Question about Toshiba 53H71 53 in. Rear Projection Television
Blue arc There is a blue arc at the bottom of the screen that also creates a shadow. What causes this and can I fix it?
  • 398 Answers
There are 2 large convergence IC's and the one that handles Blue Vertical (BV) has burned out and needs to be replaced. This is by far the most common failure in those projection sets. It is a good idea to go ahead and replace both STK392-110 IC's with the newer improved STK392-150's. If you have never replaced convergence IC's and realigned convergence circuits then have a qualified tech handle it for you.
Posted on Aug 07, 2007
SOURCE:
My computer keeps going to the blue screen showing the message 0x0000001e,oxffffffc05,0xfffff80003dcd7da,0x000000000000000001, 0x0000000000000018, bios update, disable bio memory such as caching or...
Maybe you can try the following solution... Blue screens are typically caused by software errors in device drivers: in Windows systems by poorly written device drive , They can also be caused by physical hardware faults, such as faulty RAM memory or power supplies, overheating of components, or hardware which is run beyond its specification limits . On the other hand, registry damage,corrupted program and viruses are the major causes of computer blue screen,too. They can make our computer run into blue screen error and prevent us from working, studying or playing games online. Now, let's learn to fix blue screen error as follow steps together. You will find how easy it is to solve the problem.
Step 1.Burn a bootable CD/USB by Fix Genius for fixing blue screen error.
Step2.Change BIOS of the computer to boot from CDROM or USB Device Drive.
Step3.Fix blue screen of death with the created CD or USB easily.
Computer blue screen exists in kinds of windows system, and the solution is available for windows 7 blue screen, xp blue screen, vista blue screen and even windows 8 blue screen, etc. Laptop blue screen seems more likely to occur as its insufficient configurations. But it isn't real and if we can keep using our computer in a good way, they can both be health. After,blue screen of death is no longer a horrible disaster when it occurs to us, just use the methods above and we can solve the problem soon.
Nov 10, 2012 | LG AKB72915206 REMOTE CONTROL
Blue shadows and a yellow and blue arc acroos the bottom of the screen
Tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Pioneer SD-582HD5 58" Rear Projection...
My mitsubshi vs 50609 has blue shadows how can this be fixed
you might need to adjust Blue drive on screen control to Blue tube.you have a focus and screen control box 3on top 3 on bottom of it 3 on top adjust focus to each tube R/G/B and 3 on bottom adjust screen drives.
Nov 12, 2009 | Televison & Video
Blue shadowing on our 7 year old Sony Grand Wega KDF-60XBR950
YOU NEED SOME CONVERGENCE IC THIS REPAIR MY COST U ABOUT 200-300 PLUS SERVICE CALL
Aug 24, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Everything on the screen has a blue shadow
need to change both convergence ICs STK392-560. you can get replacements at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | Sony KP-46WT500 46" Rear Projection...
43fdx01b arc at top of screen
Usually this means convergence ic's have to be replaced and possibly a few resistors on small convergence board. Sometimes it requires digital alignment after new parts are soldered in. This repair can cost 175.00-375.00.
Apr 20, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Blue color is out of position
sure sounds like convergance problem
http://www.partstore.com/Part/Samsung/
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Jan 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Help
your having convergence circuit problems, you`ll need to change the convergence IC`s and any burnt resistors in the convergence circuit, if you have questions e-mail me back, good luck, BMW Rider
Jan 03, 2008 | Toshiba 53HX71 53" Rear Projection...
Toshiba 50H82 blue arcing?
color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Dec 18, 2007 | Toshiba 50H82 50" Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
54 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
