Question about RCA F32668 32" TV
32" model# F32668
When I try to turn tv on it just clicks and does not come on, just keeps clicking no picture no sound --- clicks on clicks off a little help???
  • 398 Answers
The F32668 uses the CTC203 series chassis and I usually see 2 problems when the set will not run. The first is poor solder joints on a small coil near the horizontal output transistor, but if thats the case the set tends to run for a while and randomly shut off. When the set clicks and never runs I usually find that the flyback (high voltage) transformer has shorted out inside. In this case the flyback should be replaced by an experienced tech.
Posted on Aug 07, 2007
SOURCE:
Hello, I have a Magnavox tv 32" model 32mt3305/17.
you should bye a surge potecter power cord.surges happens all the time and destroys electronics
Aug 17, 2013 | Philips Magnavox 27MS343S 27" TV
Will not come on it only a clicking sound from part no. 0mron 0584H3
I had the same problem with my tv, same make and model. I first continuously turn on and off my tv manually until I could get some kind of picture. This procedure took maybe five minutes. I was able to get a fine picture and sound, as if it was brand new! Other things to keep in mind, try to eliminate dust build up as much as possible.. Hope this helps out...
May 21, 2009 | Philips Magnavox 27MS343S 27" TV
RCA TV, model number 32V550T. No picture but sound is fine.
hiya
this sometimes is quite simple to fix as it cud be a dry joint on the circuit board where the tube motor sits.
or it cud be the tube is on its way out, which wud be cheaper to buy a new tv rather than have it fixed
rik
Feb 24, 2009 | RCA 32V550T 32" TV
RCA 32v430t
peanut36,
Bad HV transformer = RCA part # 271996.......................T.
fermin,
Please log on to Toshiba rear projection Television>>>>>>>>>
turbo5150,
The exact same problem with ? = Make & Model,please....T.
Dec 17, 2007 | RCA F32650 32" TV
RCA F32668 model tv flicking channels on its own
Tuner Has Bad Solder Connections Internally
Nov 12, 2007 | RCA F32668 32" TV
Rca direct view tv 36" f36665
clicking,w/no sound or pix is usually IHVT, AKA flyback transformer.Please clarify size and model #. Include last three characters in Thomson products service #---Ex.=F36665-YX01.
Oct 02, 2007 | RCA 32F531T 32" TV
TV Repair
check the vertical section thats small parts like resistor 19k or 22k that all resistor is change value or check all the small capacitor around the vertical section.
Sep 06, 2007 | RCA F32668 32" TV
Flicking Channels
I HAVE THE SAME TV WITH THE SAME PROBLEM. I'M NO TECHNICIAN BUT I TOOK THE BACK OFF AND DISCONNECTED THE CIRCUIT BOARD THAT CONTROLS THE REMOTE SENSOR AND THE BUTTONS. THE TV STOPPED FLIPPING BY ITSELF. I'M CURRENTLY TRYING TO FIND A REPLACEMENT PART.
Aug 28, 2007 | RCA F32668 32" TV
No picture and clicking sound only
This may be a power supply problem or a shorted horizontal output transistor shorted. The clicking sound is the power supply trying to start but can't because of the overload. Stargazer
Feb 17, 2007 | Curtis CM32020S 32" TV
No picture or sound
If you had a burning smell, well the board is toast. These sets are made to replace the entire board at one time. Before installing the replacement module, the picture tube should be checked. A defective picture tube ( such as a G1 short) may cause a failure in the power supply section.
Sep 07, 2006 | Zenith C32V36 32" TV
RCA F32668 32" TV Logo
197 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
