Question about Hotpoint WMA31 Front Load Washer
Drum wont turn
Our washing machine has been noisy for ages and now the drum seems to be jammed. If i start a program it starts to fill with water and tries to turn but sticks as if its being jammed by something. I've tried to take it apart to check but i can't even see a way to get inside it properly. just the top panel and a little panel on the back. how can i take the whole case apart? please help! james
  • sarahjane123 Feb 23, 2009
    our washing machine has just stopped spinning and i have checked filter which is free of blockages what is the possible cause off this and can i be talked through sorting this problem myself. there was no noise before it stopped which does not indicate a bearing has gone and the washing machine still fills with water my wma 31 has a hot and cold fill
    Novelist:
  • 159 Answers
Sounds to me like the rear bearing is seized up. Seeing how you describe its been noisy for ages I would say the porblem is the bearing. Its not a easy jub to replace for a novice.The entire tub must be removed and taken apart to replace the rear bearing. To take the case apart its only the front panel with the door that that will come off. there should be a wire with a spring that holds the bellows to the door. remove that and the rest should come apart from the inside. Dont forget to disconect the dor switch.
Posted on Aug 06, 2007
Our washing machine wma 31 has just stopped turning the drum and can not get it to work
Posted on Feb 23, 2009
Hotpoint WMF760 fills but won't wash
http://www.how-to-repair.com/help/faqs/hotpoint-wml540-washing-machine-that-wont-start/
Aug 30, 2016 | Hotpoint Washing Machines
Hotpoint ultima washing machine wma74 drum not turning
If the machine wasn't excessively noisy before and when you select spin only you can't hear the motor running its likely to be the carbon brushes in the motor worn down till they no longer contact stick a new set in if the carbon length sticking out the brass holder is less than around half an inch long
Dec 08, 2013 | Hotpoint Ultima WF860 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer - DRUM DOESN'T CYCLE
This seems to be a fault with the program controller unit or the water level sensor. The program does not advance further after the inlet is filled but operates the drain to exit water. Now the water level sensor must be checked as if this is not working in the stipulated time it will drain out. Also unless the water level sensor contacts on reaching of set level the motor must start.http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 14, 2012 | Washing Machines
New washer, seems to work fine. I just question the water filling sequence at start of a wash. The water valve opens in 1 sec spurts about 6 times when drum is rotating in one direction. On 7th time it...
Every few months, new things are done to improve washing methods. If washing machine is washing clothing cleanly, and no apparant fault code comes up, then it is how the controller is programmed and meant to be.
Aug 14, 2010 | LG Washing Machines
Washing machiene drum won't turn
it sounds like you've got an item of clothing jammed between the inner and outer drum
Jun 22, 2009 | Indesit W 123 Front Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Indesit wd125 drum wont turn
check your pump it may not be working
Dec 18, 2008 | Indesit W 123 Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Hotpoint WMA31 Front Load Washer Logo
272 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
