Question about Garden
I have a quantum 4.5 powerpro mower that wont start after not being used .. Has oil fresh gas what else can i do to get it startec
  • 205 Answers
SOURCE: mower won't stay running
carb is gummed up. carb cleaner is the only thing that will help, Get it at walmart, spray can usually less than $3. Comes with a wand (straw) for spraying in small holes etc. Take the air filter off and look for small holes around inside the carb intake, stick the straw right in those and shoot, WEAR goggles or classes and rubber gloves, stuff is nasty. If it still won't run you will need to do some disassemble of the carb, if it has a bowl remove it and wash everything out with the cleaner.DO NOT however get the carb cleaner on the bowls top rubber ring it will wreck it. Be careful to put the float and needle and seat back as they were. The brass screw that holds the bowl on has some tiny cross holes in it, one strand from a wire brush works great for cleaning them out. Good Luck, Chuck
Posted on Mar 19, 2009
  • 636 Answers
SOURCE: my craftsman lawn mower stalls .i changed the oil
Is your primer button stiffing up when used or is it or does it remain sponge ? Or you may have something in the carb .Take the bowl off and clean it. Is your gas fresh or has it been sitting around awhile? Hope this helps you out.
Posted on Jul 29, 2009
  • 582 Answers
SOURCE: my toro 6.5 self propelled mulching mower with
IF THERE IS A PRIMER BULB ON THE CARB CHECK AND SEE IF IT IS HOLDING GAS IF NOT THE CHECK VALVE UNDER THE PRIMER IS BAD AND SUCKING AIR
Posted on Aug 12, 2009
  • 77 Answers
SOURCE: Brand new weed eater lawn mower blowing white smoke.
Pull air filter see if theres any oil in it,make sure the oil isnt overfilled. Push mowers usually smoke like that if theyre overfilled,or tipped on thier side,if there is oil in filter simply take filter off,drain oil to correct level,and run it till smoke goes away. If none of this is the problem rings are probably shot. Weedeater is a cheap brand and theyre made cheap too,not made to last.
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
Push mower starts, but then dies. I have checked gas and oil, and added fresh gas. Oil is clean. WHY WON'T IT STAY CRANKED?
carb could have an obstruction . gas in sediment bowl burns ,mower dies, wont start again until gas has trickled back in to fill bowl.
Oct 12, 2014 | Briggs & Stratton Garden
Lawn mower instructions why wont it work
check for spark at plug if spark at plug then squirt some starting starting fluid in carb see if will start it should run long enough to burn out starting fluid if does check for water in gas if is drain tank and carb bowl put in fresh gas not and repeat not old gas you were using strat lawn mower if still dosnt start rebuild carb and add and additive called seafoam to the gas this is good stuff follow instrution on bottle
Sep 02, 2014 | Garden
Quantum 4hp powerpro
you have a blocked primer passage take off filter huosing blow dirt out of passage and out of prmerball it might be bad enough to rebuild carb
Jul 05, 2014 | Garden
I have a murray 6.5 quantum 22inch blade mower that is a couple years old but was only used a couple times last year. It has oil, it's getting spark but it isnt getting fuel. I removed the air filter and...
Remove the old fuel from the tank. Change the gas filter if there is one. Get a can of spray carburetor cleaner and a can/bottle of fuel line cleaner. Spray carburetor cleaner in the carburetor where you put the gas ( remove the air cleaner) . Pour the fuel line cleaner in the gas tank with fresh gas and try to start the mower. Spary some carbuerator cleaner in the carburetor and try to start the mower a few times.
Jun 12, 2014 | Garden
Motor mower wont start
By tipping a 4 cycle motor on a lawn mower or any equipment, you have all the oil and gas running into the combustion chamber and sometimes the oil and WATER will get into the tank. It will need too have the spark plug removed, the engine turned over with the starter to blow the oill, gas, and water out of the cylinder(s), the plug should be either dried and gap reset, and the gas tank drained and FRESH gas put in it. Replace the spark plug prime with just a few drops of gasoline in the carburetor throat and restart and let run to dry evrything. NOTE: An oil change is recommended, too!!
Jan 14, 2014 | Garden
Mower wont start changed plug still wont start checked gas line seemed okay but what is that plastic piece in the line never seen one before
Getting a mower out of its winter slumber takes some time. Start with fresh gas, new oil, and air filter. Sometimes carbs get gummed up(varnisized gas). Donyboy73 on youtube shows how to remove Briggs n Stratton in tank carb systems and clean the parts and passages.
Apr 27, 2013 | Toro Power Lawn Mower
TORO TIME CUTTER SS4235,NOT STARTING,NO ELECTRCAL POWER TO SWITCH
Check wiring for ground. Ensure battery is fully charged or replace. Replace spark plug. Clean or replace air filter. check oil level, all mowers have a low oil start cutoff. Bad gas? Flush out fuel tank by removing gas line, flush fresh gas thru. Reattach gas line, fill with fresh gas, always use Stabile in gas! Check fuel line for cracks and secure connection to carb. Battery should read 12.8 volts or higher. .
Aug 21, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
I have a powerpro Quantum 4hp push mower with a broken throttle cable. I can't find any replacement cables for that model, is there any other that fit?
most hardware stores have a universal cable kit that will bolt to the side of the handle homedepot/lowes as well
May 20, 2012 | Garden
B&S Quantum Power 4hp won't start with fresh plug,
Did it run before you changed the plug?Gap is correct, flywheel shear pin may be bad, Water in the Gas?
Jul 02, 2011 | Poulan "" Push Mower
My 2year old toro 6.0 lawn mower wont work i just took it out from the shed, it was in there during the winter and now wont work. it worked perfect before why is this not working someone told me its debris...
did you burn all the gas out at the end of year last year if not bad gas will leave deposits in the carburator.here is a simple sugestion drain any gas out of it thats in it .put fresh gas in it and 2 table spoons of marvel mystery oil in gas tank you can get it at any auto parts store crank it untill you are sure fresh gas oil mixture is in intake wait an hour and let the fresh gas\oil mix do the work.pull plug dip it in fresh gas put plug back in and try to start it this often works if it dont you could have leaves .dirt .rust .or debris on surface of flywheel ,or a bad sheer pin on flywheel the sheer pin is whar times the engine on most small engines good luck i hope these sugestions help
Apr 29, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
208 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
