Question about Frigidaire Gallery GLWS1339EC Top Load Washer
Water pump question
Should the impeller on the water pump spin freely or should there be some resistence every so often
  • Frigidaire Master
  • 3,051 Answers
Hello there and welcome to fixya
this impeller is attached to a pump that will pump out the water out of the machine.
There fore it should have resistance all the time If not then it may need to be replaced meaning the impeller but if it is removed and is in good working order then the pump has failed and will have to be replaced ok
Please post back if you have any other issues or need instructions on how to remove the pump for dissassembly and repairs
Best regards michael
Posted on May 27, 2013
I removed water pump should the impeller spin freely?
no
water pumps when in good condition have a resistance to spinning freely from the load on the seal at the back of the impeller /or seal on the motor shaft and from the magnets in the field material of the motor
Nov 15, 2015 | Frigidaire Washing Machines
Will not pump water out
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure nothing is clogging the pump, like the occasional stray piece of clothing, and check the pump impeller. Make sure there are no broken or missing blades and that the impeller will spin freely. If any blades are broken/missing or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 04, 2009 | Washing Machines
IDL40 Not draining water off and 2 green lights fashing - what do we do?
Sep 28, 2009 | Washing Machines
Spin will not get all of the water out of clothes
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller will spin freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump, drain line, or a jammed impeller. Hope this helped and best wishes.
Sep 06, 2009 | Hotpoint VBXR1070W
Im my washing machine the problem , the water coming in
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no missing or broken blades on the impeller and that the impeller spins freely. If any blades are missing/broken or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump, drain line, or jammed impeller. Sorry for your trouble and I hope this helped. Best wishes.
Sep 02, 2009 | Washing Machines
Maytag fills but wont pump out water
Yes, it sounds like you need to check the pump. Remove the hoses from the pump and using a flashlight, look into the suction port of the pump. Check for anything clogging the pump (like the occasional stray sock) Also check the pump impeller. Make sure there are no broken/missing blades and make sure the impeller spins freely. If any blades are missing/damaged or if you cannot get the impeller to spin freely, then the pump is bad. Hopefully it is just a clogged pump. Hope this helps and best wishes.
Aug 31, 2009 | Washing Machines
Our maytag proforma machine was making a loud noise during washing cycle. water wasn't draining - we think it may be the water pump?
Aug 30, 2009 | Washing Machines
Machine spins but water stays in machine
I would check for a clog somewhere. Make sure the drain hose is not kinked or clogged. Take a flashlight and look into the suction port on the pump. Make sure it is not clogged and check the pump impeller. Make sure no blades are broken or missing and that the impeller turns freely. If any blades are broken or missing or if the impeller won't move freely, then the pump will have to be replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Aug 09, 2009 | Washing Machines
Please help!
remove bottom panel remove as much water as possible from tub ..have lots of towels handy remove clean out port on pump clean and reinstall...also ck as far into pump for something jammed in impeller ..pump may need to be removed to clean if unable to clear jam ..3 screws hold pump motor to pump body remove if necessary also ck to see if pump impeller is spinning freely on motor shaft should be some resistance when turning if impeller spins freely replace pump
Oct 04, 2008 | Kenmore Elite 45986 Front Load Washer
Water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Frigidaire Gallery GLWS1339EC Top Load Washer Logo
43 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
