Question about LG 50PS60 50 in. Plasma HDTV
Fuzzy picture When turning my 50" TV on the picture is fuzzy then it shuts of. Whats the cause
    Top Expert:
  • LG Master
  • 74,118 Answers
There can be many reasons for this fault. A through checkup is necessary. Contact any experienced service technician. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window. Faults and its reasons to Plasma TVs are described in detail with screen shots. http://electronicshelponline.blogspot.com/
Posted on Apr 25, 2013
Hitachi tv turns on then gets bad picture than turns off blue light blinking
The name of the part is probably "buffer board" and there are two in your TV - upper buffer and lower buffer, also called SDR-U and SDR-L boards.
Those are the two most common sources of problems in P50S601 along with the Y sustain board (SD board in hitachi and Panasonic terminology), which sometimes gets damaged by the failed buffer board.
In the buffer boards market there are all kinds of offerrings. There are old buffers for around $130 for the pair and there are new buffers in the range $160-$200 for the pair.
In my opinion if the difference is barely $30-$40 one is better off going for the brand new ones.
Here's a link to our title for them, you can sure find others if you start from it:
http://www.coppelltvrepair.com/p/182/hitachi-nd60200-0048-and-nd60200-0049-replacement-set-of-buffer-boards
Hope this helps!
Dec 15, 2012 | Hitachi Ultravision P50S601 50 in. Plasma...
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
My tv, just shut off! the screen does not turn on, and makes a squealing noise! what is wrong?
That is the classic case of the color wheel going out on you. The color wheel has ball barrings that tend to break and cause friction within the wheel. It'll start squealing loudly when it becomes stuck. Before it broke, did you notice the color going out or a fuzzy picture with poor skin tones? That's the color wheel!
Feb 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung LCD cm07 good then bad picture, powers off and on
well this could be a power supply issue try this web site they could have the part www.discount-merchant.com
Ness
Jan 05, 2010 | Samsung HLN5065W 50" Rear Projection...
I have a Sharp 32" Standard TV ... picture will get fuzzy either due to someone walking by or sometimes if sound coming from tv is vibrating. If we shut tv off and turn it back on it is clear again. The...
Hello: Your problem seems to be in or around the tuner of the television, More then likely you have cold solder joints on the turner that needs to be resoldered. Also check the coax end protruding from the back of the set where u connect the cable and make sure it is not loose, a bad ground on this connector to the turner shield will cause this symptom. My professional diagnostic is that when the television is cold the solder connections are making contact with the board, and as heat builds up in the television while watching these connections tend to seperate and make limited contact, causing fuzzy picture and in most cases no picture just snow...
Sep 06, 2009 | Sharp 32C-240 32" TV
Has fuzzy spots all the way across the screen and just scrolls up
Is the picture fuzzy whether you are waching tv or a dvd or a tape. If it's only fuzzy on tv or dvd or tape then it's the source. If all inputs are fuzzy suspect a bad tv.
Apr 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Toshiba 32" tv wont give sharp picture (other tv does)
try to replace filter capacitor from power supply and in horizontal section.
Jan 26, 2009 | Toshiba 36A50 36" TV
Picture looks like a Colored Negative
so, how can i fix this problem with my tv. the tv comes on but the colors look fuzzy..help!!
Oct 27, 2008 | Syntax Olevia 50" Rear Projection...
Fuzzy and discolored picture
check into the tv color circuit and related circuit,the IF circuit must be checked also.good luck.
Apr 06, 2007 | Philips 9P5034C 50" Rear Projection...
LG 50PS60 50 in. Plasma HDTV Logo
Computer Repairing
Computer Repairing
