Question about Tsunami Car Audio & Video
Signs of a blowed 15 inch subwoofer
Does not put out any sound
Melted voice coil? Short circuited voice coil due to overload? does your amplifier work properly? Is the (-) properly grounded? If the SUB is in working condition and there is nothing wrong with the amplifier.
1) The amp is not powerful enough to run the sub
2) The amp is not properly grounded or powered
3) Remote Sensor wire is not connected
4) RCA Cables or Hi - input sensors are not connected
Check out the installation to verify or the sub may be damaged
Posted on Apr 27, 2013
How much airspace does Pyle PLBW154 1500W 15" Blue Wave Series Dual 4 Ohm Subwoofer need?
If its going in a single cab truck you won't have enough room. In a car you will need at least six inches. Might consider soundproofing the trunk if that's where they will be BC the vibration from the base will bounce off the walls and can blow your speakers??
May 30, 2015 | Pyle Car Audio & Video
How big of hole do i need for the mtx 6000 thunder 10in
The MTX Thunder 6000 T61544A is a 15" Subwoofer meaning you will need a 15" hole to fit the subwoofer into. The mounting plate that surrounds the subwoofer will extend past 15" allowing you to screw the sub in properly. Be sure to use a box that is at least 12 inches deep (sub is 10 inches deep by specifications + 2 inches for good air cushion behind.
Mar 01, 2011 | MTX Thunder 6000 T61544A Car Subwoofer
Would putting an EVM10DLX into a set of Yamaha BR-10s be a recommended upgrade? Worth the cost?
It is VERY RARE for such a change to be beneficial. The cabinets and speakers are finely tuned to work together and the originals are usually just as good performers as anything you can replace them with. If you want a subwoofer you need to get a larger cabinet and preferably a larger speaker. A ten inch speaker for subwoofer use would require a closely engineered cabinet. Best to go to a single powered 15 inch subwoofer (one designed as subwoofer) to run alongside your BR-10's.
Dec 14, 2010 | ElectroVoice EVM10DLX 10" Subwoofer for...
Would a Pyramid 15" subwoofer work for my Yamaha synthasiser?
Do yourself a favor do not get anything Pyramid they are cheap for a reason and you will not get good bass response from them even in a optimal enclosure.If you want nice bass for little money go with lanzar opti 1535D sub you can pick one up for around $265 and will blow away Pyramid any day.
http://review.zdnet.com/product/subwoofers/lanzar-opti-drive-opti1535d-car-subwoofer-driver/33649420
  • Custom Tooled Die-Cast Aluminum Basket
  • COC Composite Cone
  • Jumbo Dense Foam Surround
  • 3’’ High Temperature Dual 1.2 Ohm Voice Coil
  • 100 Oz x 3 High Density Barium Ferrite Magnet
  • Power Handling: 1600 Watts RMS /3200 Watts Peak
  • Frequency Response: 30 - 500 Hz
  • Impedance: Dual 1.2 Ohm Voice Coil
  • Efficiency: 88dB
  • Includes Installation Hardware and Template
  • Packaged In a Wood
  • lanzar-opti1535d.9909657.jpg lanzar-opti1535d.3004946.jpg lanzar-opti1535d.9909658.jpg lanzar-opti1535d.1054589.jpg lanzar-opti1535d.1785277.jpg lanzar-opti1535d.9909656.jpg default.jpg
    Apr 18, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
    I have 2 15'' CVRs and a 1200w amp
    1 OHM...ONE... sheesh now thats a low resistance for anything... If they are only 500 watts and they are in parallel, series well NO.. your amp puts out wayyyy too much for those speakers.. 1200w versus 500 watts by 2... srill NOT enough "Head room" for it to be safe... about half is all you could expect before Pop.. sound is heard.
    Mar 05, 2010 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
    I HAVE A 15 INCH TYPE R DUAL VOICE COIL AND WAS TOLD IT WAS BLOWN I BELEIVE NOT HOW DO YOU KNOW FOR SURE??? AND IS IT SUPPOSE TO BE IN A SEALED BOX OR A PORTTED BOX ???
    if the cone can be pushed in with ease it is probably not blown, it would have taken alot to blow one of those to begin with.
    the box you put it in depends on what sound you are looking for, if you want faster response (for techno and fast paced music) a sealed box would be best. but if you are looking for something slower and deeper then you want a ported box.
    being a 15 inch i would suggest a sealed box.
    Nov 08, 2009 | Car Audio & Video
    My 15 & 10
    On a 10 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 20 liters, meaning that you will end up with a box of 11 inches high, x 11 inches wide, x 11 inches deep. Or 275mm high, x 275mm wide, x 275mm deep. Seal the boxes with silicone for better bass
    Oct 21, 2009 | Hollywood Sound Lab Hollywood Digital...
    It keeps blowing fuses - two 12 inch cls subs 1
    sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
    Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
    2 15'' inch Memphis
    Check flex, make sure amp is not too powerful, check bridge and wiring.
    Dec 15, 2007 | Car Audio & Video
    Blowing subwoofers
    Sounds like you have burned them out. Let them cool & then turn on the system at a low volume. If they still work then you have not damaged them too badly & might still be able to get some life out of them yet. If on the other hand they don't budge then they are burned out & seized, it's time to buy some new ones.
    Car Audio & Video Logo
    59 people viewed this question
    Top Tsunami Car Audio & Video Experts
    xxxxxx xxx
    Are you a Tsunami Car Audio and Video Expert? Answer questions, earn points and help others
