Question about Dryers
Beam vacuum repair manual
I have a beam condovac model 166 when i turn it on i just hear a humming sound and then smoke starts coming from motor do i have to replace the hole thing
  • 1314 Answers
SOURCE: Dryer problem
you need to either clean or replace the drive motor motors have two windings start and run windings both windings kick in on start up then the centrifugal switch kicks the start windings out and the run windings take over if nothing is jamming the tub go to the motor sme times getting the lint out of the switches and motor will fix it if not replace it
Posted on Jan 18, 2008
  • 8 Answers
SOURCE: Whirlpool top loader won't spin and I replaced the motor and the coupling too
If your basket appears to be off-center in the opening, and there is evidence of the basket rubbing the front of the plastic tub, then you should check out my post at:
http://www.fixya.com/support/t1254687-duet_washer_very_loud_when_spinning
If this is what happened to your washer, the 'burning smell' you refered to was the plastic tub getting hot from the rubbing of the basket (mine smelled the same way, I originally thought there was an electrical failure).
Posted on Nov 18, 2008
  • 247 Answers
SOURCE: Why is my 2000 Toyota Camry making a Humming sound
when have you had tires put on last? you might be hearing them.
Posted on Dec 21, 2008
  • 44 Answers
SOURCE: Repair manual for Electrolux EPIC 6500 SR
I don't have a manual for these but the trickiest thing about these units is taking them apart. If you have an Aerus/Electrolux dealer near you, it's not a bad investment to have them install the motor for you. You would probably receive a warranty with the work, and the things a long time. Great return on investment. But if you are determined to do it yourself, open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. Good Luck!!
Posted on Jan 01, 2009
  • 1214 Answers
SOURCE: Brush does not turn on my vaccum
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Posted on Jan 22, 2009
Why My Hobart A200 20 QT Mixer ML #104858 Motor Is Smoking?
I think... without knowing that motor... that the capacitor is a start capacitor, and that the start switch may be trying to "start" the motor full-time instead of switching it out of circuit after it figures that the motor has spun up. I may be wrong - that design may be a capacitor-run motor (similar to a three-phase motor) - but I'm betting it's a start-only capacitor.
If you know someone with a capacitance meter, you could check the capacitor - for both capacitance (to be sure it matches the label) and leakage. Easy way to write that one off. Alternatively, you could rig it such that after the motor's wound up you could manually disconnect the capacitor and see what happens - either the motor stops or else the smoking issue stops.
Whatever you do, don't let it smoke very long. The varnish on the windings is only so thick.
Jul 31, 2014 | Hobart A200 Stand Mixer
My dishwasher starts humming in middle of cycle and wont go further the rinse cycle works fine
Hello & Welcome to FixYa
Either of these two things can cause this problem: first is the timer motor, if the sound is coming from the control then the timer needs replacement. If the humming comes from the bottom of the unit then it is the motor that needs replacement. When the motor won't work you usually hear humming sound and replacing the motor is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 14, 2011 | Whirlpool 24 in. ADP5966 Free-standing...
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
f you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 18, 2011 | Kenmore Dryers
DThere is a humming sound that comes from the inside. The hum is not consistent but comes and goes.
freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Sep 10, 2010 | Amana ABB1927DE Bottom Freezer...
I have Hoover Widepath Bagless 12 Amp Windtunnel vacuum. Yesterday I was vacuuming and smelled smoke and it shut itself off. Today I cleaned out the filters (they weren't bad) made sure nothing was...
Hi There,
When a vacuum cleaner smokes, it is usually only one of two possible problems.
It could either be that your motor burned up, or that your belts burned. The belts on this particular model are notorious for breaking, but the fact that your machine doesn't come on at all after this happened, sounds like it may be the motor.
Both of these issues have a unique smelling smoke. If the smoke smelled like an electrical burning smell, this indicates it's your motor. If the smoke smelled more like burning rubber, then it's probably your belts.
If the smoke smelled like burning rubber, here's a video that we've recorded showing step by step how to inspect, trouble shoot, and replace the belts on your vacuum cleaner. If you open it up and the belts are still in tact, then this probably is a more serious problem of the motor burning out.
. I'd be more then happy to walk you through more advanced diagnosing if this doesn't fix your problem, please just use the comment box here on the Fixya repair page.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me. This is really appreciated by the Fixya community if the repair solution was able to fix your problem.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Smoke comes out when turned on and weak hum
The motor winding has probably shorted to the stator metal, or the armatur has shorted. You'll need a new motor.
Nov 25, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
I own a Hoover Steam Vac Plus w/ Rotating Brushes (model#F5871-900), when I turn on the power I hear a medium-loud hum coming from the motor area and nothing works. What could be the issue?
the motor sounds locked up. Water gets in there and rusts the pieces together. The motor could be replaced, but probably not repaired.
Jul 04, 2009 | Vacuums
Smoke coming out of my Kenmore Canister Vacuum Model 22550300C
Sounds like a motor err. Could be repaired by a professional but it never be as good as a new one. Also they you might not find anyone to repair it because the replacement motor might cost more than a new vacuum /considering it's age the motor will be hard to find and that makes it more expensive to repair./
I suggest you to buy a new vacuum.
Feb 16, 2009 | Kenmore Vacuums
Motor won't turn on
It sounds like you have a motor problem there. I don't know how old your machine is, but if it is still under warranty, don't explore any further as you will void your warranty. This problem sounds like a carbon brush problem and you will not be able to address it yourself unless you know your way around an electrical motor. The carbon brushes can stick or become jammed and once they are loosened up, they need to be reseated or the motor will burn out. You will not be able to do this yourself. These motors generally have 5 to 12 year warranties and yours may still be under warranty. If your machine is over 10 years old, the carbs are probably worn out and the motor will require repair or replacement. You should refer to a competent tech for help.
Jan 13, 2008 | Beam Industries 2775 Serenity Plus Central...
Dryers Logo
52 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
