Question about Belkin Computers & Internet
Belkin 640 It was hooked up wireless on moms laptop and it just lost it now I have to have either net cable to the router for it to work but it works on my phones and I pad but I'm tryin to hook a dell Inspiron 530 to it but it want find it and I can't find the belkin cd
  • 7,627 Answers
Try reseting the Belkin and reconfiguring the SSID and the Security Key. Here is a Setup Manual: http://www.belkin.com/PDF/F7D1401au_Basic_Modem_Router_2.pdf
Posted on Apr 26, 2013
  • 173 Answers
SOURCE: belkin wireless G router will not allow connection to internet
check for the physical cables, check if they are connected properly, if yes, try to reset the router and reconfig it
Posted on Jan 09, 2008
SOURCE: Belkin G Wireless Router Connection problem
Sounds like a faulty router or issue with the firmware if it is unaccesible, your best solution is to factory reset the device and try again.
Regards,
Kris
Posted on Mar 18, 2009
govinda123
  • 2263 Answers
SOURCE: Belkin F5D9230-4 Wireless G Plus MIMO Router setup
To set up the router , you don't need the CD.
you can do it manually.
First make sure that your computer is able to go online through the modem.
If yes then connect the modem and the computer to the router and set up your router.
Click here for step by step solutions
Posted on Nov 27, 2009
govinda123
  • 2263 Answers
SOURCE: lost installation cd for belkin F5D7234-4 G
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Feb 01, 2010
etaf
  • 779 Answers
SOURCE: I have a comtrend ADSL2+Ethernet Router hooked to
You dont need a Belkin Disk to set up - this can be done manually you can get a manual from this site http://en-us-support.belkin.com/app/product/list/q/routers/ select G in the first dropdown and then your model - theres two to choose from and then then the version
you have a choice - you could change the comtrend router to just use the modem - bridged mode - they have a few different routers see here http://www.comtrend.com/links/i$residential-adsl2-modem-router$product.htm so not sure which one you have if you can bridge to just use the modem then connect tothe Belkin and all PCs should connect to the Belkin
OR you can connect two routers together Leave the comtrend router set as it is -
Set the IP address of belkin router to same subnet as the comtrend. Depending on the DHCP range of the comtrend router - set the IP outside this range - so if comtrend is set to give an ip of 192.168.0.2 to 192.168.0.100 - set the belkin to 192.168.0.254 Disable the DHCP in the belkin.
Connect the comtrend LAN to one of the Belkin LAN ports - you may need to use a crossover cable. On the belkin the WAN port will be left unconnected
Posted on Mar 20, 2010
I hooked an ethernet cord to my belkin router so i could connect it to my xbox 360 and it dosent work so i connected the cord to my laptop to see if it was the cord. The cord works but it wouldnt connect...
if it says limited connectivity then the port on the router for ethernet is not working
* u need to do hard reset on the router using a paper clip * press the reset till u get a feel of a click * then hold it down for 1 min * then while holding unplug the powercable and plug it back * then release the reset then try with cable connected to computer then if not working * check with different cable if not working try with different computer *still doesnt work then u need to replace the router as the ports on the router not working
Mar 05, 2010 | Gateway Belkin F5D7230-4 802.11g Wireless...
Cannot connect to the internet
You cannot connect a router to a router. You would have to configure the belkin as an access point and I don't believe those routers can work that way.
Basically you cannot have a router "routing IPs" when another router is already doing that work. There will be a conflict and the second router will always fail.
Feb 15, 2010 | Belkin (F5D7230-4) Router (587009)
I have a belkin fsd7320 router and dlink 302 and cant get to net
It sound like youe wireless card in the laptop is not configured correctly.
The TCP/IP settings on the laptop's wireless card should be as follows :-
In the wireless card's Properties - TCP/IP
Enablw - Obtain an IP Address automatically
Enable - Obtain DNS server address automatically
This is the same for the LAN card.
Nov 21, 2009 | Belkin Computers & Internet
My wireless on my f5d7230-4 won't work but when i hook up a ethernet cable from the wireless router to my laptop the internet works but my wireless will not work
With the ethernet cable , it is working, Ok the router wired part is working but the wireless part is not working.
on your laptop , does it say connected to your wireless network ?
If it is not then try to connect to the wireless network .
Make sure that you have the correct wireless settings of the router .
Click Here for step by step solutions
Nov 12, 2009 | Belkin (F5D7230-4) Router (587009)
My laptop connects to the router but the internet doesn't always work. The connection is perfect yet most of the time it won't go anywhere. Sometimes if I move the laptop around a few inches it'll work for...
Greetings,
If the laptop is hooked up by ethernet cable and the problem happens when you move the laptop, you either have a bad ethernet cable or a bad ethernet port in your laptop.
Probably the best thing to do in your situation is since you have a wireless router, enable wireless on your laptop and use that instead and work wirelessly.
Let me know if you need help setting it up.
Aug 31, 2009 | Belkin F5D9231-4 Router
Regards,
Kris
Mar 17, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin router is working with desk top computer. add laptop
It's asking for the security word that you entered into the router when you set up wireless security. You will need to enter both the wireless SSID, and the security key to make the system work.
Jan 24, 2009 | Belkin N1 Wireless-N Wireless Router
Belkin G Wireless router not connecting to net
Did you save the IP addresses ?You may have to configure the router manualy go to your network ,settings or type in run box IP config and see whats going on
Dec 27, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin wireless G router will not allow connection to internet
Jan 05, 2008 | Computers & Internet
Wireless router
first connect the devices in this way
from us inter net modem to belkin routers inter net port connect a ether net cable rj45-->then connect another ether net cable rj45 from pc to -->ethernet port on teh belkin router>and reboot the router and modem if u r using cable inter net then immediatly that will work>and open a browser window type this in address bar http://192.168.2.1 u can see the belkin login screen and follow this link
http://www.gorge.net/help/wizard/belkin/f5d7230-4_pppoe.htm
rate me solved if its helps
Nov 18, 2007 | Gateway Belkin 54g Wireless DSL/Cable...
Computers & Internet Logo
167 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
