Question about Sharp Mx-3501n Color Copier Printer Scanner
My printer ran out of staples and I need instructions on how to load more staples in it
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Sharp Expert
  • 106 Answers
The staples are specific to your copier. You can purchase them from Skelton Business Equipment 281-351-5128.
Here is a video on how to install staples into your copier.
How to Replace Staples in Sharp multifunctional printer internal...
Posted on Jul 28, 2014
Where do you load staples into a Canon imageRunner 3245i?
That would depend on the model of finisher you have attached to the machine. If it is a larger finisher attached to the side of the machine open the Sorters front cover and the inner door should have a sticker with instructions. If you have an internal finisher it can be the same concept open cover and load the staples as show on the cover. There is also another internal finisher where a gray handle is pulled to slide the finisher out and the staples load into the upper rear area of the finisher.
Mar 05, 2012 | Canon Office Equipment & Supplies
I need instructions on how to refill the Arrow T50 Staple Gun. I have the stapler and ran out of staples. I can't get the staples into the track.
remove the spring loaded magazine from bottom rear of unit by pushing down on piece about two inches below curve section of rear end of handle push down gently and pull to rear staples go in front ofin same slot from which this magazine is removed load normally two clips if your dead empty when you return the spring follower back into place it follows the staples if if doesnt go all the way in you probably have to many remove some good luckd
Mar 23, 2011 | Arrow T50 Staple Gun Tacker
Canon Imagerunner 3035. refilled staples, but copier thinks empty
frst: did you set the staples according to the instructions?
second: try the few times remove and insert staple cartridge in and out, until you heare the loading clicks.
third: check the staple holder for damadges or residuals of staples.
Jul 31, 2010 | Canon imageRUNNER 3035 Black and White...
Need instructions to load staples in Canon imagerunner 2270
pull the finisher out
you will see the staple in the end of it
pull up the staple cartridge using the green handle
then insert the new one
Apr 06, 2010 | Canon imageRUNNER 2270 Copier
My wife tried to print on T-Shirt tranfers meant for ink-jet printers, and they melted onto the fuser roll, and it stinks. I need to remove the fuser assembly and clean it, but could use some instructions....
This might help. I did the same thing with my laserjet printer.
Staples has laserjet cleaning sheets. I ran several sheets through the printer after I pulled most of the transfer paper out.
The sheets are one use sheets so, you will need a few.They are impregnated with cleaning fluid on textured paper.
These sheets clean the entire paper travel path.
Dec 12, 2009 | Brother MFC-7820N Laser Printer
How to load staples in canon imagerunner 3300 copier
Does your copier have the finisher or saddle to have staples? There should be instructions in the user manuals for replacing staples. If you don't have the user manuals, I'd ask Canon to purchase replacement copies or look on the web.
Nov 23, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
How do I load staples into the Minolta Di 2010f copier?
Follow instruction on door. Push in on both sides of staple cart pull the top up install the new staple pack dont pull string on staple pack until its inside. (Staples on the floor:)) Don't throw away the plastic cart itself insure the arrows on the new staple pack match the direction on the old run or the staples will be upside down and not able to get out of the pack
Aug 17, 2009 | Minolta DI-2010F Copier
Sharp Mx-3501n Color Copier Printer Scanner Logo
65 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
