Question about Toshiba Satellite P875 Laptop Computer - 3Rd Generation Intel Co
Acpi wec1023 36128fa - Toshiba Satellite P875 Laptop Computer - 3Rd Generation Intel Co
Why ACPI not supported by upgrade to windows 7
acpi is supporrted by win 7 just make sure ist on in the bios and download acpi driver from the motherboard factory
Microsoft ACPI Driver Windows 7 Service batcmd com
Sep 05, 2014 | Computers & Internet
WHO MAKES BIOS FOR TECRA?
ACPI Flash BIOS version 3.20 for Tecra A8 (PTA82) Posted Date: 2016-09-19 ' Version: 3.20 ' Size: 3.82M ACPI Flash BIOS version 3.30 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 3.30 ' Size: 3.82M ACPI Flash BIOS version 1.40 for Tecra A8 (PTA82U) Posted Date: 2016-08-24 ' Version: 1.40 ' Size: 3.54M ACPI Flash BIOS version 1.60 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.60 ' Size: 3.52M ACPI Flash BIOS version 1.50 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.50 ' Size: 3.54M ACPI Flash BIOS version 1.30 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.30 ' Size: 3.54M
Apr 02, 2014 | Toshiba Tecra A8-EZ8311 Notebook
Aspire 1700 needs to be acpi compliant, to run windows 7 help needed
Advanced Configuration and Power Interface
(ACPI) specification provides an open standard for device configuration and power management by the operating system.
Windows 7 absolutely requires ACPI 2.0 for power management.
Your laptop only supports ACPI 1.0. Windows 7 will never load
I think Vista is the most advanced version you could install.
I really like XP as the speed is so much faster.
Keep Smiling :)
Oct 24, 2013 | Computers & Internet
Error: Install Failed ! ATK0100 ACPI UTILITY
Welcome to Fixya
ACPI utility/software refers to the computers power management. ACPI program usually provided by manufacturers. May i know the brand and model of your computer? Did you install the ACPI utility using the disk?
Your response will be highly appreciated.
Thank you for using Fixya!
Jan 06, 2011 | Computers & Internet
ACPI ATK0100 1010100 XP
what's the problem with "acpi atk0100 1010100 xp"?
Can you please rephrase your question because I don't understand what you mean by
I look forward to your reply,
Bye for now.
May 27, 2010 | Toshiba Satellite A135-S4527 Notebook
ACPI is not a compliant
Enter you bios & disable ACPI. Restart the system. Than update your windows. There should be an update for ACPI through Microsoft update service. Once installed restart your system & enter into your bios. Now enable ACPI. Save & exit the bios.
If this does not help you can try the work around found on Microsoft's web site. See the link provided;
http://support.microsoft.com/kb/314830
Cheers
Mike
Jun 01, 2009 | MSI Computers & Internet
I have ACPI problem. said when i was trying to install os on my system and it said "the bios in this system is not fully ACPI compliant" pls what can i do
For that particular software you are using,,the ACPI thinks your Bios needs updating.
You can re flash the Bios to a newer version if one is available, and if one isn't available,,then i would suggest turning off the ACPI functions in your system Bios.
ACPI controls the power saving features of your machine via the software, also the power saving features on any legacy devices attached to your system.
Jan 19, 2009 | Computers & Internet
I need to disable tha acpi on an acer travelmate 529tx but i don't know how to do it. i am trying to install xp after a failure. i get bsod and says to press f7 when i install storage drivers but i need a...
I have seen on many forums that ACPI makes a lot of troubles to a lot of users under Windows. I will try to explain several things about ACPI and I hope that you will be able to solve your problems after you read this article. I cover only most encountered issues, but always there is a choice even if it's called ACPI disable.:)
The computer ACPI support is detected in the setup stage, but there are less frequent cases when ACPI is not detected and the Standard PC HAL is installed. If you want to force the installation of the ACPI HAL:
1. At the blue screen of the Windows XP setup when it prompts you to press F6 for additional mass storage devices press F5 and you will have a list of options.
2. Choose the proper HAL for your machine remembering that there are also different HALs for multiprocessor machines.
3. Complete the setup, go to Setup / Control Panel / System / Hardware / Device Manager / Computer. If you have listed the Advanced configuration and Power Management (ACPI) the process was completed successfully.
Warning: You can do the same thing if you don't want to install ACPI and your BIOS doesn't support ACPI disable setting. Just choose the Standard Computer HAL from the list of options.
Another method to disable ACPI is:
  • wait for the text-phase of XP setup to complete
  • before XP Setup Wizard to load, boot into DOS and change ACPIEnable = 0 from ACPIEnable = 1 in file c:\txtsetup.sif
The reason why ACPI is not installed on a computer with known ACPI compatibility may be a Microsoft known subtle incompatibility which can lead to hardware instability. In the installation step Windows XP checks the BIOS compatibility with ACPI and the BIOS presence on a known bad list. If the BIOS is there ACPI is not installed. Of course than errors can occur so you can force the ACPI installation (not recommended).
Try disabling it in the BIOS first, this can not be done on a computer with the operating system already installed as it will cause the machine to stop. MUST be done when you initially install the OPERATING SYSTEM.
Regards.
Nov 16, 2008 | Acer Computers & Internet
System reboots when acpi turned off
Hi martinkp, what you need is the update from windows. Leave you're acpi enabled withing the bios. Check windows update. Windows will update (windows software for the acpi). Rule of thumb concerning windows update. Check the dates of the updates & install in order, oldest to newest. This should fix you're system from shutting down. There will be no reason to turn off acpi after updating.
Mike
Apr 06, 2008 | MSI K9VGM-V Motherboard
Wireless card not functioning/disabled after loading XP in a Compaq Presario C700T CTO Notebook PC
The wireless is not going to turn on and off via the switch properly until we get the drivers loaded to make it work. There are 3 possible types of wireless card it could be, so we have to find out the exact model number of your system. On the bottom there should be a label that has a P/N or part number listed. what are those numbers. Here's an example of the label:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033108&lc=en&cc=us&lang=en&os=2093&product=3632144&dlc=en
or
http://tinyurl.com/35dt4h
we need the info listed for #1, #2 and #3. Then we should be able to determine which adapter you have, and then we can (hopefully) find some Windows XP drivers for you.
Feb 26, 2008 | Compaq Presario 700 470024-192 Notebook
Toshiba Satellite P875 Laptop Computer - 3Rd Generation Intel Co Logo
18 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
