Question about RCA L32HD41 LCD TV
Horizontal lines My tv have horizontal lines from 3/4 down to the bottom and once its on the tv clears up and then plays good as long as its on once turn off it goes back fuzzy and snowy like i change main and t con board i really dont see anything wrong with the power supply but then again i also read that it could be the lcd panel thats bad
    Top Expert:
  • RCA Master
  • 74,383 Answers
It sounds that the main power supply regulator board has the fault. Replace all the large electrolytic capacitors on that circuit board, or replace it with a new board as card basis.
Posted on Apr 25, 2013
  • jazz Apr 26, 2013
    Are they 2 biggest ones on the board rite cause like i said it comes on the no signal but on the screen cause i dont have the cable hook up and the no signal but like fuzzy running down smear like then after 10 min it goes away the plays clear
  • 8457 Answers
SOURCE: screen goes blank but come back when TV is turned off and back on
Ur tv LCD inverter board it dead.Replaced this LCD inverter board ur tv picture will return.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 14, 2010
MNfisherman
  • 11896 Answers
SOURCE: tv shut down and wont power back up, but circuits stay powered up
Check to see that the fuse is good. If so, test power supply. It is common for these to go out..
Posted on Sep 13, 2009
fieldy14
  • 456 Answers
SOURCE: Thick line down middle of RCA LCD television.
the problem may be a combination of three things, it may be the lcd panel, the main printed circuit board, or the logic printed circuit board, the small circuit board that the panel plugs into sometimes. replace either one at a time or all, these situations always come with some trial and repeat testing. Good luck.
Posted on Nov 15, 2009
SOURCE: I have a RCA L32HD31 LCD TV and there is no
jerry.... Unless you have anymore queries.... you can proceed to click the end session button in the chat box and click on accept..... if you have already closed the chat box.... You may click on the "my Profile" link at the top right of this screen, click on the chat session we had and rate the solution
Good Luck
Posted on Aug 14, 2010
Testimonial: "Great info and great explanations."
art_mau
  • 11 Answers
SOURCE: yes i have a rca l32hd31 and i went to turn it on
Parece existir algum problema na Fonte de Alimentaçao do TV. Provavelmente capacitores eletroliticos deficientes. Quanto ao cabo USB service voce teria que possuir o programa de fabrica para ajuda-lo na pesquisa do defeito. Se possuir conhecimentos tecnicos verifique a FONTE.
Posted on Dec 13, 2010
Horizontal line about 1 from bottom of picture
The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 13, 2016 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
3 Horizontal lines distorting picture
When you say "distort the picture", are you referring to dark image? double picture
Jan 20, 2013 | Samsung Touch of Color LN52A650 52 in. LCD...
Just got this tv from friend. has no remote. screen is black. sound is good. when you push menu button, white line goes across horizontally the screen.
The horizontal line indicates the vertical deflection circuit is not working. Either the set is stuck in service mode for adjusting color (turns off vertical), or the deflection circuit has failed.
Some RCA TV sets have a "Service" switch in the back, down near the bottom of the set. Most of the newer sets use a combination of remote control and front panel buttons to get into service mode, and that can be turned off by unplugging the set and plugging it back in. Try looking for the mechanically operated service switch in the back first.
Jan 05, 2011 | RCA F25442 25" TV
Screen goes to horizontal line
Maybe the vertical IC got some cracked solder joints and the reparation worth it
Apr 24, 2009 | Televison & Video
KV36XBR400 fragmented picture horizontal overlapping lines
this will continue to degrade, almost any failure that can be affected or temporarily cleared up by hitting the set is caused by bad solder joints.
A good shop should be able to find and fix the bad solder connections for probably a little under $100
if you bring it to them and pick it up.
Feb 10, 2009 | Sony KV-36XBR400 36" TV
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
RCA L32HD41 LCD TV Logo
140 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
