Question about Yamaha HTR-5630 Receiver
Receiver continously turns on and off
When I turn on the receiver continuously turns on and off. It's as if the power button gets "stuck" when you turn it on. I don't know anything about receivers but I did open up the case and cleaned out the inside with an air duster spray. I thought their might have been some dust collecting by the power button. Also, before I plugged all of the speaker cables back up I turned the receiver on and off several times without issues. When I turned it on after I plugged in all of the cables it worked until I changed channels on my TV and it started clicking on and off continuously. thanks in advance
  • rummyim Feb 16, 2009
    I have a Yamaha HTR-5630 AV receiver and recently every time the power button is turned on almost immediately it shuts off. Anyone know what the problem could be or how to fix this. I have two large front speakers a center speaker and a twelve inch Sony sub-woofer hooked up to it.
  • 56 Answers
In this case, it is an important issue that what type of connection you've had between the amp and the TV (scart, s-video, rca, etc.) It seems to me that yours is an impedance issue. Refer to the user manual of the amp and check out the allowed or recommended impedance values, then buy appropriate interconnections.
Posted on Aug 07, 2007
6ya staff
SOURCE:
My crt monitor is not working, its power button light will be on when cpu is not turned on, but when cpu turned on , the monitor is continously turning off and on, please help me...
why in the world use any 20 year old CRT monitor
its a fire hazard now , bet you !
if it fails on PC #2 the monitor is bad.
is this test hard? with billions of PC on earth.
tell me it is not.
btw no HP model number stated
of of the OSD menu button works ever.(monitor button)
Sep 04, 2015 | Compaq Computers & Internet
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Lost my remote for my RCA RT2500 Audio/Video Receiver and i cant turn it on because the power button is stuck on standby. I purchased another remote model CRK76 but it wont turn unit on. I also unplugged...
You need to confirm if the power switch is working as the button is stuck . So it is best to get this part corrected before we move to the remote as the power switch or the button aligment can be corrected if you open to check the continuity.
Next the remote controller must be checked for the IR outputs. please check this link below for tips to repair or find a link for a universal type remote.
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
http://www.espares.co.uk/search/remote-controls/p/1090
Oct 06, 2011 | RCA RT2500 System
OMT Jukebox plays tracks continuously but will play selected track when ordered. Have turned off continous play button but it continues to play. Have programmed it not to play but it continues to play.
Perhaps someone has programmed the machine for "Play stimulator" (random play) or background music. The easiest way clear all f is to default the machine to factory settings. First, unplug the memory plug (red wire at bottom right side of selection and computer and turn off power to the machine for 10 minutes with the memory plug unplugged. After turning on power, the carousel will rotate to determine its capacity. After that the machine is ready for operation. Re-connect the memory plug. If you need further help you can contact me, [email protected]
Jan 20, 2011 | Wurlitzer Jukebox 1015 One More Time...
No picture and desktop makes beeping sound
Base on the post codes this continuous beeping indicates a power problem. Atypically this is a power supply problem and it will need to be replaced.
Oct 06, 2009 | Computers & Internet
Power button flashes blue continously and TV will not turn on.
The lamp is probably gone. Part # TS-CL110U. Easy to change yourself.
Apr 15, 2009 | JVC HD-56G787 Television
My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
hello!
You will see 3 led lights on the printer. They will blink continously if:
if the print cartridge status light is flashing
-- check if the top cover is open, Close the top cover.
-- there may be a problem with a print cartridge
1. Verify that the correct print cartridges are installed.
2. Check if a print cartridge is low on ink or improperly installed.
if the resume light is flashing
-- the printer may be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of
-- the printer may be ready to print the second side of a two-sided document
1. Follow the onscreen instructions for printing the second side.
2. Press the Resume button.
if the power light is flashing
-- the printer is preparing to print
-- The light stops flashing when the printer has received all data.
if all lights are flashing
-- the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button
to restart the printer.Proceed to step 2 if the lights continue to flash.
2. Press the Power button to turn off the printer.
3. Disconnect the printer from the power source.
4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
May 06, 2008 | HP DeskJet 940c InkJet Printer
Will not turn on
When holding the power button, to turn on the device, the screen pixelates dark and then goes blank. If I continue to hold the power button the screen will continue to pixelate dark and then go blank. In the end, the device still will not turn on.
Dec 18, 2007 | Garmin GPSMAP 180 GPS Receiver
Yamaha HTR-5630 Receiver Logo
119 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
