Question about HP iPAQ H5555 Pocket PC
Ipaq h5555 I have a used IPAQ H5555 that was given to me by my brother. He stopped using it about a year ago. I plugged it in to charge and the screen flashed very breifly, less than one sec) and now nothing happens at all. No charge lights, no power on. I have tried both hard and soft resets to no avail. Help please.
  • Mike Burnside Aug 07, 2007
    Shouldn't the unit work while plugged in even if it has a dead battery?
    Problem Solver:
  • 19 Answers
I battery dead ? In some case, ipaq battery dead will not start. ================
Posted on Aug 07, 2007
  • Paulin Lai
    Paulin Lai Aug 07, 2007
    If what you said is making any sence, plug in the power and remove the battery to see if it is working ?
    In my ipaq with dead battery does not !
SOURCE:
My ipaq h5555 wont let me get past the align screen feature. Can any one help?
do a reset ( like full rese) or if you dont want to leave it off for a few hours and turn it back on AND DONT GO TO THAT SCREEN
May 06, 2010 | HP iPAQ H5555 Pocket PC
IPAQ wireless connectivity
always start with the simplest answer first so make sure you have WiFi turned on. Think back, have you changed the wireless security on your router? If so you may need to re-enter the network details or add your iPAQ's MAC address to the access control list on the router. In the bottom right-hand corner of the home screen you should have a small HP Wireless symbol, if you tap it you should get your HP Wireless control panel on screen and can 1: turn WiFi on and off, 2: manually enter the WiFi network details and 3: search for WiFi networks in range.
Aug 16, 2007 | HP iPAQ H5555 Pocket PC
IPAQ H5555 connection problems
Hi, This could be due to a few issues, try these soloutions in order below: 1) If you have a jacket connected to the ipaq it could be preventing the ipaq from locating correctly on the connector. Remove jacket and try insering again. 2) Check that active sync is set up to detect the device on the usb port. The cradle for the ipaq may have a serial and usb connector. Ensure that just the usb connector is attached to your laptop. Try connecting again. 3) You may need to uninstall the USB cradle if it was connected before installing active sync. Try the following steps if this was the case: a) unplug the USB cradle b) uninstall active sync c)Click start then click control pannel then click system. Then click on the hardware tab. Look for the device under USB, right click on the device and then select uninstall. d) restart the laptop e) Install active sync f) ONLY after active sync has installed you can now plug the cradle back into the usb socket. g) Now connect the ipaq, it should now detect it.
Aug 09, 2007 | HP iPAQ H5555 Pocket PC
Bluetooth Mouse for IPAQ
Yes, see this review from Dave's Ipaq..... http://davesipaq.com/articles/iPAQ_technology_Think%20Outside_Stowaway%20 Bluetooth%20Mouse.html
Sep 14, 2005 | HP iPAQ H5555 Pocket PC
Uninstall games on iPAQ h5555
What you can do is delete the icons by using File Explorer to navigate to \Windows\Start Menu and delete the Games group, or just delete the icons within the \Windows\Start Menu\Games group. That won't remove them from the machine and they will be back after a hard reset, but it will make them invisible.
Sep 12, 2005 | HP iPAQ H5555 Pocket PC
HP IPAQ 5555 1.10.13 ROM UPDATE
I thought my 5555 with 1.10.10 was the latest and most stable?? How come i didnt know about 1.10.13 ROM Update... Anyway, i think it is your Camera Update that causes it. But to confirm, which ROM are you using now? Go to "Start" >> Settings >> "Asset Viewer" >> Under Version >> check the ROM Revision. 1.10.10 had no major problems, only sometimes when i couldnt connect to my wireless router / bluetooth problems, but now it is okay, dun worry.
Just "turned off"....
Was it charging over the weekend? If not, try to recharge the device again... Those devices would on occasion drain the batter overnight -- didn't happen all the time and was apparently caused by unusual software/applications combinations... The battery could be going bad again as well.
Sep 08, 2005 | HP iPAQ H5555 Pocket PC
My iPAQ will not charge or turn on ...
Can you get the iPaq hooked up directly to AC power? There's apparently a charging threshhold for badly depleted batteries that the USB port cannot get over.
H5555 sync problem
When you attach your ipaq, you should be able to go into My Computer and view the ipaq as a removable storage device, seeing the actual files and folders located on your ipaq. I would attempt to transfer the files via copy and past if Activesync cannot do it. If that solves the problem then its simply that Activesync is encountering some sort of memory overflow, if it still cannot sync then there is a problem with transfer protocol its using.
Sep 07, 2005 | HP iPAQ H5555 Pocket PC
H5555 password rest
For anyone coming across this with the same problem the solution is probably going to be reflashing the ROM. If you don?t have the CD you can usually buy one on Ebay for $5.
HP iPAQ H5555 Pocket PC Logo
262 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
