Question about Fuji FinePix S602 Pro Digital Camera
Green Hue on taking a picture
I have just switched on my finepix s602 pro after having it switched off for a few months. I now have a green streaky hue on my LCD Display and when viewing the picture taken.Any help would be appreciated. Thanks in Advance. Tim
    Genius:
  • 2,985 Answers
Failing CCD Fuji customer support for best advice
Posted on Aug 05, 2007
SOURCE:
My s7000 batterries do not last very long i am wondering if something is draining them down
PRESS RELEASE
Release Date: 12 January 2004
Fujifilm today announced that a number of early FinePix S7000 Zoom digital cameras may experience battery power depletion when used with some CompactFlash™ memory cards.
This fault does not occur when the S7000 is used with either an xD-Picture Card™ or a Microdrive™, nor does it occur in any other Fujifilm products that offer a CompactFlash™ storage facility, such as the FinePix S2 Pro, S602, S602 Pro or M603.
Cameras with serial numbers above 34L60001 (inclusive) were produced after 15 December 2003 and therefore will definitely not experience this battery drain problem.
In the short term, the problem can be avoided by unloading then re-loading the batteries just after the camera is switched off. The camera's power supply will then perform normally.
Mar 03, 2011 | Fuji FinePix S7000 Digital Camera
Pink hue to picture
Pink hue picture denotes the absence of green colour. Check the green video output transistor for open. It can be easly recogansized by taking the voltage at the collector point of that transistor. It will be high, almost equal to its supply voltage. Measure the base voltage of that transistor also. If there is no base voltage the symtom occurs. if it is so trace the track and reach to the green output pin of the related ic. If there is also no voltage, Ic may be fault. on the otherhand check the green cathode of the CRT is ok. It is quite easy. Detach all the components related to that pin, or make a temporary cut to isolate the green cathode. The switch on the set. If a green colour [High intensity] perists, the CRT is ok. You can check it in an other way. Take a 2W resistor fo value 470k or more, connect its one end to earth point, and other to the green cathode pin [Just Touch and Out], a green screen will flash on the screen. If these to checks fails, CRT is faulty.
Oct 14, 2010 | Toshiba 36HF71 36" TV
Blurry, streaky, purplish to white to green is camera "dead"?
If you have tried cleaning the internal working parts of the camera, and have tried a different lens and still have the problem, then you have two choices. Take it to a Photo Repair shop or trash it. My first choice would be to get it repaired if possible
May 17, 2010 | Fuji FinePix S5000 Digital Camera
Purple and green vertical lines on pictures, fujifilm finepix z
Check to see if the Fuji website has any downloads or updates for your camera.
Aug 12, 2009 | Agfa FUJIFILM FINEPIX Z33WP Digital Camera
Pictures come out grainy with blue green hue and streaks
You'r right - probably pointless (I assume it's off warranty).
Apr 18, 2009 | Kodak EasyShare C533 Digital Camera
Wont take pictures
A manufacturing fault- contact the Fuji support line for instruction to return the camera for replacement
Aug 26, 2008 | Fuji FinePix F401 Digital Camera
Green hue on all inputs
Most likely there is a failure in the video processing. The flickering was from the failing components breaking down.
Your set can be serviced by an experienced tech who has spare boards and the facilities to service your set.
Jerry G.
May 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
Color convergance
The green hue (I had it too) is a result of the optical block failing.
Sony has extended their warranty (regardless of the purchase date). see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=KDSR60XBR1&news_id=185
Apr 24, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Blurred Screen
An internal component failure- may be a reapair job Check Fuji Tech Support Team
May 23, 2007 | Fuji FinePix S602 Zoom Digital Camera
Fuji FinePix S602 Pro Digital Camera Logo
105 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
