Question about Philips 42PF9630A 42 in. Plasma Television
Red light Permanent red line down right side of tv
    Top Expert:
  • Philips Master
  • 74,136 Answers
Sounds like the main board is faulty. No SDA - SCL signals.
Posted on Apr 25, 2013
Testimonial: "What does that mean no sda or scl signal can it be repaired"
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
My TV looks like it had permanent 3-D. Red Ghost
hello it sound like the convergance ic may be the problem these chips sit behind the tuner board connected to a metal frame called a heat sink they are soldered in. also you will have to check the resistor in front of the chips also check the 2 capacitors at either end it would be best to get a quote from and engineer good luck
regards
shaun
Jul 10, 2010 | Sony KP-51WS510 51" Rear Projection...
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
I have a black line down the right side of my LCD tv.
unfortuatly yes its permanent ts caled a burn mark
Mar 14, 2009 | Vizio VO47L 47 in. LCD TV
Vertical red line, tv turns off
If your looking to service this set yourself you need to open the back cover and look down on the main pcboard with a flash light if you see any liquid damage it's more then likely your CRT's are leaking coolent fluid on to the main PC board, Common problem with most CRT projection TV's manufatured today, main board needs to be cleaned and the CRT's need to be sealed,
Feb 25, 2008 | Samsung HC-P5241W 52" Rear Projection...
Permanent Red Line Down the left side of the screen
This can't be repaired, the LCD panel is a sealed unit. if you can't live with it then you need a new monitor
Feb 20, 2008 | HP Pavilion F1703 17" LCD Monitor
Philips 42PF9630A 42 in. Plasma Television Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
