Door wont open on Hotpoint WM51 First Edition
The door latch cover on my washing machine is broken in half and recently the door burst open a couple of times half way through a spin cycle, so I decided to replace it. Last night I fitted the replacement (http://www.tdspares.co.uk/proddetail.asp?prod=lck1019) and closed the door to test it. The door closed fine but then it wouldnt open! I tugged and tugged at it and still it wouldnt budge. In the end I had to push a screwdriver between the door and the machine to poke at the latch to open it. Im now starting to think that the original door latch cover was broken in a similar circumstance - the door wouldnt open and the previous owners tugged at it until it snapped. Can anyone suggest why the door wont open?
    President:
  • Washing Mach... Master
  • 662 Answers
This is a common and easily fixed problem. The door should NOT be opened after the wash is completed. You have to wait for AT LEAST 2 minutes to try the door, do not use force. There is a built in mechanism for most front loaders to delay the door opening, so be patient.
In your case you might have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Posted on Apr 25, 2013
  • 8 Answers
SOURCE: DOOR WONT OPEN
Hi. Try un-pluging machine,take off top lid slide your hand down between casing and drum until you find lock, then try flicking door casp while trying to open door gentely. when open replace door lock before using again.
Slim jim
Posted on Nov 26, 2007
SOURCE: Washer door won't open (hotpoint first editon 800)
I have just had exactly the same problem. 10 seconds of washing, fuse blew, replaced it, cycle completed but now the door lock is stuck on. Like you I tried a new cycle but this has done nothing. In the end (and I'm not suggesting that this a remedy to the problem) I unplugged the machine - pulled the door handle til a gap appeared at the top of the door and forced it open by working a pair of scissors in to the gap and pulling. Of course as soon as I shut the door again and turned on the power the lock light came straight back on the and the door was locked tight. Sorry but this is the best I have come up with short of calling some one out.
Posted on Aug 20, 2008
gittos73
  • 244 Answers
SOURCE: Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Posted on Dec 16, 2008
SOURCE: My Hotpoint Aqualtis washing machine
My Aqualtis just stopped mid program with F-05 on the display. This is apparently a failure to drain properly. I was luckily able to hold the power button to cancel the current program drain the water out (very slowly) and empty the machine.
THIS IS HOW I RESOLVED MY PROBLEM.
Disconnect the machine from the mains. Turn off the water supply to the machine. Disconnect the cold water pipe from the machine at the top corner.(Watch out for some water) Remove the drain hose from where you have it going to.  Pull the machine out and lay it gently down on the left side panel (use a towel to protect the side and absorb any water). Then, from the now exposed underside there is a black rubber pipe connected to the pump (black) coming from the main drum. Use some pliers to pinch the steel spring that clamps the hose in place and remove. Then using your fingers (there is nothing sharp in there) see if you can find any blockage.
I REMOVED: A pound coin, a dairylea slice wrapper and a piece of kinder bueno packet.
Carefully replace the black hose making sure it is fully on. Replace the drain hose, reconnect the water pipe and turn the water back on. (check to see it's dry with no leaks). Plug it in, turn on and that for me was it. Job Done.
Posted on Feb 01, 2009
SOURCE: Hotpoint WM51 Washing Machine keeps tripping the electric
I had this problem; it was the motor arthing out on the body. It took a repair man half an hour to sort and it cost me £35. Hope this helps. Domo.
Posted on Feb 08, 2009
Hotpoint wm51
get a new lock they are cheap
Apr 15, 2014 | Hotpoint First Edition FEW12 Front Load...
HOTPOINT FIRST EDITION 800 WM51 USER MANUAL?
my hotpoint first edition 800 wm51 wont spin?
Nov 17, 2010 | Washing Machines
Hotpoint electronic 800 delux 9525. can not open the door help
Make sure there is no water left inside washer.
If it still will not open, then you need to remove the top cover, and release the door manually from inside at the front where the door latches in.
Can be caused by the belt being off the pulley,or a broken ****** assy.
Jan 12, 2010 | Hotpoint Washing Machines
Washing machine door wont open - hotpoint
Never reach inside the washing machine with it connected to the mains. The door interlock is always live.
There are several reasons why a Hotpoint door could be jammed shut.
•A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoints - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
•If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
•A faulty door interlock
•The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunge can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thanks for contacting fixya.com
Nov 07, 2009 | Hotpoint First Edition FEW12 Front Load...
How do i open the door on hotpoint WD440, latch is broken?
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Please rate my solution.
Thanks.
Nov 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Jan 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Ok that rules out the heating element. There are a number of possible causes so bear with me while i go through them.
Can you open the door? If so leave it open then turn on the machine. Does it trip?
Jan 23, 2009 | Hotpoint First Edition FEW12 Front Load...
Door opening.
If the door will not open , then you could have a faulty door interlock, or door handle or door latch mechanism.
Try thumping the door where it latches in, if no joy then door is going to have to be forcibly opened.
Also try switching power on and off a couple of times
Dec 05, 2008 | Hotpoint First Edition WMA12 Front Load...
Door of washing machine will not open.
Some times, you have to really pull hard to open the door
If no joy, then you have a faulty door lock.
To replace. remove door seal at front, thius will give you access to the door lock.
Nov 18, 2008 | Hotpoint First Edition FEW12 Front Load...
WF100 door wont open
The interlock has jammed, first try gently pushing the door frame on the latch side of the door and then hit the outer door frame with your fist, not too hard but a reasonable bang this may release the door, if this works spray a lubricant into the latch hole in the panel, open and close the door a few times before reusing, if this fails then you have to force the door open, the best way is to remove the lid and manouver the door lock from the inside, either the lock or the latck will eventually break, this is unavoidable, then replace the interlock and any other broken part.
Regards
Advisor
Nov 17, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
