Question about Epson Stylus® R200 InkJet Photo Printer
Encryption code Are Epson DX5 printheads using some sort of encoding now so you can' pull a print head from one printer and put in another printer? If so how do you get around this? Thanks
  • 15 Answers
SOURCE: epson cx2900 3 in 1 printer
the problem might be the ink, change the cartridge maybe the ink dried out....
Posted on Sep 18, 2007
Tirzo
  • 94 Answers
SOURCE: Epson 1280 Will Not Take Paper through to print?
Follow the instructions below in an attempt to resolve the issue you are experiencing.
1) Turn off the printer and remove all paper from the paper tray.
2) With the printer off, check for any obstructions such as torn paper or foreign objects.
3) Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
4) Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
5) Attempt printing.
Posted on Jun 10, 2008
SOURCE: epson r290 printer no printing now
how to install and R290 printer & print
Posted on Jun 13, 2009
  • 3 Answers
SOURCE: I have 2 Epson R230. One has a bad printhead, in
Befory you toss the printer, try this!
Take a syringe, 1" piece of rubber tubbing that will fit over the head input snugly, (auto parts house stocks some that works fine). Fill the syringe with a good head cleaner, slightly warm it in the microwave (try 5 seconds to start). Attach to nozzle, gently pull back just a bit, then apply a little pressure. If it accepts the fluid, STOP, You can clean the syringe, add the proper color ink, inject just a small amount. reinstall a known good cartridge, clean heads couple times checking results, if ANY streaks or color appears, clean again! Sometimes letting it sit overnight allows the head to fill with ink. I have had very good luck with this method, also some will not clean properly, just depends on how bad it is clogged.
Good luck..
Posted on Sep 21, 2009
SOURCE: HP officejet Pro L7580 print head is not working properly.
i order the 8 jan 2010 2 print heads No : 88 (ref hp c9381a for black/yellow and ref hp c9382a for magenta/cyan) and i receive it after 4 days.
Posted on Jan 15, 2010
Epson xp 305 help
It's quite likely that at some point in time you will have attempted to print in black only to receive an error message that you cannot print until a colour cartridge is replaced.
"If ink is not in the tubes from the head to the cartridge, air will be sucked in and therefore cause damage to the print head. This is because the nozzles are in the print head and not in the cartridge. "
What Epson are basically saying is... if this safeguard was not in place, and you sent a print request for black when a colour cartridge was empty, there is a risk of air being pulled into the printhead. This air will ruin the vacuum effect needed for the printhead to pull ink in, meaning your printhead would be at risk of never printing again.
Additionally, if any air is allowed go get into the aformentioned tubes from the head to the cartridge, any remaining ink will coagulate. Just in case you're not a scientist - coagulation in a tube/cartridge is bad, and will lead to you not being able to print again with that cartridge, or to a blocked nozzle/printhead which will require a significant amount of cleaning cycles to budge.
Aug 08, 2014 | Epson Expression XP-305 Inkjet...
Fresh ink cartridges won't print at all.
First visit our Epson support page to ensure you covered : http://inkjet411.com/?page_id=1939
Since the Epson PRINTHEAD is not removable, then it is suggested you take a damp cloth and repeatedly blot/saturate the respective color ink port with water (distilled water is recommended):
1. Remove suspect ink cartridge (or cartridges).
2. Place a paper towel under the PRINTHEAD assembly.
3. You'll see a round mesh ink port where ink flows into the PRINTHEAD.
4. Thoroughly dampen the ink port with 0.5 to 1 teaspoon of distilled water (use an eye-dropper or similar, pour or drip directly into ink port).
5. Reinstall ink cartridge(s).
6. Activate the 'Clean Printhead' routine once or twice to see if the respective color(s) have recovered.
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Jun 12, 2013 | Epson Artisan 837
Phaser 8560 error code after moving printer. Error- 09,005,40:8407
The 7,010.43 error code indicates the printer is having difficulty tilting the printhead forward from the parked position to the print position. There are several printer systems involved in tilting the printhead so troubleshooting the error can be challenging. The printer does not directly sense the printhead's tilting position. Instead it applies drive current to the process drive motor, and monitors the motion of the motor's rotation encoder for "following error". For a particular drive voltage the encoder should rotate at a particular rate as the printhead (driven thru the process drive, the DM camshaft, and the head tilt gear train) tilts forward. If the printer does not see the expected encoder readings it assumes a tilt failure.
for more hrlp visit CBR Tech Solutions
Sep 30, 2012 | Xerox Phaser 8560N Laser Printer
Epson SX110 printer does not print
I assume from your description that the printer is going through the motions of printing but not putting ink from one or more colours to paper. If this is the case please it is likely that the printhead has developed a slight blockage or ceased to function.
-Print a nozzle check from your printers software. This will show you clearly which colours are not printing correctly.
-Run 1-3 head cleans using the printers software with a nozzle check after each one.
-If this doesn't resolve the issue it is possible you simply have a defective cartridge and I would recommend replacing it and trying again.
-If this doesn't help or the problem is across all colours it is likely the printhead is severely dried or has reached the end of its life. So I would either take it to an Epson service center or if the printer is not worth the expense you just keep running head cleans (with 5-10 minute gaps between cleans).
Hope this helps.
Sep 08, 2012 | Epson Office Equipment & Supplies
Error code sc200 on a ricoh afcio mp c1500
Mar 30, 2012 | Ricoh Aficio Office Equipment & Supplies
Epson 1400 stopped printing after syringe windex method. There was cleaner flowing through great, but now no color prints even after 5 cleaning cycles. . . Im now running out of ink! How do I remove the...
This is the only advice I can give you. Try this forum below. It has alot of good information, for the questions you're asking. If you find this helpful, pls rate me. thanks
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
Thanks and Good Luck :0)
Mar 03, 2010 | Epson Stylus 1400 InkJet Photo Printer
Epson 4800 pro
Make sure that the "Encoder Strip" is clean and in the channel for the sensor located on the back side of the printhead carriage.
Jan 06, 2009 | Epson Stylus Pro 4800 InkJet Printer
My Epson Stylus CX5400 won't print.
hii,
u printhead block..that why cannot ink cant not get trough from the print head..or try clean the print head using printer properties under maintenain .for informations epson print head are sensetif..
Oct 25, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Dfx 8000 not printing
Check the printhead guide bar for proper lubrication- light oil similiar to 3 in 1 will work. Check for any printhead cabling catching on something as the printhead moves back and forth. If error beeps are occuring immediately after turn on, and unit will not print, this might indicate a sensor problem, such as paper sensor, head home position sensor or another error condition of some sort.
Apr 07, 2007 | Epson DFX-8000 Matrix Printer
Epson Stylus® R200 InkJet Photo Printer Logo
74 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
