Question about Xerox Phaser 4500 Printer
Pdf prints too small - Xerox Phaser 4500 Printer
Why can't I print a manual after downloading pdf?
if the printer will print other documents then you may be printing from the wrong printer icon
you have to use the small printer icon at the top of the pdf page and not from anywhere else
Jan 19, 2017 | Cameras
My HP LaserJet 8000N will not always print .pdfs.
8000N is older printer and likely has small amount of memory in comparision to newer units. If it prints basic small PDF fine but balks at printing larger jobs, that is likely the issue. Newer versions of Acrobat might also cause issues. Did you recently upgrade to reader 9 or 10?
Jul 01, 2011 | Office Equipment & Supplies
Very very slow to print pdf files larger than 600KB It will print first page pause print next 2 pages really big pause and then the pattern continues
This is because pdf files are actually huge images rather than an empty white page with text and perhaps a small image. The only way to improve this is to add more memory to your printer. There is often a small cover on HP printers where you can add memory, the downside, it is usually expensive.
Apr 08, 2011 | HP Office Equipment & Supplies
How to convert project primevera file to pdf. My PC not connected into any printer. So i need to take project primevera file in usb to print . Is it possible to save in pdf format.
Yes, this is absolutely possible.
You need a small piece of software called CutePDF. Its free and hardly takes any space on your pc/laptop.
Direct Download Link for CutePDF
Once downloaded, install the software and follow the steps below:
1. Open your project primavera file
2. try to print it
3. before printing, the time when u have to select your printer, select Cute PDF Writer as shown in the image below
4. Click on print
5. The primavera project will be printed as a PDF file and you'll be asked where you want to save it :)
6. Choose your destination.
7. When the printing is completed, you can open the pdf file in Adobe PDF reader
* You don't need a printer to do this
* You can follow the same steps and print word/excel/powerpoint files to pdf (or any other file type that you can "print")
Hope this helped!
Apr 04, 2011 | Primavera Project Planner P3 (PRIMAVERAP3)...
Prints PDF documents VERY slowly (4-5) per page
The actual issue you will find that its not so much the actual printing part of the process that is slow, its actually the spooling to the printer that takes the time.
Does your printer support PostScript printing ? (PostScript is a printing & imaging standard used by many printers) To find out if your printer does indeed support this either refer to your manufacturers documentation or perform a test page and look to see if you have a PostScript enabled option.
If your printer does support PostScript, make sure you are using its PostScript printer driver, most of the time we generally use PCL drivers, so simply change this.
Regards....
If you find your printer does not support PostScript there are a few other tweaks we can implement to increase printing speed.
Firstly we can force PDF files to be printed as graphics as opposed to text, to do this launch your chosen PDF viewer, select Print > Advanced > Print as image
Lower the print resolution, if we lower the print resolution most of the time the difference is very small, but it can reduce the actual print size of the document by up to 300%, which can greatly decrease printing times.
Make sure you are using the latest version of any print drivers or your chosen PDF printing program, normally Adobe Acrobat.
If the printer only has a small amount of memory if possible add more, if possible install a PostScript SIMM.
Check the amount of ram your computer currently has, check memory usage from task manager when printing to ascertain usage
May 19, 2010 | HP Color LaserJet 2600n Printer
Printing problem (local and network) only with pdf
PDF files are designed to be small on the computer and are uncompressed when sent to the printer. The size of the PDF is filling up the memory on the print server causing it to crash.
make sure you have the latest printer drivers.
heres a work around if the drivers didn't fix it. check "print as an image" from within printing options in Adobe Acrobat (you gotta go to "advanced" to find that check box), and then it works fine.
Apr 06, 2010 | HP P2035N LaserJet Monochrome Printer
The print is very small and it will not work with my PDF files to print on correct pages.
open pdf file
the print
go into advanced or any other optuion
as you need to look for option "print as image " and once you get the option just check that option and then try to print
Mar 01, 2010 | Computers & Internet
Print in manual too small read -avail. larger?
I'm guessing that you've got the manual as a PDF file. If not, you can download it from here: http://www.fujifilmusa.com/shared/bin/f450_manual.pdf
Once you've opened it, you can use the + and - buttons on the top menu to zoom in and out. Alternatively, you can use the + and - keys on the numberpad while holding down the CTRL key.
Hope this helps!
Jun 18, 2009 | Fuji FinePix F450 Digital Camera
Prints gibberish
the pdf files you printed might be too small in letter size..check if the printer works properly if you copy and paste the adobe files in MS WORD and increase the letter size and then print it..pls feedback for this solution
May 22, 2009 | Lexmark Optra N 240 Laser Printer
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
