Question about Whirlpool Microwave Ovens
Loud noise vibrating
Microwave (NOT IN USE) last night made for the 1st time a very loud consistent noise while vibrating for over a minute or 2, then stopped.
  • Whirlpool Master
  • 9,085 Answers
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
Please post a new help request here on FixYa and include the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc. and detailed symptoms and when they occur.
Posted on May 04, 2013
bigg t
  • 640 Answers
SOURCE: Microwave stops working after 2-4 minutes
either the circulation fan that cools the magnatron is bad,or the magnatron is bad itself.
Posted on Aug 25, 2007
  • 43 Answers
SOURCE: Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Posted on Feb 03, 2008
atomicflash
  • 17 Answers
SOURCE: microwave stopped working last night
If the microwave worked for a little while after you plugged it in again then it is just overheating.It is usually just dust/dirt collecting on the vents.the fan,and the magnetron(the thing the fan blows on).If cleaning all these doesn't solve the problem you may have a bad high temp overload sensor,and need to replace it.(this sensor is usually mounted directly on the top of the magnetron.The magnetron is the part that actually puts out the microwave signal.I've never seen a reset button.The high temp sensors reset themselves automatically.
Posted on Jun 24, 2009
SOURCE: My JMV8208BAS microwave oven is
If you hear a very loud buzzing, it is probably a shorted high-voltge diode. This may be a small black stick wired to the high-voltage capacitor (metal can with two terminals), or could be inside the can.
You would have to replace it. If the unit is no longer heating food, then the cavity magnetron has gone bad. Probably not worth trying to get it fixed, as you should be able to get a 1000w or better oven for less the a repair shop would charge to fix this one.
Take care.
Posted on Oct 17, 2010
  • 6771 Answers
SOURCE: My NN-P295 wouldn't allow me to turn off the light
It sounds to me you have short in the keypad controller system, from your description this is a very dangerous fire hazard situation, and the microwave in my view should replaced.
Posted on Feb 21, 2011
Testimonial: "Not the answer I was hoping for, but I was very impressed with how quickly I got a response. Thanks"
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
I have a panasonic convection/microwave. Last night, after I cleaned it, using oven cleaner on a sponge, it made a loud humming noise after running on microwave for about 10 sec. It does not make the noise...
Since the unit makes the noise on Microwave but not convection it is a problem it he Microwave Circuit. Probably in either the rectifier of bad mag, one of them shorted. Just looked at the date you posted this, Im sure you have fixed or replaced this by now
May 31, 2017 | Panasonic NN-C980 Convection/Microwave...
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
It was working fine last night now it is making loud noise and not heating...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 05, 2010 | Sharp R-930AK Convection/Microwave Oven
Purchased microwave in 2005, just stopped heating and now its making a loud noise
if the loud noise is like a vibrating noise then it sounds like the high voltage diode.
Mar 23, 2010 | Kenmore 63252 Microwave Oven
Microwave not heating
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 08, 2010 | Whirlpool GH8155XM Microwave Oven
Loud noise like tray vibrating. does not cook.
Call GE answer center 1-800-626-2000 ask for tech help, Have your Model # orr your data plate ready.
May 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Loud noise
If you mean a loud buzz that cuts on and off as the oven works, it is probably the outer metal cover vibrating as the magnetron powers up and down. Try holding/ pushing/ poking the metal cover while the oven is working, if the noise abates or goes away, this is the problem.
You may get relief by simply tightening the screws securing the cover, if not, maybe a little careful insertion of a thin strip of cardboard or similar, at the point the vibration occurs, may dampen it. Good luck.
Jan 18, 2008 | Sharp R-254 Microwave Oven
Viking Micro noise
The noise is probably from the high-voltage transformer. When it is overloaded, the excess magnetic field it produces vibrates its wire coils. Odd that it only happens for a brief time. It is either defective itself (in which case it may go a long time) or it is getting overloaded by the magnatron/capacitor/diode on its output (in which case it will get worse shortly)
Hope Ya Fix it
Jan 08, 2008 | Microwave Ovens
Microwave Ovens Logo
83 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
