Question about Motorola Mobility H700 Wireless Headset
Dead I left my h7oo in my pocket and it ended up in the wash. Am I out of luck here? Is there anything i can do to bring it back to life.....Thanks I'm a Dummy
    Problem Solver:
  • 13 Answers
Water is the enemy of electronics.(For the most part). I hate to be the bearer of bad news but you are simply out of luck. I am sorry you'll have to get a new headset.
Posted on Aug 05, 2007
SOURCE:
I have a fisher & paykel ecosmart washing machine that wouldn't rinse and then didn't spin out. i turned machine off and unplugged and now it will not come on when plugged in.
on these t starts off with a pump fault then if it shorts out it goes dead a new pump may bring it back life if not then its blown the main board
Nov 19, 2017 | Fisher Washing Machines
Need drivers for HP Ipaq RX4240 to sync with Windows 7
You can obtain all HP products & services for support for each product here at this link below, hope this helps....
https://support.hp.com/gb-en/document/c01121139
Jan 25, 2018 | HP iPAQ rx4240 Pocket PC
Washer sometimes halts after filling. Sometimes opening and closing the lid brings it back to life. Sometimes moving the dial brings it back to life. Sometimes nothing brings it back to life. The problem...
been a servicer for 18 years and had one yesterday that had me in a daze for a bit ,but finally figured it out... it was doing the same thing and if you pulled on the timer knob sometimes it would restart and sometimes you had to move it to the next cycle to get it working...it seemed to always happen on the spin cycle or rinse when the unit was suppose to start the tub operation... i finally determined it had bad contacts in the timer and had to replace it for the customer.... hope this helps you out... wish you luck
Feb 13, 2011 | Whirlpool Washing Machines
I have a Zanussi ZWF12070W1 washing machine. It's
Hope I can help.When you press the start button is there a buzzing coming from down by the filter if so Check that there is not something stuck in the filter.You will have to be careful depending on how much water is left in the drum so put some towels down and undo filter slowly or get the machine near a door then release filter out onto a door step.when drained shine a torch up inside filter and see if the little plastic blade on pump can turn but do not try and force it,if you do find anything in there then try it again and check the pockets.If there is still a fault you will have to call out your Engineer.
Good Luck
May 04, 2010 | Zanussi ZWF12070 Front Load Washer
Electric range heard a loud bang then it went dead
I WOULD DISCONECT THE POWER AND REMOVE THE BACK PANNELS AND LOOK FOR A SHORTED WIRE OR A BURN MARK ON THE BOARD. ALSO CHECK WHERE THE CORD ATACHES TO THE STOVE. GOOD LUCK!
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 17, 2010 | Kitchen Ranges
Frozen Screen
I had this problem and the only way to solve a frozen screen is to let the unit run out of battery and bring it back to life. Battery will die out on you for 6~8 hours. Once battery is dead you must do the following.
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 28, 2009 | Garmin StreetPilot C330 GPS Receiver
Pocke pc keeps resetting
I have 2 camcorder batteries that are totally dead. No matter how long I leave them plugged in, they aren't coming back to life.
Everything has a life span and it looks like your battery has reached the end of its life. If the e405 works on AC but not battery, then I have to suspect the batteries are now duds.
Time to go shopping on ebay!
Mar 13, 2008 | Toshiba e405 Pocket PC
Rained on T-Mobile Wing
While holding down the soft keys insert the stylus into the side of the phone (small hole on left hand side) should bring up a prompt to say if you continue you will reset your device....if you can get to setting there is a clear storage option, both master reset device. Good luck..
Jan 11, 2008 | T-Mobile Wing™ Smartphone
Old unit not powering on
Hold down the power button and push the reset button. Then select the corresponding cancel button (unless you want to loose everything. If that doesn't work, pull the battery and the backup battery. You will loose everything but it might bring it back to life.
Nov 10, 2006 | Dell Axim X5 Pocket PC
Sony Handycam DCR-HC30 2004 model
Your unit is a 2004 model. If it has never been used since then the battery is probably no good and will need replaced. Batteries discharge 20% on a monthly basis just sitting on the shelf so yours went dead a long time ago. Then if they are left in that state (dead) they sulfate which means that sulfur oxides transfer to the plates and form an insulating surface. At that point all the charging in the world is not going to bring it back. All you can do is get another one. They are available at most stores which sell electronics. Get a new battery and charge it per the instructions and try using it again. This should solve your problem. Good luck.
Jun 13, 2006 | Sony Handycam DCR-HC30E Mini DV Digital...
Motorola Mobility H700 Wireless Headset Logo
42 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
