Question about Ricoh Office Equipment & Supplies
Sc 569 The equipment has constantly this code the client disconnects and connects back to work and she
Smartcard cannot be forwarded to Terminal Server via RDP
Try re-registering the services on the client computer and see if that fixes it. Otherwise I would consider reinstalling Windows on the client.
Feb 11, 2014 | Microsoft Windows 7 Professional 64 Bit 3...
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
What does error code E05-73 on my Panasonic DP-C263 mean and how can I fix it?
E5-73 is a HDD Abnormal Operation. First try turning the system off, counting to 30 and turning it back on. If it persists you want to check the HDD connections. May be a failed HDD. Panasonics exact answer is:
1. HDD connector is disconnected.
2. SC connector is disconnected.
3. HDD is defective.
4. SC PCB is defective.
Apr 10, 2012 | Office Equipment & Supplies
I need a code for a ilo television to Dish network
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. We have a few different codes for each of our different models of remotes. I will list here for you the best codes for a ilo TV for our more popular models of remotes and the instructions for addressing the remote to the TV. I hope this information is useful and if you have any further questions please let me know!
remote models remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 569, 720, 095, 743, 721, 500.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 569, 720, 128, 834, 729.
4.0 and 4.4 IR/UHF remotes - codes 720, 569, 500, 669, 549.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 569, 720, 500, 456, 506, 834.
20.0 IR and 21.0 IR/UHF remotes - codes 726, 559, 666, 596, 621, 596, 625.
Instructions for addressing the remote to the TV
1. Turn the TV on
2. Press and hold down the TV mode button until all the mode buttons light up red.
3. Enter the 3 digit code for you TV.
4. Press the pound(#) button once.
5. Try the TV functions to make sure it works.
Nov 05, 2011 | iLO 3200 32 in. LCD Television
What is the three digit code for DISH on a Sylvania LC195SLX
Hi, my name is Cheri Torres and I work with DISH Network Customer service. We have a few different codes for each of our different models of remotes. I will list here for you the best codes for each of our more popular models of remotes and the instructions for addressing the remote to the TV. I hope this information helps and if you have any other questions please let me know!
Remotes models Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 632, 569, 566, 671, 733, 515, 568, 764.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 632, 569, 566, 536, 733, 672, 660.
4.0 and 4.4 IR/UHF remotes - codes 733, 569, 566, 632, 764, 664.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 733, 569, 566, 654, 672, 632, 764.
20.0 IR and 21.0 IR/UHF remotes - codes 733, 672, 777, 566, 764, 527.
1. Press and hold down the TV mode button until all the mode buttons light up red.
2. Enter the 3 digit code using the keypad.
3. Press the pound(#) button once.
4. Test the functionality of the TV.
Oct 17, 2011 | Sylvania LC195SLX LCD TV
Brake lights wont go off
If the stoplamps are on continuously, the following may be at fault:
  1. Circuitry.
  2. Brake pedal position (BPP) switch.
  3. Multifunction switch (Crown Victoria equipped with the police street appearance package or Grand Marquis)
CHECK THE BRAKE PEDAL POSITION (BPP) SWITCH
Disconnect: BPP Switch. Do the stoplamps continue to illuminate? If yes, continue to the next step. If no install a new BPP Switch.
CHECK CIRCUIT 511 (LG) FOR SHORT TO POWER
Disconnect: Central Junction Box (CJB) Fuse 14 (20A). Do the stoplamps continue to illuminate? If yes, and your Crown Victoria is equipped with the police street appearance package or Grand Marquis, continue to the next step. If Crown Victoria, REPAIR circuit 569 (DG). TEST the system for normal operation. If no, REPAIR the circuit. TEST the system for normal operation.
CHECK CIRCUIT 9 (LG/OG) FOR SHORT TO POWER
Disconnect: Multifunction Switch C202c. Does the LH stoplamp continue to illuminate? If yes, REPAIR the circuit. TEST the system for normal operation. If no, go to next step.
CHECK CIRCUIT 5 (OG/LB) FOR SHORT TO POWER
Disconnect: Multifunction Switch C202c. Does the RH stoplamp continue to illuminate? If yes, REPAIR the circuit. TEST the system for normal operation. If the high mounted stoplamp continues to illuminate, REPAIR circuit 569 (DG). TEST the system for normal operation. If the high mounted stoplamp does not continue to illuminate, INSTALL a new multifunction switch. TEST the system for normal operation.
Mar 09, 2011 | 2005 Ford Crown Victoria
I AM LOOKING FOR A REMOTE CODE FOR A PANASONIC
We would be happy to help with that. Here is a list of someof the codes that we have for Panasonic SC-HT940 System: 810, 799, 783, 643, 677, and 678.
Start by pressing and holding the AUX mode button until all mode buttons at the top of theremote light up, then release. Enter the number 2 then one of the codes for your Panasonic SC-HT940 System provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Panasonic System. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
May 24, 2010 | Panasonic SC-HT940 System
Need code to make Echostar dish network dvr remote 6.3 to work with tv modle number LC225SSX
We would be happy to help you with getting your DISH Networkremote to control your Sylvania TV. We're going to start by pressing and holding the TVbutton located on the top of your remote until all mode button back lights comeon, and then release. Use the number buttons to enter the codes for your Sylvania TV; here are some of the codes we currently have: 733, 672, 777, and 569. Press the pound (#) button. To check if the code works try severaldifferent functions on the remote to make sure it will properly operate your TV.Remember that some codes may not be compatible with your equipment. If this isthe case, try the other codes listed for your Sylvania TV until you findone that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
Feb 08, 2010 | Sylvania LC225SSX LCD TV
Asoon as i turn on my copier sereis it displays code p-96-569
This error code means either the print drum color information or ink category information is not input. Easy fix.
Make sure the drum in the machine has ink in it. It must be the correct ink for use in an EZ. Start into test mode by turning the machine on while holding down the left and right arrows for the print position. Hit the "C" key to clear out display. Should read 0000. Type in 590, then hit start. Type in 557, then hit start.
Machine will load information from the ink bottle into the machine and rotate a few times.
Once it stops, turn off and back on to get out of test mode. All set!
Jun 12, 2009 | Riso RZ220 Duplicator
Error code sc 490 and sc360
Did you try to rest the error? Do you know how too?
Feb 09, 2008 | Ricoh Aficio 450 Copier
12 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
