Question about Whirlpool 6060 DL Corner Pro-Fit Acrylic 6041
Jets will not turn off
The jets will not turn off of my mansfield pro fit whirlpool tub. I can unplug the power and they will shut off. I can also bang a flash light lightly against the pump (where the air hose goes into the pump, not the button) and the jets will turn off. Does this mean the pump is going bad? The pump is a Magna LD5A-C and is about $150 to replace.
  • Whirlpool Master
  • 717 Answers
Sounds like your air switch is bad in the little box on top of the motor.
It is part # TBS-339
Rod
US Parts Center
888-521-6183
Posted on Apr 25, 2013
  • 62 Answers
SOURCE: Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Posted on Jul 11, 2009
  • 80 Answers
SOURCE: whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Posted on Aug 21, 2009
  • 225 Answers
SOURCE: the button is stuck on our royal jet tub.
trying to fix button not a good idea,you need to replace button with new one.
Posted on Mar 07, 2010
SOURCE: I have a Mansfield, Swirl-way tub. Jets won't come
on mine water got behind the soft touch controll and corroded the connection see if there is green gunck on the phone like plug
Posted on Mar 12, 2010
uspartscente
  • 717 Answers
SOURCE: I just installed a new whirlpool jacuzzi tub with
if the light on the heater is not coming on when the tub is full of water and the pump is on then the heater is not working.
check the circuit breaker to make sure it is on.
the heater and the pump cannot be on the same circuit. They have to be on separate circuits.
Make sure they are on separate circuits.
Check to make sure you have the heater installed in the correct place.
there is a pressure heater that mounts anywhere after the discharge of the pump.
there is a vacuum heater that mounts in front of the pump in the suction line.
if you put on or the other in the wrong place it will never come on.
Posted on Jan 17, 2011
Why do jets turn on, then shut off?
the motor protection device is sensing to many amps. could be a flow restriction or the pump motor bearings are going bad.
Mar 06, 2016 | Jacuzzi Home
Aquaglass whirlpool tub
if timer and power ok, jets may be clogged. try running for 10-15 minutes after tub filled. It may unclog.
Oct 06, 2013 | Home
Galbocca tub with jets
You have some bacteria build up on the inside of your tubing of the tub.
Try some cleaning solutions per directions on the bottle of tub cleaner made specifically for this situation.
Cleaning Solutions
US Parts Center
Aug 22, 2013 | Whirlpool Home
Water coming out of adjustable air vent behind wall of tub
one or more of the jets are turned off. i would suspect someone is plugging the jets off which causes water to go backwards in the system and the water goes out the air controls. solution: check the jets to make sure the jet faces are turned on and/or tell someone to quit plugging off the jets when they are in the tub.
Mar 03, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have a Mansfield, Swirl-way tub. Jets won't come on. Lights are working, but no action from the jets.
Oct 04, 2009 | Whirlpool Home
My jets in my new tub will not turn on.
You could have a GFCI receptacle tripped or in test mode. look close to tub or in and around tub area for this. This receptacle has a test and reset button on it.
Aug 30, 2009 | Mansfield Plumbing Products Mansfield...
Jets stuf off on their own after about 20 - 30 minutes
This is normal for jets on hot tubs/whirlpools for the jets to shut off after 20 minutes. This is a safety feature to prevent overheating of the water. When jets are running, the hot tubs are constantly heating and can elevate to dangerously high temperatures excess of 110 degrees causing scalds that you would not even know are happening. Your body temperature acclimates to the climbing temps and you dont realize it is that hot. It also helps prevent you from falling asleep and not paying attention to the temps in the tubs. Sorry, but I think you are going to have to restart the jets after each cycle. It is a safety feature that can't be bypassed or circumvented. Good luck and happy tubbing
Dave K
Aug 29, 2009 | Home
Whirlpool tub, jets come on and won't shut off. No water in tub.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Kohler Whirlpool tub motor wont turn on
Kohler Whirlpool tub turns on and shuts right off. Reset gfi and motor turns on and shuts right off. Help
Mar 15, 2009 | Kitchen Appliances - Others
Kohler whirlpool will not shut off and sounds like about to blow
Sounds as if you may need a new switch to turn the tub on/off. You can find one on our site www.uspartscenter.com
Feb 28, 2009 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
Whirlpool 6060 DL Corner Pro-Fit Acrylic  6041 Logo
431 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
