Question about Audio Technica Audio Players & Recorders
Sound comes out the left speaker very crackled
  • Audio Technica Master
  • 5,056 Answers
1: Faulty cartridge.
2: Faulty connection.
3: Faulty Pre-amp - in turntable or in main amp.
Posted on May 19, 2013
Left speaker not working, system crackles if left side is active, alright when left side shut down.
Get a meter and check the resistance on the speaker. Looks like a speaker may be blown but with the description of the crackle noise from the slide controls you might have a bad pot in the unit or the pot has come loose from the board. This could explain why the speaker blew out
Jul 30, 2015 | Behringer Europort EPA150 Ultra-Compact...
Crackling noise coming from 1 channel
sounds like you are picking up some interference first try swapping out the RCA cables you are using to connect that component. also keep your RCA cables away from any 110V AC power lines.
same thing with speaker cables, speaker wire should intersect power lines at 90 degrees and should not run parallel to power lines.
many people use the wires that come with their components. these cables are thin and offer very low performance a thicker higher quality cable with a gold connector will not only better maintain the quality of the signal being transferred between components but will also have better shielding to protect the cable from picking up interference from other electrical components and power lines.
Also should point out that a blown speaker sometimes produces a crackling sound, swap your left / right speakers and see if the crackling sound still comes from that speaker if it does you have a blown / damaged component.
Dec 30, 2009 | Onkyo Audio Players & Recorders
I have a crackling speaker on the left port of the bass box
The crackling sound on the left port of the bass box, indicates vibrating foreign matters inside it. Just open the box and clear it up. Put the sounds on. Listen if the crackling sound is audible. If the result is ok, then, close the box, and everything is alright..
However, if the result is otherwise, then, it is due to a defective speaker that needs to be replaced.
Nov 21, 2009 | Creative Labs Sound Blaster Live! 5.1...
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
I sometimes lose sound from my left speaker and it crackles.
this is a speaker input pin problem, like pin is dameg or input pin is not atech proparly in computer problem is still present remove the cable and install new one cable in speaker
Mar 11, 2009 | Audio Players & Recorders
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Crackling Sound
Not sure what model but there is a coil on some LG LCDs that needs to be replaced on the SMPS.
Jul 01, 2008 | LG 42LB5D 42 in. LCD Television
Stereo receiver crackling noise
open it up and spray it with contact spray. move left and right and then spray again. this will normally do the trick. the crackling noise comes from standing in the same position for to long.
Aug 13, 2017 | Audio Players & Recorders
Crackling Sound from Speakers
check audio cables wiggle them around if no difference in sound check other inputs if they all crackle call for service it sould be under warranty probably in the speakers or the input board
Oct 23, 2007 | LG 50PX4DR 50 in. Plasma TV
95 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
