Question about Xerox WorkCentre PRO-215 All-In-One Laser Printer
Errur 47-215 Xerox WorkCentre PRO 128
  • 2072 Answers
SOURCE: Xerox Workcentre Pro 416 P
This would be the first thing to try..
  • Press the 0 and 8 keys simultaneously and switch on.
  • Input 400 using the numeric keys, and press the enter key.
  • Change displayed status counter to 0, and press the enter key.
  • Switch the machine off then on. Check that the machine returns to the normal standby mode. If the machine does not return to normal standby mode, perform the following checks.
  • Posted on Feb 18, 2008
    • 2072 Answers
    SOURCE: Xerox Workcenter Pro 657 Memory Error
    With a 657, most likely the main board has failed. It is not uncommon at all, That is a general problem with that model.
    What you can try is, looking from the front of the machine, the main board is located on the back right side. removing 2 screws and releasing the levers will allow you to slide the processor board out of the machine. You can try just reseating,,,, removing and shoving the board back into the machine, and seeing if that helps.
    Most likely, either the board has failed, or the memory battery had exceeded its life and the memory is not working.
    Wish I had a more positive answer for you, but the 657 is getting older, and those lithium batteries are failing. I have to add though, that those processor boards, have failed pretty frequently over the years.
    What you can do is go onto Google and look up "the parts drop" ,,, call them and ask for Britt, and see what he has as far as that producut is concerned. That machine is actually made byn Toshiba, you may be be able to find either a Xerox, or Toshiba repair dealer in your area that has that board and will fix it reasonably. If you find a Toshiba dealer other than a Xerox dealer. Tell them it is the same machine as a Toshiba E-120, they are exatly the same.
    Posted on Oct 17, 2008
    SOURCE: Is there a Mac workaround driver for the Xerox WorkCentre PE16
    Recently I had to configure a 17" Aluminum PowerBook and a Xerox Workcentre PE 16. That multifunction laser monochrome printer is not supported by MacOS X, but I tried all the same.... and no glue for that, until I went on the Samsung webpage and noticed their SCX-4216F printer. This machine is the same as the PE 16.
    So I downloaded the lastest drivers from Samsung's download centre (drivers for Tiger too), installed the drivers on the PowerBook (running 10.3.4), connected the printer and when I selected the printer ... tada! It automatically selected the Samsung driver, so I clicked on OK and started printing. Everything was OK!
    But it doesn't end here: even the Lexmark X215 MPF has the same chassis as the Xerox and Samsung. Yet, on Lexmark's website there are no Mac OS X drivers, but Samsung's drivers work just the same. I hope this hint will help others...
    Posted on Jan 26, 2009
    • 193 Answers
    SOURCE: how do I set up scan for my xerox workcentre pro
    go to xerox website..user guide
    when all else fails..follow the instructions
    Posted on Dec 03, 2009
    • 111 Answers
    SOURCE: Error code 39,003,40;61256 on a xerox workcentre
    Here is the easy solution to fix the issue :
    Click on the link and follow instructions to fix the issue.
    http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
    Posted on Apr 01, 2010
    Jam inxerox workcentre pro 128 copier finisher stapl area
    how do i repair a staple jam in my xerox workcentre 128?
    Jan 15, 2013 | Xerox WorkCentre Pro 123/128 Copier...
    Xerox WorkCentre Pro 123 linux driver ?
    if you open your web browser, put in
    www.xerox.co.uk, go to cusomer support then to suport and driver,
    there put
    • WorkCentre M123/M128 and then your operating system. From there you should find the driver package for the linux system
    Dec 06, 2017 | Xerox WorkCentre Pro 123/128 Printer
    Buna ziua, Am o mica problema. Am un echipament Xerox Workcentre 128 Pro, am instalat un sistem de operare Windows 7 pe x64. Problema este ca nu reusesc sa setez imprimanta sa imi scoata fata verso....
    In Windows 7 - Duplex printing in Xerox Workcenter 128:
    Go to the printer in your printer folder in control panel. Double-click on it then select menu option named "Printer" and click "Properties". Hope it helps you. It worked for me.
    Sep 06, 2011 | Xerox WorkCentre Pro 123/128 Printer
    Problem connecting Win 7 64-bit to Xerox Workcentre M128 printer - Windows is giving a "no suitable driver found" error.
    Try this link, it goes directly to the 64 bit driver download site.
    http://www.support.xerox.com/support/workcentre-pro-123-128/downloads/enus.html
    If that doesnt work. Go to www.xerox.com. Select support and drivers, in the search box, type 128, then go to the workcenterpro 123/128 and click on downloads and drivers.
    You will find 32, 64 bit drivers for all OS.
    Jan 27, 2011 | Xerox WorkCentre PRO 128 Copier
    Error 116-364
    Error 116-364 Problem with the Xerox WorkCentre Pro 123/128 Copier Finisher Staple Refills Copier. Dear i am also facing the same problem, It would be very helpful if you share the solution you may had come across. Thank you very much .
    May 17, 2010 | Xerox WorkCentre Pro 123/128 Copier...
    I have Xerox workcentre pro 128 copier machine and we don't know what the user name and password is. It was reset from default
    Service will have to come reset it. If you changed it from the default of login: 11111 and password of x-admin
    Sep 02, 2009 | Xerox WorkCentre PRO 128 Copier
    I have Xerox workcentre pro 128 copier machine. can you solve my problem? when i copy before appear this Error code 123-396.
    That is a software related error, You most likely need to reload the firmware, or replace the hard drive.
    You can try disconnecting all the document feed and scanner cables then reseating them. Other than that, your looking at a software issue.
    Jan 28, 2009 | Xerox WorkCentre PRO 128 Copier
    Xerox WorkCentre PRO-215 All-In-One Laser Printer Logo
    24 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
