Question about Patio Heaters
Where can I find a replacement part for the mantle screen?
Model #hss-dghd
Fan will not shut off what could be the problem?
if its the original model number without an b at the end it is supposed to shut off, if it is the 4604b the added a feature to keep the fan running anytime power was on to keep it from burning up the power strip, this was a temporary fix, i just picked up a new on tonight under warranty and it has a feature that lets the fan run for a while and then shut off, the newest model number is HA24-50m, is is the same heater as original but now only has 5000w and 3000w options on switch, good luck finding a listing but this is the heater northern tools gives you when they replace the 4604. im pretty computer savvy and i can not find any site that is for profusion heaters as a company, here is a number for tech support you can call, 1-866-206-0888
Oct 19, 2016 | ProFusion Heat ProFusion Ceiling-Mount...
My iheater (iH1500) seems to be missing a fusable link located in the back center of the unit. Can I get one to replace it. The unit doesn't power up.
If you believe it is not powering up because of a blown or missing fusible link, you can simply BYPASS the fusible link with a (large) piece of wire, briefly turning the power on to test the unit. If the unit powers up with the bypass wire (and it does not blow the fuse or breaker to that outlet)... leave the bypass wire there!
May 14, 2015 | IHeater 1500 Advanced Infrared Heater...
Patio heater fell over and now not working could it be the flame screen needs to be replaced
????????????????????????? Whatevers Broken / Damaged needs replacing
Mar 14, 2015 | Patio Heaters
Patio Heater Garden Sun model JDS04SS After lighting the jets all lightup but within minutes only half the jets stay alight. Is this dangerous? the heater is a couple of years old.Can it be repaired and...
Your heater needs to be cleaned & adjusted. Contact your gas supplier for information, as to do they do the service or have someone they recommend. You will probably have to bring it in.
Oct 22, 2014 | Patio Heaters
Where to get a copper gas line for Endless Summer 230000 Patio Heater?
Could you use a compression fitting across the break? If you can take a piece of the tubing to local hardware/auto store for sizing to see how snug the brass ring is.
Oct 21, 2014 | Patio Heaters
Why won't my patio heater light
The thermocouple has to be in contact with the flame at all times when pilot is lit, this heats up and sends mill-volts back to the safety valve to keep the gas on, if not it won't let the gas through, otherwise you need to clean the pilot or replace the thermocouple if everything else is ok..
Aug 29, 2014 | Patio Heaters
What is a thermocouple replacement for patio heater metric threads
Not sure, Most universal kits will work. Take old one with to get replcement, sometimes depends on milli-volt out put also.
Aug 17, 2014 | Patio Heaters
Pilot light bright yellow
Need to clean or replace it,supply tanks is empty, low pressure,bad regulator, not enough air supply etc. Kinked supply lines.?
Jul 20, 2014 | Patio Heaters
No Flame
It could be dirty nozzle or dirty line
Unscrew every thing in the nozzle and control valve section and clean gas line and reinstall and try it
Nov 18, 2013 | Fire Sense 60803 Patio Heater
Heater runs 1 cycle then turns off
Replaced 301 80C 16A thermostat, purchased on ebay for $6.00, fixed problem. to Fix standing at front, Remove left side panel, two small screws hold thermostat in place. LifeSmart wants $36.00 for same part. Fixed problem.
Oct 18, 2013 | Lifesmart Renew Infrared Quartz Heater...
Patio Heaters Logo
209 people viewed this question
Top Patio Heaters Experts
deton8 von Splosion
Lawrence Oravetz
Tom Chichester
Are you a Patio Heater Expert? Answer questions, earn points and help others
