Question about Onkyo Audio Players & Recorders
Sound problems with an Onkyo receiver and a FIOS Set Top Box
I purchased an Onkyo receiver less than 24 hours ago, and after setting it up everything was working as it should. Then, late last night the sound for the FIOS dropped put when using the receiver. I can hear part of what makes up the sound, but main forward noise (speaking, etc) is completely silent. I've changed the port that the FIOS box is connected to, I've swapped HDMI cables with other devices (PS3, Wii U, ETC) that all work perfectly with the Onkyo. I've done a factory reset a couple of times, and nothing seems to work. Oddly enough, passthrough with the TV's main speakers works fine and I get all the sound that way.
    Genius:
  • Onkyo Master
  • 1,054 Answers
If you are not hearing dialogue, then check your center speaker. Most voice tracks are routed to the center channel
Posted on Apr 06, 2017
5 Suggested Answers
CremeStout
  • 115 Answers
SOURCE: Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Posted on Dec 03, 2007
SOURCE: Onkyo 805 sub hook up problem
I made the same mistake when i hooked my REL sub up to the back of the 805.
The problem is there are 2 connectors on the back of the amp that are labeled as sub out. Look very closely, you will see that there are 2 grouped RCA outs. The RCA out group you are looking for differentiated by groups of "little white dots" all the way to the far right on the back of the amp. Hope this helps.
Posted on Jun 09, 2008
SOURCE: Setting up Cable with HDMI
Yes, the firmware on your hdtv box has an old firmware, I switched my old hdtv box with a newer one box and the problem was solved. It seems that it can't work if your hooking up with DVI to HDMI cable to your receiver to tv. Your hd box must have an HDMI out otherwise it causes problems. I also have rx-v661 and i finally hooked up everything HDMI to the receiver and then to the tv and it was having the problem you speak of. After I switched out the hd box for a newer one everthing worked fine.
Posted on Jan 22, 2009
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Feb 20, 2010 | Samsung Audio Players & Recorders
Onkyo 876 with hdmi from blu-ray sound is fantastic video poor
Get a THX video set up disk (some movies have them on) and read the Onkyo manual for video setup between source and target. I have the BD35 Blu ray and a Panasonc 37" plasma, the pic via the amp was a bit off before the 4 hours of tweaking but now looks fab, after the process tweaks the sound sync needed a bit of work to get it all synched up but it is really worth the effort.
May 19, 2009 | Onkyo TX-SR875 Receiver
No sound is coming through my Onkyo receiver from the cable box
The Playstation 3 automatically broadcasts video and audio through HDMI even when an optical audio cable is ran to the receiver. If your TV has an optical audio out, it's just best to run everything into the TV including audio, and then run the optical cable from the TV to the reciever. It's less confusing and less buttons/remotes you have to use when you want to change devices, i.e. Cable/PS3/DVD
Feb 17, 2009 | Onkyo TX-SR606 Receiver
Ittermittent digital audio drop out on some channels
Did the issue ever get resolved. I have similar issues with a connection to Cox Cable HDTV and Onkyo TX-DX989. All sources (DVD Player) sound fine and not issues except channels 706 and 710 on Cox Digital receiver. I had Cox replace the HDTV receiver and the same issue occurs. I've tried optical audio and also the COAX audio ports with the same issue. The workaround I have found is to set the audio to "Other" on the Cox box, but the volume then has to be turned up quite a bit.
Jan 16, 2009 | Onkyo TX-DS989 Receiver
Onkyo tx sr875 NO SOUND!!!
Check speaker cables are in the right way as ONKYO amps have the conections side by side not up and down like most amps,also if you are useing hdmi leads go to the hardware set up in the menu and turn off the audio out for hdmi.
hope this helps.
CABLE GUY.
Jul 01, 2008 | Onkyo TX-SR875 Receiver
Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Jun 01, 2008 | Onkyo TX-SR702 Receiver
Code for Verizon FIOS remote Control
I have a solution which has worked well for me. It uses the DVD button at the top of the remote. It was a trade-off as none of the codes in the RC144 Philips remote will work any Blu-ray players, so the DVD button was unassigned. The 922, 955 and 977 codes are explained in the directions for the FIOS remote. http://onlinehelp.verizon.net/consumer/bin/pdf/philips%20rc1445302%20user%20guide.pdf
1. Set up your TV button to work your TV.
2. Set up your Onkyo code, pick one to turn on the receiver. I used 3719
3. Use the 9-2-2 code to cycle through all available codes. At about a count of 300 I found one which will turn the Onkyo receiver off. Make sure you start this process with the ONKYO receiver already on. Once you find it press the OK button.
4. Use the 9-7-7 code to power all devices TV, AUX and DVD from the power button.
In this way, each time the power button is pressed it will send both the power on and power off signal to the ONKYO receiver.
This technique works well when you point the remote at the ONKYO receiver and press power button. Apparently the TV has better reception for the signal then the ONKYO does.
Oct 24, 2007 | Onkyo TX-SR605 Receiver
78 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
