Question about Canon SmartBase MP730 All-In-One InkJet Printer
Canon MP730 stops printing midstream
When printing on my Canon MP730, it beings the process as normal, I will hear the usual spooling sounds, etc. Then it prints out maybe a line or two of the document and stops completely, only to finally finish the job 30 minutes to an hour later ... maybe. The same happens whether on a B&W or heavily colored doc. What to do???
  • Sarah Eff Aug 07, 2007
    It's with text or colored docs, indistinctly.
    What's interesting though, is that I printed out an efax today with no problem at all (which rules out the thought that it might be something with the print head).
  • 57 Answers
Is the issue the same with a anormal text document or just with heavily colored docs? If the text doc gets printed fine, then it is an issue with print spooler and we might need to work on that. revert & lemme know
Posted on Aug 06, 2007
  • Adi Rishi
    Adi Rishi Aug 07, 2007
    Did you try to Uninstall the printer drivers & then deleted the registry entries also?
    Try it, just install the printer driver (not the whole software that generally comes with the Printer in a CD) & then try to print a text/pict doc.
SOURCE:
What's your problem? After having had "wrong
Did you take the tape off the new cartridge. For the ink to flow. not trying to be smart it is easy to forget.
Sep 12, 2017 | Canon MultiPASS MP730 All-In-One InkJet...
I have a canon MP730 and it is connected to my HP computer. I can print a word processed document and any material online onto the MP730. However, I am not able to command the scanner from my HP...
Theres a few things you can do, HP normally makes you install a slew of programs with the driver, see if you can find the program called something like "HP Scan" and try to use that to scan things. If that does that work, reinstall the driver.
Hope that helped!
May 04, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Canon mp730 has stopped printing magenta. We had just changed all the other color tanks (black, cyan, yellow) and magenta stopped printing. We then found we had dislodged the magenta tank (was...
Unclip it again and clean contacts on both printer and cartridge with a lint-free paper and a little alcohol (isopropyl alcohol if you have it). Clip it back and run the head cleaning and alignment routine; that should be enough.
Nov 29, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
I can not print on my canon iP90v. I try to download a new driver for it, but i keep getting an error that says I have problems with printer spooler.Do you have any tips?
You could either kick it or try this (less expensive) trick:
  1. Click "start" and go to "Run"
  2. Type "services.msc" at the prompt which will open the Services
    window (ooh, pretty...)
  3. Scroll down the alphabetical list in the right window pane until you come
    to the entry with the name "Print Spooler"
  4. Right-click this entry, then select "stop". This will stop the computer
    running the process that holds your print queues.
  5. Leaving that window open for now, click again on "Start", and then click
    "My Computer" to open a Windows Explorer window.
  6. We've stopped the queue service, now we just have to clear the jam that is
    already there. To do this we navigate to the print spool folder which is hiding
    within the Windows folders. Usually Windows is installed on C: drive, but you
    should be easily able to tell when the Explorer window opens which drive it is
    on.
    The usual path to the spool folder is
    C:\WINDOWS\system32\spool\PRINTERS, but yours may be slightly
    different. Your windows drive may have another name for instance, but this would
    be uncommon. So click on your Windows drive (usually C), then double-click on
    the Windows folder, and then find the System32 folder and double-click on
    that. Windows may warn you that you are about to view system files, but click
    "View files anyway" message and search out the "spool folder". Within the
    Spool folder is your Printers folder, and you should open
    that.
  7. Delete every file within this folder to empty the jammed print queue
    (pressing the "ctrl" and "a" keys will select all files and then you can just
    hit "delete").
  8. Close the explorer window now that we have emptied the cleared spool files,
    and return to your Services window. we must re-start the Print spool
    service, and do so by right-clicking the Print Spool entry and selecting
    "Start" from the list. Close the services window and try printing again
Nov 10, 2009 | Canon PIXMA iP90v Printer
Canon MP730 not printing. Printhead cleaning doesn't help.
You may need new print heads. They are around $50. Or, you could do this: Take the print head out of the printer, and run warm water from the tap (not high pressure), over the ports for about 5 minutes. Ink will drop out of the jets. Dont touch the electrical contact end of this head. This may clean the head enough so it works again. If not you need a new print head.
Apr 25, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Hloo I need hilp
sounds like you have an empty ink catridge. even though the catridge doesn't look complete empty the sensor can decide it is and won't work until you change the cartridge. You might want to remove and reinsert all of the cartridges making sure they are in the proper slot and properly setted.
May 05, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Printer
#334 is an eprom error, try turning it on and off to reset it, if it doesn't work there might be a problem with the main logic board.
Apr 12, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Canon smartbase mp730
Have you tried doing some maintenance like nozzle check,printing head alignment,clean the nozzles if not then try it by going into control panel - printers and faxes - where you see your mp730 right click and go to properties then click on the last tab which would be maintenance.Try those options if none worked then u might have to replace you print head and that should work
Nov 26, 2007 | Canon SmartBase MP730 All-In-One InkJet...
Canon MP730
If you haven't yet, try a cable that is bi-directional.  They are available in any electronic store.
Sep 18, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Canon SmartBase MP730 All-In-One InkJet Printer Logo
Clive
Clive
old marine
old marine
Ekse
