Question about LG LFX23961ST Stainless Steel Bottom Freezer French Door Refrigerator
LG not functioning
Need instructions lg sound bar remote control akb74815321
  1. Turn on your Sound Bar.
  2. Select LG TV function by using FUNC on the remote control or F on the unit until the correct function is selected.
  3. Set up LG Sound Sync (Wireless) on the TV. Refer to your TV's instruction manual for detailed steps
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 11, 2016 | LG Televison & Video
The vol, input and other functions won't work it's not the remote
If you are using a remote other than the LG remote that came with the TV it could be an improper code setting. Most TVs have up to 10 or 15 codes to match the remote to the TV. Some codes will work for some functions, but not all.
Jan 02, 2016 | LG Televison & Video
I can't seem to change function from DVDs/usb to aux or radio function on my lg home theater fb162. With or without the remote present.please assist
Whether the remote, or using any buttons on the unit, those inputs go into a microprocessor(computer within your unit). There can be other issues, but that is the most likely.
If you are interested in having your LG repaired, please look to my website at audioserviceclinic.com. Thank you.
Aug 09, 2015 | LG Audio Players & Recorders
I've tried all suggestions from other posts but still can't get Tub Clean Function to work.
Only suggestion I have is to try these old reset solution that work on some older lg washers: unplugg and wait 5 minutes or so, or unplug an d hold power button for 15 seconds, or unplug and the plug back in holding power button down for about 15 seconds then release. Good luck. (LG makes great products but their customer service and repair are horrible).
Mar 31, 2015 | LG Washing Machines
How can I turn auto dim function off on my LG M227WD?
Use LG Remote Control, press Menu and turn off Energy Saving function.
May 23, 2010 | LG M2294D-PZ 22 in. LCD TV
Monitor LG l1910 S that does not function
hello, maybe you supplier is damaged, and this iss the problem
you can solve it with a simple check by multimeter if the supplier gives you more then 9v his ok.
thank you, ron
Mar 17, 2009 | LG L1910S (Silver) 19" LCD Monitor
Touch functions
Looks like you might need a new screen !1
Dec 08, 2008 | LG KU990 Viewty
I want to be able to transfer/copy/store the texts from phone to pc
all lg of most lg phones are like this...so it is not possible..so sorry
Jun 26, 2008 | LG Prada KE850 Cellular Phone
LG CG225
hi , Are you sure your phone has bluetooth functionality ,coz from the userguide i couldn't find any blutooth functionality for LG cg225 http://www.hawkelectronics.com/uploadedFiles/Owners_Guides_PDFs/LG_CG225_User_Guide_English.pdf If you got a different model,please do come back. sreejith
Jul 16, 2007 | LG CG225 Cellular Phone
LG LFX23961ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
44 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
