off the motor base and tried running it. It ran just fine. Put the jar back on the base and it only buzzed. Figured a piece of frozen fruit...
Smart move. The blade assembly is almost frozen and the motor does not have enough torque.. You need to remove the blade assembly and completely clean out the bearing and reassemble after the Mr. clean operation. A lite dab of oil is also called for.
Sep 10, 2017 | Oster 006832000000 10Speed Blender
Motor base is working and container jar base turns by hand but won't work together to spin blades
Just fixed my blender. Motor was working fine, but the bladea wouldn't turn. I removed the blade piece from the base and tried moving the blades by hand and they wouldn't turn. So, I lubricated the blade at the location where it's supposed to rotate. I kept trying to move the blades by hand and gradually they started to loosen up. All fixed!!! I guess they get stuck after a few years of use.
Aug 13, 2010 | Back to Basics Smoothie Elite Work Top...
Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
Connection between the motor and the blender unit (where the spinning takes place) - get extremely hot and blender does not seem to blend well. Motor works fine without the top - and the top seems to spin...
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Jul 15, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
Replacing the part that connects the motor to the blades on an Oster blender
I don't know if this will help or if this is what you are looking for. But today I was searching the web for the bottom piece that fits on the jar and saw this website has a lot of replacement parts for Oster blenders. Hope this is what you're looking for.
Good Luck
http://www.goodmans.net/get_item_os-070_square-drive-pin-for-oster-osterizer-blenders-shor.htm
Sep 12, 2008 | Oster 6803 14 Speed Blender
Open Questions:
Blenders Logo
235 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
