Question about Frigidaire Refrigerators
Refrigerator side freezing and cannot control temp.
I have a 10 year old side by side Frigidaire refrigerator model number FRS26R2AQ5 that has a problem only on the frigerator side. The freezer works good. We had it set to the factory settings but about 1 week ago the fruit and fluids started to freeze. I put a thermostat inside and found that it was at 20 and running. I turned it all the way down and heard it turn off. I have been trying different settings but it is either too cold or too warm and will not stay at any temp for long. Do I need some kind of thermostat? Is it inside the control panel in the top of the fridge side? Thank you JIM
  • James Kollat Apr 27, 2013
    Thank you for your help. JIM
  • Frigidaire Master
  • 4,655 Answers
Refrigerator side freezing and cannot control temp - 099b99d4-9ea3-4dba-a2ca-6c92989fe8af.jpgLook and see if the air damper called a=> 5304482075 Temperature Control Thermostat is opening and closing after selecting a different temperature. This along with the termostat are what controls the fresh food section temperatures. I am here should you have questions, Thanks Sea Breeze
Posted on Apr 26, 2013
Testimonial: "Great help."
  • 5 more comments
  • James Kollat Apr 26, 2013
    Thank you. I will check this part and get back to you.
    When I turn the control I can here this air damper open and close, I can als feel the cold air shut off and then turn back on while I turn the control. Seems like this damper is working. Any other suggestions on what to check next? JIM
  • John Tripp
    John Tripp Apr 27, 2013
    These components should also open and close the air damper proportional to the temperature settings you request. The damper may open and close but will it create and maintain the temperatures you ask for?
  • John Tripp
    Jim I know of no other parts that can regulate temperatures other than the return vents located in the bottom of compartment. That is an expensive part and most likely returnable should its replacement not do the job. Thanks JT
  • John Tripp
    It may be time to buy a replacement refrigerator. Being 10 years old and the part is 20% of a new refrigerator would cause me to get something new and better.....JT
  • John Tripp
    You are welcome! Thanks John Tripp
jumptrout51
  • 3361 Answers
SOURCE: Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
Posted on May 24, 2009
machinetech7
  • 1344 Answers
SOURCE: Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
Posted on May 17, 2012
Testimonial: "thinks alot, after 24hrs it staying at 39f so its working now i don't know why but she all fixed the only thing i did was turn it off for a min and turn it back on. "
  • 1462 Answers
SOURCE: Maytag side by side model GS24C8C3EV Refrigerator too warm
it is almost certainly a defrost problem. when fault has occured, remove freezer bzck panel and see if there is ice build-up. if so this confirms a defrost problem - possibly that the element is open circuit
Posted on Jun 22, 2007
aborcass
  • 2651 Answers
SOURCE: refrigerator freezes food
sounds like might be a cold control issue, not cyclying on/off. if correct you dairy is good judge, so id assume that your ice cream is FROZEN SOLID. try turning down refrig temp control this will reduse run time(if working at all)
Posted on Feb 24, 2008
  • 132 Answers
SOURCE: I have a 20 year old sub-zero refrigerator. For
It sounds like the freezer side is losing its capacity......All cooling done on the refrigerator side is done by air flow of the fan in the freezer compartment by the evaporator coils(aluminum fins looks like a radiator)
You might want to pull the back panel of the freezer section and look at it.
Normally it is fully frosted when running(whitish snow covering on evaporator) If it is only partially frosted it has a freon leak or compressor problem. If it is engulfed in frost and there is no air flow possible through it your defrost system has failed.My guess is it is partially frosted and you have a freon leak.
Also check the fan by the compressor is running on the outside and the condensor coils on the outside on the bottom are clean.( fan runs when compressor runs)
A
Posted on Jan 14, 2010
Testimonial: "Quick intelligent response! Thank you!"
Www frigidaire com
Wire connector loose under door hinge cover or other loose connection, What is the model number? Could be something that I or someone will need the most important part of the refrigerator (Model Number) Try to find if possible, Thanks John Tripp Appliance 911 91641dbb-0105-46fa-be14-a2da26def0cc.jpg
Jan 25, 2014 | Refrigerators
We have a 4 year old frigidaire side by side refrigerator, model phs69ejss0, it has stopped cooling fridge and freezer and there is a 4 flashing in refrigerator temp display area, any idea how to fix?
The Flashing #4 occurs when power is applied to the fridge and the control board goes through it's cycles and didn't detect a damper connection.
So its your air damper that's bad.
Here is the part to order.
Dec 09, 2012 | Frigidaire Pro PHS69EJSS Stainless Steel...
Milk and other items keep freezing in my side by side fridigaire
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Frigidaire FRS23H5AS Side by Side...
Refrigerator does not defrost
you need part number 23 on this web site. or it also could be the temp control knob. Let me know if you need more asstance.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5149974
Aug 24, 2009 | Frigidaire FRS6R5EMB Side by Side...
Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
Serial number
there are a few places to look for most frigidaire side by sides the model and serial number are on a tag either on the right hand inside wall of the refrig section or on the ceiling in the refrig section. on some older models though the tag may be behind the crisper drawers at the bottom. hope that helps. peyton
Jan 27, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerator is too cold. Freezing milk and vegs.
sounds like the solenoid door is broke or stuck ,unless you are real handy , just tape up the air inlet in the refrigerator little by little until you get it right.
Dec 15, 2008 | Frigidaire FRS266ZDSB Side by Side...
Food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Oct 14, 2007 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
727 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
