Question about Bosch HBL5450UC Electric Single Oven
Bosch built in oven
Brand new oven we installed yesterday and when you turn it on it goes to preheat 100' and does not get hot. SUGGESTIONS?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
Ok try there maybe a recall list as there is with there dishwashers try the list see if ure model number is on the list then if it is either send it for repair or rtn it most people still are using recall listed units
Posted on Apr 25, 2013
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: why does it take so long to preheat.
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 26, 2010
HansPP
  • 2510 Answers
SOURCE: Bosch built in double oven:
This type of problem normally can be ascribed to a defective thermostat. Unfortunately there is no test for a thermostat, it has to be replaced to see if the problem has been sorted out.
One thing you can do is remove the thermostat bulb from the oven and place place it in a position where it will not heat up. Place an oven thermometer in the oven. Switch on and see of the temperature climbs above what you wee seeing before. This is a very much hands on test as you have no control over the temperature that the elements can get to. As soon as you see the temperature reach a point above that seen before, shut down immediately.
Posted on Mar 27, 2011
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 | Bosch Ovens
Temperature light won't shut off after oven top cools down?
the preheat light wont go off on my oven, and its not really hot. my oven light is on as well ,how do I turn off the preheat light
Nov 30, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
We own a Bosch (Built-in) oven HBN4305.0B and the top grill/oven element has failed. Can you please advise on replacement procedure
With the power turned off it is usually a case of, in most ovens, just removing the element by unscrewing two screws. Unclip the wiring and make a note of what wires go where. Find a new one and install in reverse procedure.
Feb 10, 2011 | Bosch Ovens
I have Bosch double oven HBL HBN and does not
sensors would not make it heat up any quicker element might be getting weak,but 10 mins to heat up is about normal.
Sep 27, 2009 | Ovens
Neither oven will come on
Hello kybattey
Welcome to Fixya.
You said, After coming on and preheating Saturday, the upper oven went off and the lower wouldn't work either. Control paned was blank, but interior lights were on and pushing control paned buttons resulted in beeps. Turned off breaker for 5 minutes to reset and upon retry, the fan came on for maybe 5 seconds and then went off. Nothing else changed. Any suggestions?
You say the ovens went on and then later cut off.
Does the clean mode work?
Try the clean mode and see if it goes on.
Assuming it will clean!
Since the Range will clean you have confirmation that the proper power is reaching the range. It also verifies that the elements are in working condition. You will need to check the high temperature limit switch and the door latch mechanism. If either of these is defective, the bake and broil function will not operate properly
Let me know how it goes.
Waiting your response.
Huuum
Please remember to leave a rating when done!
Oct 20, 2008 | Whirlpool RBD305PD Electric Double Oven
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Viking oven broil keeps on
it is designed to preheat this way. after the unit cycles the red indicator light off the first time than both elements turn off. when it calls for heat again only the bake elements comes on. makes the preheating work faster.
May 05, 2008 | Viking 30" Professional Select Built-in...
Bosch oven
looks as though youre circotherm element has blown (open circuit) you will need to remove oven and check with multimeter should read around 35-37 ohms on 2.5 kilowatt heater if open circuit will need replacing easy to do on most ovens and no too expensive around £30-£35 for element depends on model and output power.
hope this helps
Jan 17, 2008 | Bosch HBL 745 Stainless Steel Electric...
Bosch HBL5450UC Electric Single Oven Logo
110 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
