Question about Microwave Ovens
Microwave door switch
After entering time for cooking, closing the door, and hitting enter. There is a massage "Close Door" on the display window.
  • Microwave Ovens Master
  • 9,047 Answers
See our help file on door switches here:
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Posted on May 03, 2013
  • 4102 Answers
SOURCE: frigidaire microwave won t turn off
this is a problem with your programme timer these can be expensive to replace and because of the age you will probably be better buying a complete new unit as you could repair it and you could come across other related problems and could end up spending a fortune sorry i couldnt be any more help
Posted on Nov 08, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Will not work
This is usually a bad door swithc or loose or broken door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 18, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Door Switch Problem?
That model number has too many digits after the JVM. Could it be JVM1339BW02 or JVM1339BW002?
If one is bad, it's probably the bottom switch, whose wiring goes back to the power relay, thermostat, or fuse, depending on eact model.
The switch with thin wires going to a ltitle connector on the board is the door sense switch. That's not likely your culprit.
I usually recommend you replace them all while you're at it.
It sounds like it may actually be a loose or misaligned door or door switch mount.
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
GE models have a very helpful "mini-manual" hidden inside the unit behind the control panel. Handy in troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 04, 2007
reg501
  • 413 Answers
SOURCE: Whirlpool RM278BXP Over the range Microwave
The capacitor and diode will not cause the problem you describe. You will not be able to measure the diode with an ohmmeter, the forward breakdown is about 5-6Vdc. The normal failure mode for the capacitor is a short which will blow the fuse.
If any high voltage components go bad, the microwave will operate normally just not heat.
You should focus on the door interlock switches and safety thermostats, especially the cavity thermostat located somewhere on the top of the cavity.
To make a high voltage diode tester, wire up a 9V battery, LED and a 220 ohm resistor. Hooked up one way the LED will light reverse the connection the LED will not light.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 12, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Hi. I pressed the 'quickstart'
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
It may be a problem with a door switch or door switch mount.
Posted on Sep 28, 2008
My panasonic genius prestige inverter microwave has started to click off after I enter the power & time. Sometimes it will work fine. Sometimes it takes 2 or 3 times of entering then cleaing the i
Check the door latch switch inside the oven. The 4 switches where the door hooks latch on to when the door is closed has to engage with the door hooks to tell the oven that the door is closed. loosen the 2 phillip screws that holds the switch assembly and slide it to adj. and ensure that the switches close when the door is closed.
Sometimes the switches go bad and cannot make contact and must be replaced. If you see that the connectors on the switch is discolored or overheated replace the switch, it is bad.
Jan 15, 2015 | Panasonic Genius Prestige Inverter...
Whirlpool microwave fuse has blown multiple times
It depends on which fuse and when it blows. Wish you had mentioned that.
But usually it's a defective door switch or door switch mount.
If the fuse blows at random times while it's cooking, it may just be a loose fuse holder. Those have to be replaced due to metal fatigue, not just squeezed tight with pliers.
If it blows as soon as you hit "Start" to begin cooking, you have a shorting high voltage capacitor.
If it blows when you open or close the door, you have a loose or defective door switch or latch.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Nov 21, 2012 | Microwave Ovens
Sharps microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number (R-520JKF) here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Aug 21, 2008 | Microwave Ovens
"cook" on display
Please reply back with your brand and model number so we can help you.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Aug 10, 2008 | KitchenAid KCMS1555RSS Stainless Steel...
Microwave runs on its own
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 22, 2008 | Emerson MW8108P Microwave Oven
GE Profile Spacemaker 2.0 Microwave
If it goes dead or blows the breaker or GFI when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Jul 16, 2008 | GE Profile Spacemaker Over-the-Range...
Microwave light, turntable, and fan run after the door closes
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally by a problem on the control panel.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 29, 2008 | GE JVM1650 1000 Watts Microwave Oven
Nov 10, 2007 | GE JVM1350BW/WW/AW/SY Microwave Oven
Microwave oven
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Feel free to contact me directly if you have further questions. I appreciate your thoughtful rating of my reply.
Oct 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
