Question about Sewing Machines
Bernina 165e: touchscreen is very hard to push (touch) sometimes takes 5 or 6 times to work
My Bernina 165e is getting very hard to touch on the touch screen. Especially when I have my embroidery machine hooked up on it. Any Suggestions, I feel like my finger is broke today where I used it 2 days ago. :) Thank You
  • Sewing Machines Master
  • 7,365 Answers
It would be a good idea to have the machine checked to see if
the circut board needs to be replaced.
Posted on Apr 25, 2013
Touchscreen is not responding Bernina Deco 600, machine has not been in use for a while can that be the problem?
I've read elsewhere that machines that have been idle for quite some time will take a while to turn on. The recommendation was to turn it on and leave it on for several hours.
Jun 27, 2017 | Bernina Sewing Machines
How do I change the light bulb on my Bernina 1530?
You might check out some of the older Bernina manuals to get an idea of how it may work in your machine. The 1260 is the closest manual available. Looks like your machine takes the same push-in bulb. So, you would push up on the bulb and twist. Then you would install the replacement the same way. Sometimes, using tight fitting medical gloves helps grip the bulb in order to twist.
BERNINA Sewing Systems
BTW--I have older Berninas and upgraded their bulbs to LED.
Oct 03, 2016 | Bernina Sewing Machines
Touch screen not working on new Bernina 560
Sometimes the touch screens can get accidentally re-calibrated incorrectly, and then will not work. It could also be a electrical defect, though this is rare with BERNINA products. I would recommend taking your machine back to the store that you bought it from to have it repaired. BERNINA machines come with a 5 year electronics warranty in the United States, so if it does happen to be an electrical defect, as long as your registered your warranty, this should be covered. If it is anything else, a BERNINA dealer should be able to re-calibrate or repair it fairly easily.
You can find a nearby BERNINA dealer at the attached link.
Find Dealer easily find your nearest BERNINA dealer BERNINA
May 08, 2014 | Bernina Sewing Machines
My Bernina Artista 170 Sewing Machine Touch Screen is not responding, Touch Screen just not working, Touch Screen is maybe cracked, can it be replaced ?
Maybe Cracked screen???
If broken, the screen is just like cellphone screen, digitizer is also broken and screen won't respond to screen touches... Find a trained repair shop. EmbroideryServices
Apr 20, 2014 | Bernina Artista 170
Bernina 165 touchscreen not working
It sounds like you may have two problems - one is easy, but without the other, its hard !!! If the touchscreen isn't working, it may simply be mis-calibrated and cant be accessed. To recalibrate the touchscreen from scratch, switch the machine on whilst, at the same time, pressing both of the two needle position buttons - the calibration screen should then come up and you should touch the screen where the dots are shown to recalibrate it. If, pressing the dots does not do anything, the probability is that your touch overlay or main control board is faulty, in which case you will need to take it to your Bernina agent. If you manage to re-calibrate the touchscreen OK, switch the machine off and back on again and if the display is still very grey but readable, you can adjust the contrast of the display by pressing the button with an arrow facing right, inside a box - this will take you to the user adjustment menu. Touch the display button that has a symbol with three vertical bars of different shades of grey and this will take you to a display that allows the brightness and contrast to be adjusted - touch the up or down buttons to get the best display contrast and once this is done, you should be all working again. Good Luck
Jul 02, 2012 | Sewing Machines
My wonderful Bernina 1130 has served me loyally since purchase in 1988, often being used every day when I worked as a dressmaker. In recent years full-time work keeps me from sewing. My faithful Bernina...
Contact an authorized Bernina dealer/repair center. The service technician can often tell what board needs to be worked on, take it out and send to Bernina. I just had to have work done on my 1130 and that is what was done. If that does not work, look up the number and call Bernina USA directly so they can direct you. While it's true that some parts are no longer obtainable, the machine boards can be serviced by Bernina USA. It's worth fixing.
Sep 29, 2010 | Bernina Virtuosa 160
Bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
scott
Jul 27, 2009 | Bernina Virtuosa 160
Bernina 200 e freezing
Ask them to replace the I/O print and make sure its upgraded to the latest firmware, also have them check or replace the motor depending on when you bought your machine these could be under warranty.
Jun 18, 2009 | Bernina Artista 180
Sewing Machines Logo
47 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
