Sharp es-s701x c2 error what the problem
Automatic stop c2 error
4 Suggested Answers
  • 6277 Answers
SOURCE: versanbuenaventura@yahoo.commy sharp ES-S701X washing machine
FixYa is sorry but this Forum does not supply parts, part numbers, prices or other details direct; it's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web. Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained on many makes and models, probably over many years ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Aug 01, 2011
SOURCE: My instruction manual of Sharp ES-S701X washing
I have a copy, can scan and email to you,let me know, kumanan1950@yahoo.com
Posted on Mar 08, 2010
  • 6277 Answers
SOURCE: MY Sharp ES-S601X washing machine
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
John C
Posted on Jul 10, 2011
Testimonial: "Thanks a lot. It helped and worked."
AEG dishwasher C2 error
Dear Sir:
Please read the instruction manual for to fix this error.
If you do not have go for free download: www. fitness.manualsonline.com or www. retrevo.com
see the wiring diagram for help.
May 07, 2012 | Dishwashers
C2 will not start
Willie,
My c2 vts 2007 is having the same problem. Did you find out what was wrong with your c2 and how to fix it?
Jan 11, 2012 | 2004 Citroen C2 VTS
FROM where i download lg d945gcr drivers
Try to download it from here
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GCCR
Or
Automatically detect or identify your drivers from here
http://www.intel.com/support/detect.htm?iid=dc_spotlight_home1
For further any help or to thank me mail me on my email ejaz89@live.com
Aug 06, 2010 | Intel D945GCCR Motherboard
Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Jul 29, 2010 | Washing Machines
Water is not pumped away, or stops in the middle of a cycle and displays one of a several error messages
Recall the error codes by activating the Automatic Diagnostic Test Mode to determine the cause of the problem. Select any one button, except Power, Start, and Stop, and follow this:
Press and hold the button for 3 seconds>Release the button for 3 seconds>Press and hold the button for 3 seconds>Release the button for 3 seconds>Press and hold the button for 3 seconds
All of the indicators on the console will light up for 5 seconds while 88 is displayed on the Estimated Time Remaining display. If not, repeat the step. Let us know if it cannot be activated.
The program then checks for any saved error codes after 5 seconds. List down the codes and post it back here. The console indicators will turn off then on with the 88 displayed if no error codes are recalled. After 5 seconds, the automatic test begins. The program performs a four-minute automatic test to check major washer functions. Press the same selected button in activating the automatic test above to advance through the automatic test steps.
  1. C0: The motor goes to a slow spin.
  2. C1: Warm water fills through the fresh dispenser and basket floats then disengage.
  3. C2: Cold water fills through the bleach valve for 10 seconds.
  4. C3: Hot water fills through the fabric softener valve for 10 seconds.
  5. C4: Warm water fills through the detergent valve for 10 seconds.
  6. C5: Agitates for 15 seconds.
  7. C6: Recirculates for 10 seconds.
  8. C7: Drains to engage basket and drain further for 10 seconds.
  9. C8: Drains and spins slowly.
  10. C9: Coasts to stop.
  11. Press the Stop or Power button to cancel/exit the test.
Inform us about the result of the test for the repair guide if necessary.
Feb 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
C2 error
aeg lavamar error c2
Dec 25, 2008 | Maytag NFW7200TW Front Load Washer
Burning audio
http://www.custcenter.com/cgi-bin/sonypictures.cfg/php/enduser/std_alp.php?p_sid=CAwJNDkj&p_lva=&p_li=&p_accessibility=0&p_redirect=&p_page=1&p_cv=&p_pv=1.7&p_prods=7&p_cats=0&p_hidden_prods=&prod_lvl1=7&prod_lvl2=0&cat_lvl1=0&p_search_text=cds+paly&srch_btn_submit=%C2%A0%C2%A0%C2%A0Search%C2%A0%C2%A0%C2%A0&p_new_search=1
Pick "Close disk after burning"
Use a 74-minute disc instead of an 80-minute disc
Burn at a slower rate
Dec 05, 2008 | Sony ACID Pro 5 for PC
Hp wireless assistant 3.00 C2
You may install a different version but it is not guarantee that it would work. I suggest to connect your system to an ethernet cord (wired connection) then click on the link below..
http://tinyurl.com/6jlcth
You should see there Start Detection - it will automatically detect the system driver you have. You should select the operating system then you may reinstall the network driver then.
Keep me posted.
Thanks
Nov 20, 2008 | HP Pavilion dv6000z Notebook
Transferring..........
hi
this might help try here for the manual http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_alp.php?p_sid=wPB6U3Ri&p_lva=61&p_li=&p_accessibility=0&p_redirect=&p_page=1&p_cv=1.187&p_pv=&p_prods=0&p_cats=187&p_hidden_prods=&prod_lvl1=0&cat_lvl1=187&p_search_text=Nikon+COOLPIX+L3&srch_btn_submit=%C2%A0%C2%A0%C2%A0Search%C2%A0%C2%A0%C2%A0&p_new_search=1&p_search_type=answers.search_nl
riz.
Nov 18, 2007 | Nikon COOLPIX L3 Digital Camera
Washing Machines Logo
302 people viewed this question
Top Washing Machines Experts
